    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 144.3k Views 50 Watching
    • E Offline
      ENG. YASEEN
      Wow It's working in SU Pro7 ..... That's Great 😍
      Thank u 👍
      Sculpt By SU Pro7
      My Website:
      http://xyz4studio.blogspot.com/
      • boofredlayB Offline
        boofredlay
        Is anybody using this in their work flow? If so how and to what success?
        I am surprised we have not seen a bunch of examples so far.
        • majidM Offline
          majid
          I am wondering that if it is possible to have a tool for adding detail , or even reducing the details, while keeping the surface smoothness (if it is a curved surface).
          maybe something like the picture
            Sandbox Tool->Add Details
            • troyhomeT Offline
              troyhome
              I wish sandbox did more thank only triangulation
              IOviz.com
              SU Pro 2024 PC
              • majidM Offline
                majid
                sand box is not so smart tohave i.e. .6 size, rectangles, it just triangulates
                  aea
                  Missing a tutorial to sculpt tools .
                    chakal82
                    I installed this plugin and ı tried to use push or bulge controls but nothing happens.I can see blue circle but when ı trried to click on the face nothing happens also when ı checked the ruby console there is no movement.
                    what will ı do? please help.
                      Dsmelcer1234
                      Can anyone get planar lock to work on su 7.1? I've tried every different way I can think of and nothing ever gets locked. Tried use, use + show, dont use, turned on every different option, drawn the three point horiz to the mesh, vertical to the mesh, put the three point plane in a the mesh component, exploded it, selected the mesh then drew the three points, draw the plane in the center of the mesh, on the edge, etc etc... Every time the tools move the vertices as if I never used planar lock. Any body got any ideas?
                        BTM
                        Planar lock is far from perfect, but the way it should work is that any vertices (points) that happen to sit on the same plane as the rectangle it draws are locked to that plane, and can move around on it but can't leave the plane.
                        On another note, I hope to start on a v.2 of sculpt tools some time in the next few months. v.1 was made just after I learned to code, and can be simplified an improved quite a bit; plus I never got around to adding the flatten or inflate features in the finished product.
                        • X Offline
                          xrok1
                          v2? nice to hear! 😄
                          • Bob JamesB Offline
                            Bob James
                            Bring it on 🎉
                              KXI System
                              Hey guys sorry to crash your party buuuuut.....
                              Its going wack in V8. Can anyone look into this?
                              Getting the perfect sig is hard...
                              Google it!
                                It'd help if you can be most specific to what happens. "going wack" could mean anything...
                                  BTM
                                  I haven't gotten around to testing it in su8 yet, sorry. One thing that might cause a problem is that I used the constant E without declaring which class it was part of. It worked in v.7, but in 8 it would have to be replaced with Math::E. If there are any other problems, feel free to let me know.
                                  As for a v.2 of sculpt tools, it still might come around, but I haven't been using sketchup that much recently. Unity 3 has been taking up a lot of my attention 😉
                                    stevenwoodhouse
                                    Thanks BTM 😄
                                      davecoopstl
                                      I concur...these tools (v1) do NOT currently work with SketchUp 8. Too bad, because they look amazing!
                                      • peter_shawP Offline
                                        peter_shaw
                                        can someone confirm that it doesnt work in SU8? because the plugin does load in SU8 for me, and you can manipulate meshes, but its really slow?! not sure if im using it wrong or if its not working, havent used it before..
                                        edit: ok i just saw this video http://www.screencast.com/t/FOl5w6XE , it defenitely doesnt work like this 😞
                                        • mitcorbM Offline
                                          mitcorb
                                          If you have downloaded the zip file and extracted it correctly, you should have a Folder [btm_Sculpt_Tools of 76.5kB] and a file [btm_Sculpt_Tools_Loader.rb] both located in your Sketchup 8 Plugins folder.
                                          I am having trouble with Winzip in my Windows 7 machine, so I simply copy pasted these two items from my Sketchup 7 Plugins folder.
                                          The attachment is a good faith attempt to show you it worked, but this is a Scene, not a screen capture, so I can't show you the icons toolbar. And it was very responsive. The mesh/grid was created on the top surface using the line tool and move/copy multiple in both x and y directions.
                                          EDIT: My copy of Sk8 is not fully loaded with all of the plugins I have collected through Sk7. So, I am just guessing some other plugin you have may be interfering? maybe not? or it is the problem with your original download and deploy?
                                            peter_shaw
                                            ok, i got it to work now! by deleting all my plugins and copying them again with a fresh download 😄
                                            • 3 / 5
