    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • charly2008C
      charly2008
      Dear TIG and Massimo,
      thank you for your advices. The background for my experiments with a winding road is the representation of the curve slope.
      With EEbyLoft I have also tried. TIG, your EEbyL is also a great tool. I would not belittle your merits. But in this case it is difficult to find the correct level for the protractor because the Edges. With Curviloft i can use faces and I can change the faces more simple(made by Perpendiculare Faces) gradually at an specified angle and can construct the slope. And this worked in my first attempt (see pictures below).
      You may have seen my posts with winding Roads in the forum. The disadvantage of these Roads was, that the road profile was shown only horizontal in the curves.
      Charly
      • fredo6F
        NEW BETA RELEASE
        Curviloft 1.0b – LibFredo6 3.5b – 11 Jul 10: Second beta version, dedicated to Loft by Spline and Skinning (Loft Along Path is still not fully functional). Main changes are:
        • Skinning should better accept preselection of contours and make its way to create the mesh
        • Added some spline methods (Linear, Ortho-elliptic and ortho-spline)
        • For Skinning and Loft Along Path, you can over-sample the rails
        • For Skinning, you can swap the direction between contours and rails
        • Preview Mesh is normally black in SU7
        • Floating palette remembers its position across SU sessions
        • Spanish translation by Defisto
          On top of potential bugs and geometry issues (including bugsplats), there are some limitations and unfinished work
        • VCB is not active
        • No interactive edition in the floating palette
        • B-Spline and F-Spline do not close nicely in loop mode
        • No later reedition of shape generated (this will come)
        • all texts and labels are not reviewed yet
        see main post for download:http://forums.sketchucation.com/viewtopic.php?f=323&t=28586#p248195
        • fredo6F
          Charly,
          Thanks very much for your deep testing of Curviloft. It helps me find and hopefully fix the many bugs and imprecisions remaining in the script. This is why I judged that I had to go through a long beta phase with the users.
          For the long and winding roads, I have found the issues and they should be adressed in the next release 1.0b.
            dylan
            Thanks Fredo 👍
            http://dmdarchitecture.co.uk/
            • charly2008C
              charly2008
              thanks Fredo,
              you are great.
              Charly
              • X
                xrok1
                  Daniel S
                  Great update Fredo! Very powerful!!
                  If you select all and then apply skin there are still issues with this type of geometry:
                  skin not work right.skp
                  Daniel S
                  • fredo6F
                    Daniel S
                    Daniel,
                    Thanks for this contribution. There are issues, for sure. I will have a close look.
                    In the meantime, it is recommended to use the method of explicitly putting small segments to indicate where to cut cell contours.
                      DIEGO-RODRIGUEZ
                      hi fredo.
                      ruby console, a new error:
                      D:/Archivos de programa/Google/Google SketchUp 7/Plugins/LIBFREDO6_Dir_35/Lib6EdgePicker.rb:2166: warning: Object#id will be deprecated; use Object#object_id
                      Could you fix it.
                      I´m use:
                      windows xpSp3 Spanish
                      sketchup last version in Spanish
                      thank you very much
                      • fredo6F
                        @diego-rodriguez said:
                        hi fredo.
                        Could you fix it.
                        It is just a warning, but I'll fix it for the next release
                        • C
                          cam youds
                          I must be slow in the head but I keep getting this msg
                          Cannot load plugin Curviloft because the script cannot create DEFPARAM_Dir folder in:
                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                          Please create it manually, respecting the case
                          What am I doing wrong?????????????????????????????????????????????????
                          • fredo6F
                            It may be that your system folder is protected by some security rules preventing to create folders there by program.
                            So just create the folder DEFPARAM_Dir manually in the directory: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins and this should work.
                            • C
                              cam youds
                              It works....Life changing!...no more rhino or soild works!!!!!!
                                DIEGO-RODRIGUEZ
                                frequently, I have a little problem.
                                does not generate the geometry.
                                http://img94.imageshack.us/img94/2872/86299088.gif
                                if I open the ruby console and run the plugins. Sketchup is labeled.
                                and generate this error:
                                http://img146.imageshack.us/img146/6030/sinttulo1yj.jpg
                                skin test.skp
                                • fredo6F
                                  does not generate the geometry. if I open the ruby console and run the plugins. Sketchup is labeled.
                                  Diego,
                                  The two shapes in your attached file work fine by pre-selecting all contours.
                                  But I did not find the small shapes where you seem to have troubles (the one with color edges on your picture).
                                  For the warning in the Ruby console, do not worry. This is harmless and I have already fixed it for the next release.
                                  fredo
                                    DIEGO-RODRIGUEZ
                                    hi fredo.
                                    thanks for your response.
                                    already solved the problem.
                                    Reinstall sketchup, in another partition of my hard disk and found that the problem is a file called MSVCRT-ruby18.dll
                                    upload the file.
                                    file size 853kb not works
                                    file size 792kb works
                                    file.rar
                                    • pep75P
                                      pep75
                                      Thanks Fredo! Brilliant update!! Thanks so much!!
                                      grtzzz
                                      Pep
                                      • olisheaO
                                        olishea
                                        this really is a different league of plugin!!
                                        something i've been wanting for a LONG time. how come you don't charge? its amazing
                                        oli
                                        • mariochaM
                                          mariocha
                                          Testing the beta, the skin command cannot complete this file, attached.
                                          EEbyrails does it well tought.
                                          No-skin.skp
                                          %(#008000)[Mario C.
                                            Both work for me... but there are more facets in CurviLoft's result...Capture.PNG
                                            • 11
                                            • 12
                                            • 13
                                            • 65
                                            • 66
                                            • 11 / 66
