    [Plugin] ChrisP_ColorEdge
    67 Posts 35 Posters 103.3k Views 35 Watching
    • kenK
      ken
      Thanks for the plugin. Maybe I will be able to get the black screen drawing display.
      On another note, would it be possible to limit the color selection to just the basic colors.
      Again thank you for your plugin.
      Ken
      • C
        c.plassais
        Sorry if I dont understand everything I am a Frenchy and it is a real handicap 🤣
        I am newbie with English and ruby
        In response to your comments :
        Cadfather
        About protractor, the difficulty is the accuracy with the mouse to find the right angle with inference no problem. But I'll try.
        Colorize only corners no problem, it’s fairly easy and it's a good idea
        Cmeed
        What do you mean to colour by profile ?
        I see you using Mac, so no problem with the plugin apparently?
        Watkings
        no problem for use on the edges of a face.
        The only restriction is if you do a push pull on the face, must be weld segments and after dotted repeat
        The last icon is just for information, it is the color chart
        Ken
        I posted a "lite" version with only 8 basic colors
        Christophe
        • kenK
          ken
          Thank you for the very fast response and the plugin.
          Ken
          • MALAISEM
            MALAISE
            I was waiting for such a plugin for a while. Thanks a lot Chris for sharing
            Pierre
            • cmeedC
              cmeed
              Cmeed
              Not really the person to ask about crashes as I've only used it once but happily with great success. No crashes.
              heres what i was asking about in the pic - just profiles?
              • C
                c.plassais
                sorry but I dont think this is possible.
                profile changes with position camera.
                The plugin will change line's material 😞
                • C
                  c.plassais
                  Hello
                  As requested Cadfather, I have added the possibility to colorize angles
                  Edge by edge per click
                  Edges connected to a face by clicking on the face
                  All edges connected by double-clicking on face or edge
                  [flash=480,385:lzat1hz3]http://www.youtube.com/v/PUxgLBuwVa8&hl=fr_FR&fs=1&[/flash:lzat1hz3]
                  Download ➡ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                  Christophe
                  • CadFatherC
                    CadFather
                    thank you Chris.. love this script - i now have plan lines in green, elevations in blue and pink, makes intersecting 2d cad information easier
                    (really sketchup fun changing the colours 😛 )
                    if the snapping of the lines could be controlled this could be a great tool to draw strange plans at various angles
                      Jörg
                      Thank you Chris, this is amazing!!!!
                      I waited for the dottet lines for years!
                      Jörg
                      • DavidBoulderD
                        DavidBoulder
                        I trick for color by profile. Not very smooth, but if you have to tools it works nice.
                        • Work as normal in SketchUp
                        • Drop views into Layout
                        • Export from Layout as vector PDF
                        • Import into Adobe Illustrator
                        • Select "Final all lines with same width"
                        • You can now isolate them and color or alter as desired
                        note: If you have depth cue turned on in SketchUp this won't work as line widths will not all be the same.
                        David
                        David Goldwasser
                        OpenStudio Developer
                        National Renewable Energy Laboratory
                          stefx
                          I use Mac and it looks like it doesn't work..... 😞
                          any tips?
                          stef.
                          • C
                            c.plassais
                            any tips?
                            stef.
                            Oops!
                            Sorry but I do not test on Mac.
                            cmeed uses the plugin successfully on Mac
                            can you send me a copy of the errors returned
                            Christophe
                              stefx
                              Hi Christophe,
                              I have solved the problem just restarting my Mac.
                              Sorry for the trouble,
                              Thank you for the amazing plugin!
                              stef.
                              • C
                                c.plassais
                                no problem
                                it suits me 😉
                                • C
                                  c.plassais
                                  Hi Everyone,
                                  a new version ChrisP_ColorEdge 0.2.2
                                  Adding the management layer
                                  Draw an edge by layer, with a color of your choice or the color of the active layer.
                                  Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
                                  Dotted lines by filtering by layer
                                  Thank you to TIG for his plugin ListeLayerColors
                                  [flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
                                  Enjoy
                                  Christophe
                                  • C
                                    c.plassais
                                    Adding icons designed by Max (CadFather)
                                    Icons designed by max
                                    A big thank you max 👍
                                    Christophe
                                    • C
                                      c.plassais
                                      ****14/07/2010 Version 0.2.3 Fixed problem layer's observer
                                      Regards
                                      Christophe
                                      • Y
                                        yvan79
                                        good plugin to counter autoCAD colored edges....
                                          jsteacy
                                          Very cool, 😎
                                          • P
                                            plf10
                                            thank you for your share 💚
                                            • 1 / 4
