    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
    • Didier BurD Offline
      Didier Bur
      Got this error when using "make crowd" without having a "fur_instance" component in my model:
      Error: #<TypeError: wrong argument type (expected Sketchup::ComponentDefinition)>
      C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1272:in `add_instance'
      I guess the script does not check wether the relevant component is in the model or not ? πŸ’­
      It works OK if a "fur_instance" component is present.
      After deleting the fur instance component, hit "CheckOnAll", and it is still there, and the makecrowd doesn't work anymore if I let its checkbox ticked.
      DB
        Stu
        Ive been using fur for a while ...with good results, and just loving it!! πŸ‘
        However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
        http://www.landesign.com.au
          tak2hata
          @paulower said:
          This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
          Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
          You can see who is running smoothly letters with accents and numerical symbols.
          Thanks paulowr.
          I add language list on first thread.
          I will increase the size of Buttons in next version.
          Hi , Stu.
          That happens in small value of "MaxNumber(/Face)" for the faces.
          You should increase "MaxNumber(/Face)" enough.
          Thanks.
          by TAK2HATA
            Stu
            Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
              tomot
              Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
              See my RAND code snippet below.
              if( $type == "Random + " )
                  group=entities.add_group
                  entities=group.entities
                  1.upto($vpanes) do |i|
                    x = ($vtile*i)+(i*$space)
                    1.upto($hpanes) do |j|
              	    y = ($htile*j)+(j*$space)
              	o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
                  pt1 = o.offset($hVec, -$htile)
              	pt2 = o.offset($vVec, -$vtile)
              	pt3 = pt1.offset($vVec, -$vtile)
              	#entities.add_cpoint o
              	#entities.add_cpoint pt1
              	#entities.add_cpoint pt2
              	#entities.add_cpoint pt3
                  face = entities.add_face o, pt1, pt3, pt2
                  face.pushpull -($tthick+rand(20))
              end #if
              cheers!
              my plugins
              tomot
                tak2hata
                Hi,all.
                I update this to version1.4b.
                >       end
                >     end
                > end #if
                cheers!
                Thanks tomot.
                But this plugin created preset file.
                If I add new parameter, compatible with the old one is difficult for me.
                If you want to use random size to component instance, please use crowd(webdialog).
                and change value of "size jitter" as you like.
                Thanks.
                by TAK2HATA
                  Mauhaus
                  Hi guys,
                  I lost my dwg-import option after installing the plugin. Any ideas why this happened?
                  /Thomas 😞
                    Hi Thomas,
                    re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
                      Mauhaus
                      Hi Gaieus
                      Thanx for replying 😎
                      Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
                      /Thomas
                        SuperSized
                        In the spirit of the SA World Cup.... nice plugin
                        • FrederikF Offline
                          Frederik
                          I'm sure the install was made properly, however, the dwg/dxf import has been excluded from ver. 7.1 and onwards...
                          You need a seperate plugin...
                          Please check out the DWG/DXF import plugin for SketchUp 7.1 (Free)...
                          Cheers
                          Kim Frederik
                          • H Offline
                            hebeijianke
                            A Chinese translation.
                            Thanks to you all !
                            fur_lang_cn.txt
                              @mauhaus said:
                              Yes, I have been running 7 (7.1.6859) **PRO**for some time now. The dwg-import option disappeared after installing it...
                              That would only be the free version Kim. The pro still has the "native" import option.
                              As you are not supposed to be able to install the free version on top of the pro, there can indeed be some problem.
                              However we are going off-topic here so Thomas, after you see my post here, I will split these posts and move the new topic created this way to the SketchUp Discussions > Bug reports subforum.
                              However you could try to reinstall your SU but really make sure to download the Pro version (again) to install it. Also, for the Mac version there was also a maintenance release after the main release of 7.1. A couple of fixes were made there so best is to go for sure...
                              • F Offline
                                frv
                                TX for the great plugin, I love the idea of the crowedmaker.
                                But under OSX it does not work, the dialog panel is empty for the crowed option.
                                Francois
                                • mariochaM Offline
                                  mariocha
                                  @frv said:
                                  ....., I love the idea of the crowedmaker.
                                  Francois
                                  Yep, same here. No dialog under MacOX (10.6.3) πŸ˜•
                                  %(#008000)[Mario C.
                                    Masoncrowell
                                    can someone tell me how i do this on a mac?
                                    i downloaded the file and updated my version of sketchup. the file only shows up in my downloads and i can't open it with sketchup. i also enabled my plugins menu on sketchup and the only option that shows up is a "cost" option. How do i do this? πŸ˜•
                                      tak2hata
                                      Francois
                                      Hi,Francois and Mario.
                                      It is very regrettable.
                                      I will examine way for working on mac.
                                      This file is compressed by zip.
                                      First, You should extract this file with folder.
                                      It includes
                                      --fur_en.rb
                                      --fur_en(folder include icon images)
                                      and copy created files to plugins folder.
                                      Read here.
                                      http://sketchup.google.com/intl/en/download/rubyscripts.html
                                      Thanks.
                                      by TAK2HATA
                                        ktslambieng
                                        this is this is a new : vietnam translation for fur1.4b
                                        Thanks you for all !
                                        http://farm2.static.flickr.com/1273/4676700265_23fc0faee3_b.jpg
                                        fur_lang_vn14b.txt
                                        • F Offline
                                          frv
                                          TX Tak,
                                          hope you find the time to look into the blanc dialog for crowds.
                                          I love your idea to specialise the furmaker for crowds
                                          Francois
                                            That is due to some oddness in Geom::Transformation.scaling which I mentioned earlier.
                                            http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&p=248300#p248300
                                            But tak2hata said later he's swapped to use .scaling(a,a,a) isntead of .scaling(a) - so that should have taken care of it. Unless there is something else that also creates this scenario.
                                            Oli: are you using the latest version?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 32
                                            • 33
                                            • 15 / 33
