    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • Didier BurD
      Didier Bur
      Does anyone know what can be done to adress this error?
      After taking a look at the code, line 541 has something to do with "Direction (X)" Y and Z factors.
      Yours are undefined (nil), so check your values in the dialog box and try to change them with something else than zero and see if it works. Check your decimal "," or "." too.
      Hope this helps,
      DB
        jaceguay
        Thanks for the fast response, changing the values return another error:
        Error: #<TypeError: no implicit conversion to float from nil>
        C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in new'
        C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:852:in show_webdialog' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:792:in call'
          jonorman
          same problem here. after installing last version..
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
          buuuuhuuuuu... miss my fur/grass plugin 😒
          • T
            tak2hata
            I uploaded version1.4.
            Change is...
            Remember webdialog position.(Thanks thomthom πŸ˜„ )
            Add new mode "Crowd".(Multi Instance scattering.)
            In this version ,I changed convert string to length method little.
            When that error is happened , I want look your dialog parameter.
            I think problem is around "s_to_l" method.
            @thiloo said:
            thanks tak2hata for the quick explanation,
            wow, thatΒ΄s also an powerful feature.
            sadly itΒ΄s not working if I choose "make by component - yes"!
            also, with component activated, the reaction to the force settings are quite unexpected?
            [attachment=0:367xbin3]<!-- ia0 -->fur_force.jpg<!-- ia0 -->[/attachment:367xbin3]
            I need the components for instancing -> rendering.
            again, Thank You for your time and effort
            "make by component -- yes" was added after making this plugin.
            This plugin originaly use for "make by component -- no".
            I do not have good way to componentinstance direction control.
            When I find good way,I will change it.
            Thanks.
            by TAK2HATA
              sloof
              how to use this ?
              somebody help me please ?
                jonorman
                screen dump of SU trying to use fur.
                • T
                  tak2hata
                  Hi,jonorman.
                  I updated version 1.4a.
                  Sorry,I forgat changing "s_to_l".
                  now it changed.
                  It may be work.
                  by TAK2HATA
                  • T
                    tak2hata
                    @sloof said:
                    how to use this ?
                    Hi,sloof.
                    http://forums.sketchucation.com/viewtopic.php?f=323&t=28092
                    [url=http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html:1j014hsy]http://sketchupdate.blogspot.com/[/url:1j014hsy]
                    It may help.
                    Thanks.
                    by TAK2HATA
                      jonorman
                      JIPPIIIIII ! ! ! ! Back in bizzniz 😍 πŸ‘ β˜€
                      • T
                        tomot
                        WOW! .....another great Plugin,
                        This pampas grass looks better that the real stuff in my planter πŸ˜„
                        Thanks! tak2hata
                        my plugins
                        tomot
                        • Didier BurD
                          Didier Bur
                          Got this error when using "make crowd" without having a "fur_instance" component in my model:
                          Error: #<TypeError: wrong argument type (expected Sketchup::ComponentDefinition)>
                          C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1272:in `add_instance'
                          I guess the script does not check wether the relevant component is in the model or not ? πŸ’­
                          It works OK if a "fur_instance" component is present.
                          After deleting the fur instance component, hit "CheckOnAll", and it is still there, and the makecrowd doesn't work anymore if I let its checkbox ticked.
                          DB
                            Stu
                            Ive been using fur for a while ...with good results, and just loving it!! πŸ‘
                            However I've struck a problem as in the attached....it seems to be the cut off angle that is upsetting the geometry.....if I try a square or rectangular plane it behaves normally.
                            http://www.landesign.com.au
                            • T
                              tak2hata
                              @paulower said:
                              This is the translation of Make Fur to languaje Portuguese-BR (Brazil) by me.
                              Tak2hata would be possible in the next version, you increase the size of the buttons "Assign Material to" and "Get Stuff From." Is that in Portuguese, we have more characters in the translation and some letters may not appear on the icon (button).
                              You can see who is running smoothly letters with accents and numerical symbols.
                              Thanks paulowr.
                              I add language list on first thread.
                              I will increase the size of Buttons in next version.
                              Hi , Stu.
                              That happens in small value of "MaxNumber(/Face)" for the faces.
                              You should increase "MaxNumber(/Face)" enough.
                              Thanks.
                              by TAK2HATA
                                Stu
                                Thanks Tak2hata, I boosted it up to 12,000!! and its fine now
                                • T
                                  tomot
                                  Tak2hata I was wondering if you had considered including a random fur height function? I'm currently creating a random height tile/block/city generator... which is not finished yet.
                                  See my RAND code snippet below.
                                  if( $type == "Random + " )
                                      group=entities.add_group
                                      entities=group.entities
                                      1.upto($vpanes) do |i|
                                        x = ($vtile*i)+(i*$space)
                                        1.upto($hpanes) do |j|
                                  	    y = ($htile*j)+(j*$space)
                                  	o = $pt3.offset($hVec, y - $space).offset($vVec, x - $space)
                                      pt1 = o.offset($hVec, -$htile)
                                  	pt2 = o.offset($vVec, -$vtile)
                                  	pt3 = pt1.offset($vVec, -$vtile)
                                  	#entities.add_cpoint o
                                  	#entities.add_cpoint pt1
                                  	#entities.add_cpoint pt2
                                  	#entities.add_cpoint pt3
                                      face = entities.add_face o, pt1, pt3, pt2
                                      face.pushpull -($tthick+rand(20))
                                  end #if
                                  cheers!
                                  my plugins
                                  tomot
                                  • T
                                    tak2hata
                                    Hi,all.
                                    I update this to version1.4b.
                                    >       end
                                    >     end
                                    > end #if
                                    cheers!
                                    Thanks tomot.
                                    But this plugin created preset file.
                                    If I add new parameter, compatible with the old one is difficult for me.
                                    If you want to use random size to component instance, please use crowd(webdialog).
                                    and change value of "size jitter" as you like.
                                    Thanks.
                                    by TAK2HATA
                                      Mauhaus
                                      Hi guys,
                                      I lost my dwg-import option after installing the plugin. Any ideas why this happened?
                                      /Thomas 😞
                                      • GaieusG
                                        Hi Thomas,
                                        re you sure you did not upgrade from SketchUp 7.0 to 7.1 (free) lately?
                                          Mauhaus
                                          Hi Gaieus
                                          Thanx for replying 😎
                                          Yes, I have been running 7 (7.1.6859) PRO for some time now. The dwg-import option disappeared after installing it. Maybe I didn't install it properly?
                                          /Thomas
                                            SuperSized
                                            In the spirit of the SA World Cup.... nice plugin
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 32
                                            • 33
                                            • 15 / 33
