    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 103.3k Views 35 Watching
    • P
      Panga
      Thanks Christope, It'll be helpfull.
      Regards
      • W
        watkins
        Dear Chris,
        Is this plugin only for wireframe models, or can one use it to colour the edges of models with faces? There is an icon in the toolbar which appears to be unused at the moment (multi-coloured checkerboard face). What does this do?
        The functionality offered by the plugin is very interesting, but where might one use it? Am I being dense?
        Kind regards,
        Bob
        • kenK
          ken
          Thanks for the plugin. Maybe I will be able to get the black screen drawing display.
          On another note, would it be possible to limit the color selection to just the basic colors.
          Again thank you for your plugin.
          Ken
          • C
            c.plassais
            Sorry if I dont understand everything I am a Frenchy and it is a real handicap 🤣
            I am newbie with English and ruby
            In response to your comments :
            Cadfather
            About protractor, the difficulty is the accuracy with the mouse to find the right angle with inference no problem. But I'll try.
            Colorize only corners no problem, it’s fairly easy and it's a good idea
            Cmeed
            What do you mean to colour by profile ?
            I see you using Mac, so no problem with the plugin apparently?
            Watkings
            no problem for use on the edges of a face.
            The only restriction is if you do a push pull on the face, must be weld segments and after dotted repeat
            The last icon is just for information, it is the color chart
            Ken
            I posted a "lite" version with only 8 basic colors
            Christophe
            • kenK
              ken
              Thank you for the very fast response and the plugin.
              Ken
              • MALAISEM
                MALAISE
                I was waiting for such a plugin for a while. Thanks a lot Chris for sharing
                Pierre
                • cmeedC
                  cmeed
                  Cmeed
                  Not really the person to ask about crashes as I've only used it once but happily with great success. No crashes.
                  heres what i was asking about in the pic - just profiles?
                  • C
                    c.plassais
                    sorry but I dont think this is possible.
                    profile changes with position camera.
                    The plugin will change line's material 😞
                    • C
                      c.plassais
                      Hello
                      As requested Cadfather, I have added the possibility to colorize angles
                      Edge by edge per click
                      Edges connected to a face by clicking on the face
                      All edges connected by double-clicking on face or edge
                      [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
                      Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                      Christophe
                      • CadFatherC
                        CadFather
                        thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
                        (really sketchup fun changing the colours 😛 )
                        if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
                          Jörg
                          Thank you Chris, this is amazing!!!!
                          I waited for the dottet lines for years!
                          Jörg
                          • DavidBoulderD
                            DavidBoulder
                            I trick for color by profile. Not very smooth, but if you have to tools it works nice.
                            • Work as normal in SketchUp
                            • Drop views into Layout
                            • Export from Layout as vector PDF
                            • Import into Adobe Illustrator
                            • Select "Final all lines with same width"
                            • You can now isolate them and color or alter as desired
                            note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
                            David
                            David Goldwasser
                            OpenStudio Developer
                            National Renewable Energy Laboratory
                              stefx
                              I use Mac and it looks like it doesn't work..... 😞
                              any tips?
                              stef.
                              • C
                                c.plassais
                                any tips?
                                stef.
                                Oops!
                                Sorry but I do not test on Mac.
                                cmeed uses the plugin successfully on Mac
                                can you send me a copy of the errors returned
                                Christophe
                                  stefx
                                  Hi Christophe,
                                  I have solved the problem just restarting my Mac.
                                  Sorry for the trouble,
                                  Thank you for the amazing plugin!
                                  stef.
                                  • C
                                    c.plassais
                                    no problem
                                    it suits me 😉
                                    • C
                                      c.plassais
                                      Hi Everyone,
                                      a new version ChrisP_ColorEdge 0.2.2
                                      Adding the management layer
                                      Draw an edge by layer, with a color of your choice or the color of the active layer.
                                      Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                                      Dotted lines by filtering by layer
                                      Thank you to TIG for his plugin ListeLayerColors
                                      [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                                      Enjoy
                                      Christophe
                                      • C
                                        c.plassais
                                        Adding icons designed by Max (CadFather)
                                        Icons designed by max
                                        A big thank you max 👍
                                        Christophe
                                        • C
                                          c.plassais
                                          ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                                          Regards
                                          Christophe
                                          • Y
                                            yvan79
                                            good plugin to counter autoCAD colored edges....
                                            • 1 / 4
