[Plugin] ChrisP_ColorEdge
Hi Everyone,
a new version ChrisP_ColorEdge 0.2.2
Adding the management layer
Draw an edge by layer, with a color of your choice or the color of the active layer.
Recolor the edges by filtering by layer, with a color of your choice or the color of the active layer.
Dotted lines by filtering by layer
Thank you to TIG for his plugin ListeLayerColors[flash=425,350:29yeejxt]http://www.youtube.com/v/GQ-DpoUOiTM[/flash:29yeejxt]
Enjoy
Christophe
****14/07/2010 Version 0.2.3 Fixed problem layer's observer
http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
Regards
Christophe
good plugin to counter autoCAD colored edges....
Very cool,
thank you for your share
A gotta have script and just super for tracing over scan'd drawings and such.
Thank you so very much.
Note that if one selects a color visually from materials it will be the default for the line tool color.
Works well especially as on can sample on screen colors too this way for repeats.
Cheers
dtr
Is there anything special about the installation. I can't see the plugin in SU . I unpacked to plugins and it created a folder and a rb file ChrisP_ColorEdge_EN. Anything else? I would be very happy when I could draw dotted lines.
It is under ...VIEW __TOOLBARS ^`...Color Edge
Thanks Juan
Shade by 3 colors dosn't work for me
Instead, it gives me the dialog, and when I click ok, NOTHING HAPPENS!
Yes,
I don´t understand the tool neither. Use it for lines, enough for me. Sorry.
I have to investigate though I have the feeling that it is not tunned yet or updated. -
This tool allows to colorize the edges on a same plane by a mixture of two basic colors depending on the angle and possibly a second plane and a third color -
hello i would like tranlate this plugin to german but how ?
And it is Possible to have a different line width.
Thanks for the great work
best-off@gmx.net -
Good evening,
for the width lines it's not possible.
I will soon publish a new version, including a Spanish version translated by Diego Rodriguez. The new version adds faces to the lines drawn.
Can work on inner edges are groups and components.
It is possible to include a German version. Here are the lines to translate$aa_01 = "Length " $aa_02 = "TAB to modify parameters " $aa_03 = "Select the end of the edge == TAB to modify colors " $aa_04 = "Color on axis X " $aa_05 = "Color on axis Y " $aa_06 = "Color on axis Z " $aa_07 = "Color 45 degree " $aa_08 = "Color other axix " $aa_09 = "Color single " $aa_10 = "Color " $aa_11 = "Select the start of the edge == TAB to modify colors " $aa_12 = "No color " $aa_13 = "No RGB" $aa_14 = "RGB " $aa_15 = "TAB to modify colors " $aa_16 = "By Layer " $aa_17 = "No selection, do you want apply\nthe operation to all entities? " $aa_18 = "Stippling " $aa_19 = "% or cm " $aa_20 = "Adapt length " $aa_21 = "Color 1 " $aa_22 = "Color 2 " $aa_23 = "There are several instances\nDo make unique instance?\nOtherwise the definition will be modified... " $aa_24 = "Angle length " $aa_25 = "Angle color " $aa_26 = "Edge color " $aa_27 = "ColorEdge " $aa_28 = "Draw Color Edge " $aa_29 = "Draw edge by color by vector " $aa_30 = "Edge single color on select " $aa_31 = "Edge color by axis on select " $aa_32 = "Modify select in dotted line " $aa_33 = "Color Edge by click " $aa_34 = "Dotted line by click " $aa_35 = "Colored angle by click " $aa_36 = "Colors blend " $aa_37 = "Color select " $aa_38 = "Colored angle " $aa_39 = "Dotted line" $aa_40 = "By default" $aa_41 = "Active layer" $aa_42 = "All" $aa_43 = "Delete" $aa_44 = "Color layer" $aa_45 = "Keep" $aa_46 = "Whithout" $aa_47 = "Invisible" $aa_48 = "Yes" $aa_49 = "No" $aa_50 = "Selection of colors to use" $aa_51 = "Valid and save" $aa_52 = "Valid" $aa_53 = "Uncheck all" $aa_54 = "Chech all" $aa_55 = "Cancel" $aa_56 = "Color choice " $aa_57 = "Add face " $aa_58 = "Inputbox setup " $aa_59 = "Inputbox setup..........................................You must before colors selected " $aa_60 = "Language choice " $aa_61 = "List chosen colors " $aa_62 = "Parameters " $aa_63 = "Yes|No"ChrisP
thanks i will check it out.
I am late to this party, as well, but so glad to be here.
Thank you so much, Christophe, for your generosity and delicious plugin.
I wish:
- it worked on groups as groups
- settings were remembered
- setting units respected those active in SU
- it worked on circles, arcs
Please see the image, which I hope explains my comments better.
In this case I'm really just looking for a consistent appearance for the perimeter edges.
Hi Chris, would you help me please? I colored some edges on my model, but now i want it all to go back to default.. How do i do it? Thanks
