    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • Didier BurD
      Didier Bur
      V1.3L not working either: no error message, no fur, nothing happens 😲
      EDIT: it works if I switch the model units to inches. There's definitely something wrong with unit management.
      Doesn't work if I set "root width" to "0,5" but works with "1,1", same goes with "length" parameter, so I think that
      the problem that "-50mm".to_l.to_s turn to "~ -0'"
      is not fixed yet.
      DB
      • FletchF
        Fletch
        @massimo said:
        Fletch, your leaves are not overlaping! how did you achieve that?
        Perhaps he deleted some overlapping components later? 😉
        Glad you like it... I do too! 😄
        No. I deleted nothing.
        There are 12 new leaves we made (free) for licensed users of Twilight... available here.... along with a video tutorial and the practice scene.
        Twilight Render also has no problems exporting these 2400 leaf instances in this image (took about 1sec. to process the file) and they render perfectly.
        The "secret" to not overlapping is that the leaf component is made to be at approx. 15 degree angle away from the face, the way they grow.
        But yes, the sizes and angle should perhaps be "jittered" or "changed" a bit more... it was just a quick test. 😉
        Fletch
        • T
          tak2hata
          Hi,all.
          I update to verison1.3m.
          It changes LengthPrecision temporary.
          So using units "m" has no problem , now.(perhaps).
          Thanks.
          by TAK2HATA
          • GaieusG
            Yes, this is working, thank tak2hata!
            I can make fur again
            (now just exploring all the settings...)
            • JClementsJ
              JClements
              Gaieus: That's Shaga-delic.
                saturne45
                Hello, very great job... make fur is very nice. thank you.
                • T
                  tald311
                  Thank you. This is great.
                  • C
                    Click Draw
                    Been playin'....this is very cool! I hope PETA doesn't get wind of this 🤣
                    Thanks very much for this!!!
                    Jeff
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                      realist
                      Hi, I'm new to Sketchup and about to climb the learning curve.
                      I saw the Fur plugin and thought it would be a cool additon to Sketchup. I clicked on the link to download it but all that does is refresh the page. It doesn't download anything. Am I missing something here? Thanks.Gary
                        JollyFather
                        Thanks a lot!!!
                        Best regards,
                        JF
                        • P
                          paulower
                          Hello Tak2hata.
                          I have spoken these days about the plugin, which is one of the best I've seen so far for our dear SketchUp.
                          Is there a way the dialog can remember it's position on the screen? I always expect it to reopen where I put it the previous time. 😄
                          Any chance this feature soon?
                          Hi,all.
                          I updated this plugin to version1.3i.
                            Webdialog sees easier.(Thanks Diego.)
                            Parameter name translates by langage text file.
                          Thanks.
                          If you wish, I can provide the translation from Portuguese languaje from Make Fur
                          http://i910.photobucket.com/albums/ac301/bausketchup/MakeFUR1.jpg
                          http://i910.photobucket.com/albums/ac301/bausketchup/makefur2.jpg
                          _______________________________
                          My Blog
                          Baú SketchUp
                          Baú SketchUp
                          Visite nosso blog.. Visit our blog Baú SketchUp
                          • T
                            thiloo
                            thank you so much, I already love this Plugin!
                            some question:
                            • what´s the "Valid Distance" for?
                              if I choose "make by Component: no"
                              and enter something different than 0,000m it´s not working.
                              if I choose "make by Component: yes"
                              it´s working, but seems to have no effect.
                            • Also, if I select "make by Component: yes" the results are looking quite different from when I select no". for example: the force values seem to have stronger impact on component:yes.
                            • T
                              tak2hata
                              Hi, thiloo.
                              @thiloo said:
                              some question:
                              The Valid Distance is validate fur about distance from camera.
                              So This value is large.like 20m.
                              But 0 make all valid.it do not omits fur.
                              Example.Use valid distance = 8000mm.
                              About Fur_Valid Distance1
                              About Fur_Valid Distance2
                              About Fur_Valid Distance3
                              Hi,paulower.
                              Sorry ,Now I examines the method to remember dialog position.
                              That demands the javascript knowledge from me.
                              I will update few day later.
                              Thanks.
                              by TAK2HATA
                                autarchos
                                Dear Mr. Paulo Wer:
                                That is some fantastically lush and beautiful grass you have created! What is the probability that you would like to share your technique and component/material with the fur-worshipping masses?
                                Besten Grüßen,
                                Drazen Petrovic
                                • T
                                  thiloo
                                  thanks tak2hata for the quick explanation,
                                  wow, that´s also an powerful feature.
                                  sadly it´s not working if I choose "make by component - yes"!
                                  also, with component activated, the reaction to the force settings are quite unexpected?
                                  I need the components for instancing -> rendering.
                                  again, Thank You for your time and effort
                                    I see the same issue that thiloo describes.
                                      Hehe - even the Googlers play around with this: http://sketchupdate.blogspot.com/2010/05/having-spent-last-three-hours-fiddling.html
                                      http://3.bp.blogspot.com/_mDRU50FpD-E/TAALyG_ckXI/AAAAAAAAAMI/geNk8IzxF7Y/s400/WithFur.png
                                      • B
                                        bryan_gibson79
                                        As a user of Sketchup from its inception all i can say is WOW! about this plug-in. I gotta quick question though...Is there any easy way to hide all the linework on the blades of grass in sketchup with out rendering and without turning off all linework in the model? When you get alot it all turns black due to the linework. Anyone have any ideas?
                                        BG
                                          autarchos
                                          Didier's Hide Faces/Edges plug-in is one method:
                                          http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/hide_faces_edges.rb
                                          BG
                                          • marleusM
                                            marleus
                                            Really cool plugin
                                            thanks a lot 👍 👍
                                            Markus Sillander
                                            Vantaa, Finland
                                            I'm on FormFonts now
                                            http://www.formfonts.com
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 32
                                            • 33
                                            • 13 / 33
