    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 130.9k Views 50 Watching
    • mitcorbM Offline
      mitcorb
      I would like to repeat an earlier post:
      [Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.] Meaning I could not get it to work.
      mitcorb
        BTM
        mitcorb
        It's not a visual cue. It's a feature to allow sculpting even if there's a lot of lag; when you sculpt, it will affect not only the vertices around the cursor, but also around the line between the cursor and the last cursor position:
        You can draw fast with lagline on.
        • mitcorbM Offline
          mitcorb
          Thanks -BTM:
          I think I understand what you mean.
          As for drawing fast, that would be when I get a new desktop system. My current machine has a Pentium 4 with 1.6Ghz.
          • W Offline
            wsms
            thanks for everybody who build this plugin!
            i am just trying to sculpt something out~
            the only problem is the speed of my computer...
              BTM
              ok, I'm starting work on sculpt tools again; a new tool I'm probably going to add in the next release is flatten. I've got it working, but It's not finished yet.
              It flattens nearby points to the plane they best fit. If you hold shift, it will keep the previous plane, so you can create a flat surface. It has a setting which allows it to not affect points on the other side of the plane, so you can sculpt somewhat hard surfaces in the model, like in this image.
              ( though, with sketchup, it's admittedly not very useful)
              an 'icosphere', with flatten used in different places.
              I'll see if I can get an inflate/ deflate tool in the next release alswell.
              • X Offline
                xrok1
                SWEET!
                🤢 sorry got a little too excited 🤣
                • majidM Offline
                  majid
                  wowww it is unbelievable ...man... the only remaining thin is documenting the plugin... is there anyone here ,so experienced, to do that?
                  • E Offline
                    ENG. YASEEN
                    Wow It's working in SU Pro7 ..... That's Great 😍
                    Thank u 👍
                    Sculpt By SU Pro7
                    My Website:
                    http://xyz4studio.blogspot.com/
                    • boofredlayB Offline
                      boofredlay
                      Is anybody using this in their work flow? If so how and to what success?
                      I am surprised we have not seen a bunch of examples so far.
                      • majidM Offline
                        majid
                        I am wondering that if it is possible to have a tool for adding detail , or even reducing the details, while keeping the surface smoothness (if it is a curved surface).
                        maybe something like the picture
                          Sandbox Tool->Add Details
                            troyhome
                            I wish sandbox did more thank only triangulation
                            IOviz.com
                            SU Pro 2024 PC
                            • majidM Offline
                              majid
                              sand box is not so smart tohave i.e. .6 size, rectangles, it just triangulates
                                aea
                                Missing a tutorial to sculpt tools .
                                  chakal82
                                  I installed this plugin and ı tried to use push or bulge controls but nothing happens.I can see blue circle but when ı trried to click on the face nothing happens also when ı checked the ruby console there is no movement.
                                  what will ı do? please help.
                                    Dsmelcer1234
                                    Can anyone get planar lock to work on su 7.1? I've tried every different way I can think of and nothing ever gets locked. Tried use, use + show, dont use, turned on every different option, drawn the three point horiz to the mesh, vertical to the mesh, put the three point plane in a the mesh component, exploded it, selected the mesh then drew the three points, draw the plane in the center of the mesh, on the edge, etc etc... Every time the tools move the vertices as if I never used planar lock. Any body got any ideas?
                                      BTM
                                      Planar lock is far from perfect, but the way it should work is that any vertices (points) that happen to sit on the same plane as the rectangle it draws are locked to that plane, and can move around on it but can't leave the plane.
                                      On another note, I hope to start on a v.2 of sculpt tools some time in the next few months. v.1 was made just after I learned to code, and can be simplified an improved quite a bit; plus I never got around to adding the flatten or inflate features in the finished product.
                                      • X Offline
                                        xrok1
                                        v2? nice to hear! 😄
                                        • Bob JamesB Offline
                                          Bob James
                                          Bring it on 🎉
                                            KXI System
                                            Hey guys sorry to crash your party buuuuut.....
                                            Its going wack in V8. Can anyone look into this?
                                            Getting the perfect sig is hard...
                                            Google it!
                                            • 3 / 5
