    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 102.0k Views 35 Watching
    • DavidBoulderD
      DavidBoulder
      I trick for color by profile. Not very smooth, but if you have to tools it works nice.
      • Work as normal in SketchUp
      • Drop views into Layout
      • Export from Layout as vector PDF
      • Import into Adobe Illustrator
      • Select "Final all lines with same width"
      • You can now isolate them and color or alter as desired
      note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
      David
      David Goldwasser
      OpenStudio Developer
      National Renewable Energy Laboratory
        stefx
        I use Mac and it looks like it doesn't work..... ๐Ÿ˜ž
        any tips?
        stef.
        • C
          c.plassais
          any tips?
          stef.
          Oops!
          Sorry but I do not test on Mac.
          cmeed uses the plugin successfully on Mac
          can you send me a copy of the errors returned
          Christophe
            stefx
            Hi Christophe,
            I have solved the problem just restarting my Mac.
            Sorry for the trouble,
            Thank you for the amazing plugin!
            stef.
            • C
              c.plassais
              no problem
              it suits me ๐Ÿ˜‰
              • C
                c.plassais
                Hi Everyone,
                a new version ChrisP_ColorEdge 0.2.2
                Adding the management layer
                Draw an edge by layer, with a color of your choice or the color of the active layer.
                Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                Dotted lines by filtering by layer
                Thank you to TIG for his plugin ListeLayerColors
                [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                Enjoy
                Christophe
                • C
                  c.plassais
                  Adding icons designed by Max (CadFather)
                  Icons designed by max
                  A big thank you max ๐Ÿ‘
                  Christophe
                  • C
                    c.plassais
                    ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                    404 Not Found
                    (forums.sketchucation.com)
                    Regards
                    Christophe
                    • Y
                      yvan79
                      good plugin to counter autoCAD colored edges....
                        jsteacy
                        Very cool, ๐Ÿ˜Ž
                        • P
                          plf10
                          thank you for your share ๐Ÿ’š
                            dtrarch
                            A gotta have script and just super for tracing over scan'd drawings and such.
                            Thank you so very much. ๐Ÿ˜
                            Note that if one selects a color visually from materials it will be the default for the line tool color.
                            Works well especially as on can sample on screen colors too this way for repeats.
                            Cheers ๐Ÿ˜„
                            dtr
                              akigrimm
                              Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
                                JuanV.Soler
                                It is under ...VIEW __TOOLBARS ^`...Color Edge
                                • C
                                  c.plassais
                                  Thanks Juan ๐Ÿ‘
                                  • B
                                    Builder Boy
                                    Shade by 3 colors dosn't work for me ๐Ÿ˜ž Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS! ๐Ÿ˜
                                    All my plugins
                                      JuanV.Soler
                                      Yes,
                                      I donยดt understand the tool neither. Use it for lines, enough for me. Sorry.
                                      I have to investigate though I have the feeling that it is not tunned yet or updated.
                                      • C
                                        c.plassais
                                        This tool allows to colorize the edges on a same plane by a mixture of two basic colors depending on the angle and possibly a second plane and a third color
                                        • C
                                          c.plassais
                                          [flash=800,600:3blf0ado]http://content.screencast.com/users/c.plassais/folders/Jing/media/b2d1840e-dcf4-4c4f-a71b-8de7ea7e272c/blend.swf[/flash:3blf0ado]
                                            schnydix
                                            hello i would like tranlate this plugin to german but how ?
                                            And it is Possible to have a different line width.
                                            Thanks for the great work
                                            best-off@gmx.net
                                            • 2 / 4
