    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 144.3k Views 50 Watching
    • W Offline
      wsms
      thanks for everybody who build this plugin!
      i am just trying to sculpt something out~
      the only problem is the speed of my computer...
        BTM
        ok, I'm starting work on sculpt tools again; a new tool I'm probably going to add in the next release is flatten. I've got it working, but It's not finished yet.
        It flattens nearby points to the plane they best fit. If you hold shift, it will keep the previous plane, so you can create a flat surface. It has a setting which allows it to not affect points on the other side of the plane, so you can sculpt somewhat hard surfaces in the model, like in this image.
        ( though, with sketchup, it's admittedly not very useful)
        an 'icosphere', with flatten used in different places.
        I'll see if I can get an inflate/ deflate tool in the next release alswell.
        • X Offline
          xrok1
          SWEET!
          🀒 sorry got a little too excited 🀣
          • majidM Offline
            majid
            wowww it is unbelievable ...man... the only remaining thin is documenting the plugin... is there anyone here ,so experienced, to do that?
            • E Offline
              ENG. YASEEN
              Wow It's working in SU Pro7 ..... That's Great 😍
              Thank u πŸ‘
              Sculpt By SU Pro7
              My Website:
              http://xyz4studio.blogspot.com/
              • boofredlayB Offline
                boofredlay
                Is anybody using this in their work flow? If so how and to what success?
                I am surprised we have not seen a bunch of examples so far.
                • majidM Offline
                  majid
                  I am wondering that if it is possible to have a tool for adding detail , or even reducing the details, while keeping the surface smoothness (if it is a curved surface).
                  maybe something like the picture
                    Sandbox Tool->Add Details
                    • troyhomeT Offline
                      troyhome
                      I wish sandbox did more thank only triangulation
                      IOviz.com
                      SU Pro 2024 PC
                      • majidM Offline
                        majid
                        sand box is not so smart tohave i.e. .6 size, rectangles, it just triangulates
                          aea
                          Missing a tutorial to sculpt tools .
                            chakal82
                            I installed this plugin and Δ± tried to use push or bulge controls but nothing happens.I can see blue circle but when Δ± trried to click on the face nothing happens also when Δ± checked the ruby console there is no movement.
                            what will Δ± do? please help.
                              Dsmelcer1234
                              Can anyone get planar lock to work on su 7.1? I've tried every different way I can think of and nothing ever gets locked. Tried use, use + show, dont use, turned on every different option, drawn the three point horiz to the mesh, vertical to the mesh, put the three point plane in a the mesh component, exploded it, selected the mesh then drew the three points, draw the plane in the center of the mesh, on the edge, etc etc... Every time the tools move the vertices as if I never used planar lock. Any body got any ideas?
                                BTM
                                Planar lock is far from perfect, but the way it should work is that any vertices (points) that happen to sit on the same plane as the rectangle it draws are locked to that plane, and can move around on it but can't leave the plane.
                                On another note, I hope to start on a v.2 of sculpt tools some time in the next few months. v.1 was made just after I learned to code, and can be simplified an improved quite a bit; plus I never got around to adding the flatten or inflate features in the finished product.
                                • X Offline
                                  xrok1
                                  v2? nice to hear! πŸ˜„
                                  • Bob JamesB Offline
                                    Bob James
                                    Bring it on πŸŽ‰
                                      KXI System
                                      Hey guys sorry to crash your party buuuuut.....
                                      Its going wack in V8. Can anyone look into this?
                                      Getting the perfect sig is hard...
                                      Google it!
                                        It'd help if you can be most specific to what happens. "going wack" could mean anything...
                                          BTM
                                          I haven't gotten around to testing it in su8 yet, sorry. One thing that might cause a problem is that I used the constant E without declaring which class it was part of. It worked in v.7, but in 8 it would have to be replaced with Math::E. If there are any other problems, feel free to let me know.
                                          As for a v.2 of sculpt tools, it still might come around, but I haven't been using sketchup that much recently. Unity 3 has been taking up a lot of my attention πŸ˜‰
                                            stevenwoodhouse
                                            Thanks BTM πŸ˜„
                                            • 3 / 5
