    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      tald311
      Thank you. This is great.
        Click Draw
        Been playin'....this is very cool! I hope PETA doesn't get wind of this 🤣
        Thanks very much for this!!!
        Jeff
        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
          realist
          Hi, I'm new to Sketchup and about to climb the learning curve.
          I saw the Fur plugin and thought it would be a cool additon to Sketchup. I clicked on the link to download it but all that does is refresh the page. It doesn't download anything. Am I missing something here? Thanks.Gary
            JollyFather
            Thanks a lot!!!
            Best regards,
            JF
              paulower
              Hello Tak2hata.
              I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
              Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. 😄
              Any chance this feature soon?
              Hi,all.
              I updated this plugin to version1.3i.
                Webdialog sees easier.(Thanks Diego.)
                Parameter name translates by langage text file.
              Thanks.
              If you wish, I can provide the translation from Portuguese languaje from Make Fur
              http://i910.photobucket.com/albums/ac301/bausketchup/MakeFUR1.jpg
              http://i910.photobucket.com/albums/ac301/bausketchup/makefur2.jpg
              _______________________________
              My Blog
              Baú SketchUp
              Baú SketchUp
              Visite nosso blog.. Visit our blog Baú SketchUp
                thiloo
                thank you so much, I already love this Plugin!
                some question:
                • what´s the "Valid Distance" for?
                  if I choose "make by Component: no"
                  and enter something different than 0,000m it´s not working.
                  if I choose "make by Component: yes"
                  it´s working, but seems to have no effect.
                • Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
                  tak2hata
                  Hi, thiloo.
                  @thiloo said:
                  some question:
                  The Valid Distance is validate fur about distance from camera.
                  So This value is large.like 20m.
                  But 0 make all valid.it do not omits fur.
                  Example.Use valid distance = 8000mm.
                  About Fur_Valid Distance1
                  About Fur_Valid Distance2
                  About Fur_Valid Distance3
                  Hi,paulower.
                  Sorry ,Now I examines the method to remember dialog position.
                  That demands the javascript knowledge from me.
                  I will update few day later.
                  Thanks.
                  by TAK2HATA
                    autarchos
                    Dear Mr. Paulo Wer:
                    That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                    Besten Grüßen,
                    Drazen Petrovic
                      thiloo
                      thanks tak2hata for the quick explanation,
                      wow, that´s also an powerful feature.
                      sadly it´s not working if I choose "make by component - yes"!
                      also, with component activated, the reaction to the force settings are quite unexpected?
                      I need the components for instancing -> rendering.
                      again, Thank You for your time and effort
                        I see the same issue that thiloo describes.
                          Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
                          http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
                            bryan_gibson79
                            As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
                            BG
                              autarchos
                              Didier's Hide Faces/Edges plug-in is one method:
                              http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
                              BG
                              • marleusM Offline
                                marleus
                                Really cool plugin
                                thanks a lot 👍 👍
                                Markus Sillander
                                Vantaa, Finland
                                I'm on FormFonts now
                                http://www.formfonts.com
                                • N Offline
                                  notareal
                                  It still amaze me what this plugin can do
                                  Perhaps later styling with hair guides? Like in Max or Blender. Not that it have to be so extensive, but in a spirit of those.
                                  Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                    paulower
                                    @autarchos said:
                                    Dear Mr. Paulo Wer: That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                                    Besten Grüßen,
                                    Drazen Petrovic
                                    Yes, sure I can explain:
                                    1 - I created a normal plane in SketchUp and used the Sandbox tool SketchUp to create the topography of the land;
                                    2 - I used two maps (two textures) of different grass. A grass that is normal, and the other is like a bush (do not know how to say it in English).
                                    • Do not forget to apply the texture on both sides, ie, in the back and front face.
                                    **3 -**Create a component for each texture (one for the grass normal and other to grass bush);
                                    **4 -**In the Settings Window FUR, I made the adjustments and settings required, such as:
                                    • TopJitter (%): 1
                                    • Direction (X): 0mm
                                    • Direction (Y): 0mm
                                    • Direction (Z): 500m or 5000m (not mm. That in my example)
                                    • In the menu drop down "Make by Component", choose the component that you created;
                                    5 - Click on Make Fur;
                                    **6 -**I did the render in V-Ray for SketchUp. In V-Ray only applied the map Alpha in Diffuse;
                                    I still do not know for sure the function of all commands, but recommend you do the tests in Make FUR. If you want the maps are on the links below:
                                    File - Map Alpha Mask
                                    File - Map Grass
                                    My Blog
                                    Baú SketchUp
                                    Baú SketchUp
                                      paulower: that's a nice setup. Thanks for sharing.
                                        No need for javasscript to remember the window's position. SU does this for you if you specify a preference key.
                                        http://code.google.com/apis/sketchup/docs/ourdoc/webdialog.html#new
                                        pref_key
                                        The registry entry where the location and size of the dialog will be saved. If preferences_key is not included, the location and size will not be stored.
                                          jaceguay
                                          Nothing happend when i click make fur, the ruby console show this:
                                          Error: #<TypeError: no implicit conversion to float from nil>
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in initialize' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in new'
                                          C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:541:in fur_inputbox' C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561 C:/Program Files/Google/Google SketchUp 7/Plugins/fur_en.rb:1561:in call'
                                          Does anyone know what can be done to adress this error?
                                            jeabdc
                                            ThankY ขอบคุณมากครับ
                                            • 32
                                            • 33
                                            • 1 / 33
