    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 103.3k Views 35 Watching
    • kenK
      ken
      Thank you for the very fast response and the plugin.
      Ken
      • MALAISEM
        MALAISE
        I was waiting for such a plugin for a while. Thanks a lot Chris for sharing
        Pierre
        • cmeedC
          cmeed
          Cmeed
          What do you mean to colour by profile ?
          I see you using Mac, so no problem with the plugin apparently?
          Not really the person to ask about crashes as I've only used it once but happily with great success. No crashes.
          heres what i was asking about in the pic - just profiles?
          • C
            c.plassais
            sorry but I dont think this is possible.
            profile changes with position camera.
            The plugin will change line's material 😞
            • C
              c.plassais
              Hello
              As requested Cadfather, I have added the possibility to colorize angles
              Edge by edge per click
              Edges connected to a face by clicking on the face
              All edges connected by double-clicking on face or edge
              [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
              Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
              Christophe
              • CadFatherC
                CadFather
                thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
                (really sketchup fun changing the colours 😛 )
                if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
                  Jörg
                  Thank you Chris, this is amazing!!!!
                  I waited for the dottet lines for years!
                  Jörg
                  • DavidBoulderD
                    DavidBoulder
                    I trick for color by profile. Not very smooth, but if you have to tools it works nice.
                    • Work as normal in SketchUp
                    • Drop views into Layout
                    • Export from Layout as vector PDF
                    • Import into Adobe Illustrator
                    • Select "Final all lines with same width"
                    • You can now isolate them and color or alter as desired
                    note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
                    David
                    David Goldwasser
                    OpenStudio Developer
                    National Renewable Energy Laboratory
                      stefx
                      I use Mac and it looks like it doesn't work..... 😞
                      any tips?
                      stef.
                      • C
                        c.plassais
                        any tips?
                        stef.
                        Oops!
                        Sorry but I do not test on Mac.
                        cmeed uses the plugin successfully on Mac
                        can you send me a copy of the errors returned
                        Christophe
                          stefx
                          Hi Christophe,
                          I have solved the problem just restarting my Mac.
                          Sorry for the trouble,
                          Thank you for the amazing plugin!
                          stef.
                          • C
                            c.plassais
                            no problem
                            it suits me 😉
                            • C
                              c.plassais
                              Hi Everyone,
                              a new version ChrisP_ColorEdge 0.2.2
                              Adding the management layer
                              Draw an edge by layer, with a color of your choice or the color of the active layer.
                              Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                              Dotted lines by filtering by layer
                              Thank you to TIG for his plugin ListeLayerColors
                              [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                              Enjoy
                              Christophe
                              • C
                                c.plassais
                                Adding icons designed by Max (CadFather)
                                Icons designed by max
                                A big thank you max 👍
                                Christophe
                                • C
                                  c.plassais
                                  ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                                  Regards
                                  Christophe
                                  • Y
                                    yvan79
                                    good plugin to counter autoCAD colored edges....
                                      jsteacy
                                      Very cool, 😎
                                      • P
                                        plf10
                                        thank you for your share 💚
                                          dtrarch
                                          A gotta have script and just super for tracing over scan'd drawings and such.
                                          Thank you so very much. 😍
                                          Note that if one selects a color visually from materials it will be the default for the line tool color.
                                          Works well especially as on can sample on screen colors too this way for repeats.
                                          Cheers 😄
                                          dtr
                                            akigrimm
                                            Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
                                            • 2 / 4
