    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 102.0k Views 35 Watching
    • C
      c.plassais
      Sorry if I dont understand everything I am a Frenchy and it is a real handicap 🤣
      I am newbie with English and ruby
      In response to your comments :
      Cadfather
      About protractor, the difficulty is the accuracy with the mouse to find the right angle with inference no problem. But I'll try.
      Colorize only corners no problem, it’s fairly easy and it's a good idea
      Cmeed
      What do you mean to colour by profile ?
      I see you using Mac, so no problem with the plugin apparently?
      Watkings
      no problem for use on the edges of a face.
      The only restriction is if you do a push pull on the face, must be weld segments and after dotted repeat
      The last icon is just for information, it is the color chart
      Ken
      I posted a "lite" version with only 8 basic colors
      Christophe
      • kenK
        ken
        Thank you for the very fast response and the plugin.
        Ken
        • MALAISEM
          MALAISE
          I was waiting for such a plugin for a while. Thanks a lot Chris for sharing
          Pierre
          • cmeedC
            cmeed
            Cmeed
            Not really the person to ask about crashes as I've only used it once but happily with great success. No crashes.
            heres what i was asking about in the pic - just profiles?
            • C
              c.plassais
              sorry but I dont think this is possible.
              profile changes with position camera.
              The plugin will change line's material 😞
              • C
                c.plassais
                Hello
                As requested Cadfather, I have added the possibility to colorize angles
                Edge by edge per click
                Edges connected to a face by clicking on the face
                All edges connected by double-clicking on face or edge
                [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
                Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                Christophe
                • CadFatherC
                  CadFather
                  thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
                  (really sketchup fun changing the colours 😛 )
                  if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
                    Jörg
                    Thank you Chris, this is amazing!!!!
                    I waited for the dottet lines for years!
                    Jörg
                    • DavidBoulderD
                      DavidBoulder
                      I trick for color by profile. Not very smooth, but if you have to tools it works nice.
                      • Work as normal in SketchUp
                      • Drop views into Layout
                      • Export from Layout as vector PDF
                      • Import into Adobe Illustrator
                      • Select "Final all lines with same width"
                      • You can now isolate them and color or alter as desired
                      note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
                      David
                      David Goldwasser
                      OpenStudio Developer
                      National Renewable Energy Laboratory
                        stefx
                        I use Mac and it looks like it doesn't work..... 😞
                        any tips?
                        stef.
                        • C
                          c.plassais
                          any tips?
                          stef.
                          Oops!
                          Sorry but I do not test on Mac.
                          cmeed uses the plugin successfully on Mac
                          can you send me a copy of the errors returned
                          Christophe
                            stefx
                            Hi Christophe,
                            I have solved the problem just restarting my Mac.
                            Sorry for the trouble,
                            Thank you for the amazing plugin!
                            stef.
                            • C
                              c.plassais
                              no problem
                              it suits me 😉
                              • C
                                c.plassais
                                Hi Everyone,
                                a new version ChrisP_ColorEdge 0.2.2
                                Adding the management layer
                                Draw an edge by layer, with a color of your choice or the color of the active layer.
                                Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                                Dotted lines by filtering by layer
                                Thank you to TIG for his plugin ListeLayerColors
                                [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                                Enjoy
                                Christophe
                                • C
                                  c.plassais
                                  Adding icons designed by Max (CadFather)
                                  Icons designed by max
                                  A big thank you max 👍
                                  Christophe
                                  • C
                                    c.plassais
                                    ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                                    404 Not Found
                                    (forums.sketchucation.com)
                                    Regards
                                    Christophe
                                    • Y
                                      yvan79
                                      good plugin to counter autoCAD colored edges....
                                        jsteacy
                                        Very cool, 😎
                                        • P
                                          plf10
                                          thank you for your share 💚
                                            dtrarch
                                            A gotta have script and just super for tracing over scan'd drawings and such.
                                            Thank you so very much. 😍
                                            Note that if one selects a color visually from materials it will be the default for the line tool color.
                                            Works well especially as on can sample on screen colors too this way for repeats.
                                            Cheers 😄
                                            dtr
                                            • 1 / 4
