    1.3k Posts 300 Posters 3.1m Views 298 Watching
      Daniel S
      Great update Fredo! Very powerful!!
      If you select all and then apply skin there are still issues with this type of geometry:
      skin not work right.skp
      Daniel S
      • fredo6F
        Daniel S
        Daniel,
        Thanks for this contribution. There are issues, for sure. I will have a close look.
        In the meantime, it is recommended to use the method of explicitly putting small segments to indicate where to cut cell contours.
          DIEGO-RODRIGUEZ
          hi fredo.
          ruby console, a new error:
          D:/Archivos de programa/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:2166: warning: Object#id will be deprecated; use Object#object_id
          Could you fix it.
          I´m use:
          windows xpSp3 Spanish
          sketchup last version in Spanish
          thank you very much
          • fredo6F
            @diego-rodriguez said:
            hi fredo.
            Could you fix it.
            It is just a warning, but I'll fix it for the next release
            • C
              cam youds
              I must be slow in the head but I keep getting this msg
              Cannot load plugin Curviloft because the script cannot create DEFPARAM_Dir folder in:
              /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
              Please create it manually, respecting the case
              What am I doing wrong?????????????????????????????????????????????????
              • fredo6F
                It may be that your system folder is protected by some security rules preventing to create folders there by program.
                So just create the folder DEFPARAM_Dir manually in the directory: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins and this should work.
                • C
                  cam youds
                  It works....Life changing!...no more rhino or soild works!!!!!!
                    DIEGO-RODRIGUEZ
                    frequently, I have a little problem.
                    does not generate the geometry.
                    http://img94.imageshack.us/img94/2872/86299088.gif
                    if I open the ruby console and run the plugins. Sketchup is labeled.
                    and generate this error:
                    http://img146.imageshack.us/img146/6030/sinttulo1yj.jpg
                    skin test.skp
                    • fredo6F
                      does not generate the geometry. if I open the ruby console and run the plugins. Sketchup is labeled.
                      Diego,
                      The two shapes in your attached file work fine by pre-selecting all contours.
                      But I did not find the small shapes where you seem to have troubles (the one with color edges on your picture).
                      For the warning in the Ruby console, do not worry. This is harmless and I have already fixed it for the next release.
                      fredo
                        DIEGO-RODRIGUEZ
                        hi fredo.
                        thanks for your response.
                        already solved the problem.
                        Reinstall sketchup, in another partition of my hard disk and found that the problem is a file called MSVCRT-ruby18.dll
                        upload the file.
                        file size 853kb not works
                        file size 792kb works
                        file.rar
                        • pep75P
                          pep75
                          Thanks Fredo! Brilliant update!! Thanks so much!!
                          grtzzz
                          Pep
                          • olisheaO
                            olishea
                            this really is a different league of plugin!!
                            something i've been wanting for a LONG time. how come you don't charge? its amazing
                            oli
                            • mariochaM
                              mariocha
                              Testing the beta, the skin command cannot complete this file, attached.
                              EEbyrails does it well tought.
                              No-skin.skp
                              %(#008000)[Mario C.
                                Both work for me... but there are more facets in CurviLoft's result...Capture.PNG
                                • mariochaM
                                  mariocha
                                  Thanks TIG,
                                  So I tried it on the PC side of my MAC, and it worked just fine.
                                  frustrated me 😢
                                  Strange, cause other curves were ok.
                                  %(#008000)[Mario C.
                                  • fredo6F
                                    Mariocha,
                                    I think I know what it is and why it is specific to Mac. I'll publish a fix soon with a new release.
                                    By the way, you can adjust the density of meshing by using the Interpoland OverSamplingboxes. If you deactivate both, then you get a mesh strictly built on the original contour vertices.
                                    • mariochaM
                                      mariocha
                                      A new relase ? Great !! 👍 👍 👍
                                      And Oversampling & Interpol will be so usefull for designing !
                                      C'est vraiment super !
                                      as I'm working on a tensile structure these days.
                                      %(#008000)[Mario C.
                                      • cmeedC
                                        cmeed
                                        help.
                                        I see skinning videos posted within this thread but i can't get this shape to work. it seems so simple.....
                                        I click contours, click space, i then repeat until all three lines are coloured and click the tick button or open space. i get a PLEASE WAIT then nothing happens.
                                        Am I doing something wrong, is it Because i'm on a mac?
                                        the last picture is tig's rails but i have to make a 4th rail for it to work.
                                          Should work with the 3 curves in either Fredo's or mine. With EEbyRails Pick the curve as the profile then the 2 side rails and then re-pick the profile again as the melding-profile - it will end with a point and triangular faces opposite the profile's end, as desired...Capture.PNG
                                          • cmeedC
                                            cmeed
                                            Thank you for your speedy reply. Tig your plugin is working great (i didn't know about going back to my first curve to make three curves work, cheers)
                                            what i'm making is a field of 800 tents - the ones you can put up in 3 seconds. So i need a way of using the contours and keeping the the polys down.
                                            see pic tent - I used the loft by spline to get this but its not that great, Skinning didn't work.
                                            i wanted to used fredos to get the polys down.
                                            • 11
                                            • 12
                                            • 13
                                            • 65
                                            • 66
                                            • 11 / 66
