    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      tak2hata
      @paulower said:
      This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
      Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
      You can see who is running smoothly letters with accents and numerical symbols.
      Thanks paulowr.
      I add language list on first thread.
      I will increase the size of Buttons in next version.
      @stu said:
      Ive been using fur for a while ...with good results, and just loving it!! πŸ‘
      However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
      Hi , Stu.
      That happens in small value of "MaxNumber(/Face)" for the faces.
      You should increase "MaxNumber(/Face)" enough.
      Thanks.
      by TAK2HATA
        Stu
        Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
        http://www.landesign.com.au
          tomot
          Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
          See my RAND code snippet below.
          if( $type == "Random + " )
              group=entities.add_group
              entities=group.entities
              1.upto($vpanes) do |i|
                x = ($vtile*i)+(i*$space)
                1.upto($hpanes) do |j|
          	    y = ($htile*j)+(j*$space)
          	o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
              pt1 = o.offset($hVec, -$htile)
          	pt2 = o.offset($vVec, -$vtile)
          	pt3 = pt1.offset($vVec, -$vtile)
          	#entities.add_cpoint o
          	#entities.add_cpoint pt1
          	#entities.add_cpoint pt2
          	#entities.add_cpoint pt3
              face = entities.add_face o, pt1, pt3, pt2
              face.pushpull -($tthick+rand(20))
          end #if
          cheers!
          my plugins
          tomot
            tak2hata
            Hi,all.
            I update this to version1.4b.
            >       end
            >     end
            > end #if
            cheers!
            Thanks tomot.
            But this plugin created preset file.
            If I add new parameter, compatible with the old one is difficult for me.
            If you want to use random size to component instance, please use crowd(webdialog).
            and change value of "size jitter" as you like.
            Thanks.
            by TAK2HATA
              Mauhaus
              Hi guys,
              I lost my dwg-import option after installing the plugin. Any ideas why this happened?
              /Thomas 😞
                Hi Thomas,
                re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
                  Mauhaus
                  Hi Gaieus
                  Thanx for replying 😎
                  Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
                  /Thomas
                    SuperSized
                    In the spirit of the SA World Cup.... nice plugin
                    • FrederikF Offline
                      Frederik
                      I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
                      You need a seperate plugin...
                      Please check out the DWG/DXF import plugin for SketchUp 7.1 (Free)...
                      Cheers
                      Kim Frederik
                      • H Offline
                        hebeijianke
                        A Chinese translation.
                        Thanks to you all !
                        fur_lang_cn.txt
                          @mauhaus said:
                          Yes, I have been running 7 (7.1.6859) **PRO**for some time now. The dwg-import option disappeared after installing it...
                          That would only be the free version Kim. The pro still has the "native" import option.
                          As you are not supposed to be able to install the free version on top of the pro, there can indeed be some problem.
                          However we are going off-topic here so Thomas, after you see my post here, I will split these posts and move the new topic created this way to the SketchUp Discussions > Bug reports subforum.
                          However you could try to reinstall your SU but really make sure to download the Pro version (again) to install it. Also, for the Mac version there was also a maintenance release after the main release of 7.1. A couple of fixes were made there so best is to go for sure...
                          • F Offline
                            frv
                            TX for the great plugin, I love the idea of the crowedmaker.
                            But under OSX it does not work, the dialog panel is empty for the crowed option.
                            Francois
                            • mariochaM Offline
                              mariocha
                              @frv said:
                              ....., I love the idea of the crowedmaker.
                              Francois
                              Yep, same here. No dialog under MacOX (10.6.3) πŸ˜•
                              %(#008000)[Mario C.
                                Masoncrowell
                                can someone tell me how i do this on a mac?
                                i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? πŸ˜•
                                  tak2hata
                                  Francois
                                  Hi,Francois and Mario.
                                  It is very regrettable.
                                  I will examine way for working on mac.
                                  This file is compressed by zip.
                                  First, You should extract this file with folder.
                                  It includes
                                  --fur_en.rb
                                  --fur_en(folder include icon images)
                                  and copy created files to plugins folder.
                                  Read here.
                                  http://sketchup.google.com/intl/en/download/rubyscripts.html
                                  Thanks.
                                  by TAK2HATA
                                    ktslambieng
                                    this is this is a new : vietnam translation for fur1.4b
                                    Thanks you for all !
                                    http://farm2.static.flickr.com/1273/4676700265_23fc0faee3_b.jpg
                                    fur_lang_vn14b.txt
                                    • F Offline
                                      frv
                                      TX Tak,
                                      hope you find the time to look into the blanc dialog for crowds.
                                      I love your idea to specialise the furmaker for crowds
                                      Francois
                                        That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
                                        http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&p=248300#p248300
                                        But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
                                        Oli: are you using the latest version?
                                          ❓ what happened to Oli's post..?
                                            michaelhsu
                                            amazing, thanks.
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 32
                                            • 33
                                            • 15 / 33
