    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 103.3k Views 35 Watching
    • C
      c.plassais
      Hello
      As requested Cadfather, I have added the possibility to colorize angles
      Edge by edge per click
      Edges connected to a face by clicking on the face
      All edges connected by double-clicking on face or edge
      [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
      Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
      Christophe
      • CadFatherC
        CadFather
        thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
        (really sketchup fun changing the colours 😛 )
        if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
          Jörg
          Thank you Chris, this is amazing!!!!
          I waited for the dottet lines for years!
          Jörg
          • DavidBoulderD
            DavidBoulder
            I trick for color by profile. Not very smooth, but if you have to tools it works nice.
            • Work as normal in SketchUp
            • Drop views into Layout
            • Export from Layout as vector PDF
            • Import into Adobe Illustrator
            • Select "Final all lines with same width"
            • You can now isolate them and color or alter as desired
            note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
            David
            David Goldwasser
            OpenStudio Developer
            National Renewable Energy Laboratory
              stefx
              I use Mac and it looks like it doesn't work..... 😞
              any tips?
              stef.
              • C
                c.plassais
                any tips?
                stef.
                Oops!
                Sorry but I do not test on Mac.
                cmeed uses the plugin successfully on Mac
                can you send me a copy of the errors returned
                Christophe
                  stefx
                  Hi Christophe,
                  I have solved the problem just restarting my Mac.
                  Sorry for the trouble,
                  Thank you for the amazing plugin!
                  stef.
                  • C
                    c.plassais
                    no problem
                    it suits me 😉
                    • C
                      c.plassais
                      Hi Everyone,
                      a new version ChrisP_ColorEdge 0.2.2
                      Adding the management layer
                      Draw an edge by layer, with a color of your choice or the color of the active layer.
                      Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                      Dotted lines by filtering by layer
                      Thank you to TIG for his plugin ListeLayerColors
                      [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                      Enjoy
                      Christophe
                      • C
                        c.plassais
                        Adding icons designed by Max (CadFather)
                        Icons designed by max
                        A big thank you max 👍
                        Christophe
                        • C
                          c.plassais
                          ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                          Regards
                          Christophe
                          • Y
                            yvan79
                            good plugin to counter autoCAD colored edges....
                              jsteacy
                              Very cool, 😎
                              • P
                                plf10
                                thank you for your share 💚
                                  dtrarch
                                  A gotta have script and just super for tracing over scan'd drawings and such.
                                  Thank you so very much. 😍
                                  Note that if one selects a color visually from materials it will be the default for the line tool color.
                                  Works well especially as on can sample on screen colors too this way for repeats.
                                  Cheers 😄
                                  dtr
                                    akigrimm
                                    Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
                                      JuanV.Soler
                                      It is under ...VIEW __TOOLBARS ^`...Color Edge
                                      • C
                                        c.plassais
                                        Thanks Juan 👍
                                        • B
                                          Builder Boy
                                          Shade by 3 colors dosn't work for me 😞 Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS! 😠
                                          All my plugins
                                            JuanV.Soler
                                            Yes,
                                            I don´t understand the tool neither. Use it for lines, enough for me. Sorry.
                                            I have to investigate though I have the feeling that it is not tunned yet or updated.
                                            • 2 / 4
