    [Plugin] Sculpt Tools v 1.0...
    100 Posts 51 Posters 146.8k Views 50 Watching
    • C
      CPhillips
      Welcome back BTM! Awsome plugin.
      • mitcorbM
        mitcorb
        I would like to repeat an earlier post:
        [Question-- Is the "lagline" setting in the dialog a selection of a visual cue? If it is, I have not seen it.] Meaning I could not get it to work.
        mitcorb
        • B
          BTM
          mitcorb
          It's not a visual cue. It's a feature to allow sculpting even if there's a lot of lag; when you sculpt, it will affect not only the vertices around the cursor, but also around the line between the cursor and the last cursor position:
          You can draw fast with lagline on.
          • mitcorbM
            mitcorb
            Thanks -BTM:
            I think I understand what you mean.
            As for drawing fast, that would be when I get a new desktop system. My current machine has a Pentium 4 with 1.6Ghz.
            • W
              wsms
              thanks for everybody who build this plugin!
              i am just trying to sculpt something out~
              the only problem is the speed of my computer...
              • B
                BTM
                ok, I'm starting work on sculpt tools again; a new tool I'm probably going to add in the next release is flatten. I've got it working, but It's not finished yet.
                It flattens nearby points to the plane they best fit. If you hold shift, it will keep the previous plane, so you can create a flat surface. It has a setting which allows it to not affect points on the other side of the plane, so you can sculpt somewhat hard surfaces in the model, like in this image.
                ( though, with sketchup, it's admittedly not very useful)
                an 'icosphere', with flatten used in different places.
                I'll see if I can get an inflate/ deflate tool in the next release alswell.
                • X
                  xrok1
                  SWEET!
                  🤢 sorry got a little too excited 🤣
                  • majidM
                    majid
                    wowww it is unbelievable ...man... the only remaining thin is documenting the plugin... is there anyone here ,so experienced, to do that?
                    • E
                      ENG. YASEEN
                      Wow It's working in SU Pro7 ..... That's Great 😍
                      Thank u 👍
                      Sculpt By SU Pro7
                      My Website:
                      http://xyz4studio.blogspot.com/
                      • boofredlayB
                        boofredlay
                        Is anybody using this in their work flow? If so how and to what success?
                        I am surprised we have not seen a bunch of examples so far.
                        • majidM
                          majid
                          I am wondering that if it is possible to have a tool for adding detail , or even reducing the details, while keeping the surface smoothness (if it is a curved surface).
                          maybe something like the picture
                            Sandbox Tool->Add Details
                            • troyhomeT
                              troyhome
                              I wish sandbox did more thank only triangulation
                              IOviz.com
                              SU Pro 2024 PC
                              • majidM
                                majid
                                sand box is not so smart tohave i.e. .6 size, rectangles, it just triangulates
                                  aea
                                  Missing a tutorial to sculpt tools .
                                  • C
                                    chakal82
                                    I installed this plugin and ı tried to use push or bulge controls but nothing happens.I can see blue circle but when ı trried to click on the face nothing happens also when ı checked the ruby console there is no movement.
                                    what will ı do? please help.
                                      Dsmelcer1234
                                      Can anyone get planar lock to work on su 7.1? I've tried every different way I can think of and nothing ever gets locked. Tried use, use + show, dont use, turned on every different option, drawn the three point horiz to the mesh, vertical to the mesh, put the three point plane in a the mesh component, exploded it, selected the mesh then drew the three points, draw the plane in the center of the mesh, on the edge, etc etc... Every time the tools move the vertices as if I never used planar lock. Any body got any ideas?
                                      • B
                                        BTM
                                        Planar lock is far from perfect, but the way it should work is that any vertices (points) that happen to sit on the same plane as the rectangle it draws are locked to that plane, and can move around on it but can't leave the plane.
                                        On another note, I hope to start on a v.2 of sculpt tools some time in the next few months. v.1 was made just after I learned to code, and can be simplified an improved quite a bit; plus I never got around to adding the flatten or inflate features in the finished product.
                                        • X
                                          xrok1
                                          v2? nice to hear! 😄
                                          • Bob JamesB
                                            Bob James
                                            Bring it on 🎉
                                            • 3 / 5
