    Extrude profile to profile
    17 Posts 7 Posters 1.8k Views 7 Watching
      arcano
      Hi to all !
      I need a plug in for my project. I must extrude my profile to another profile over (see the attachment below) but i need that sketchup do it automatically for precision reason.
      Some months ago I've seen someting like that.
      Someone help me ?
      Thanks ! 😉
        You could try this....
        404 Not Found
        (forums.sketchucation.com)
        Or this....
        404 Not Found
        Or soon we'll have this, but not yet....
        404 Not Found
        • numbthumbN
          numbthumb
          If those profiles are identical in shape, but not in size, you can simply push/pull the larger one to the desired height, and then scale its upper face uniformly about the center.
          Comfortably numb...
            arcano
            No, the profile are no identical.
            I've tried with blend 1.12 and I've found an error.
            How can I make this with ExtrudeTools - Zipped Set ???
              dedmin
              Post the SketchUp's file.
                You can use EEbyFace with a single edge curve as the rail, or EEbyRails ditto... Capture.PNGor EEbyLoft to make a Bezier between them...Capture1.PNG
                  2 faces + Path? by Kirill2008
                  • numbthumbN
                    numbthumb
                    No disrespect intended, but couldn´t you just push/pull that and scale the upper face subsequently? Those faces are the same shape, right? Am I missing something?
                    Comfortably numb...
                      arcano
                      @rclub
                      Thank you very much for exhaustive explanation!
                      @Tig
                      great plug in you rule guy !
                        Yes you can - unless one profile is not quite the same "shape"... 😕
                          arcano
                          Bingo!
                          • numbthumbN
                            numbthumb
                            Yeah, that is what confuses me - I was sure arcano´s profiles were the same shape, only different in size.
                            Anyway, some practice with your extrude tools won´t hurt - they are indispensable, especially when it comes to creating complex shapes.
                            Comfortably numb...
                              @arcano said:
                              @rclub
                              don't thank me as all I've learnt I gotten here and continue to learn more everyday. For most problems there's many approaches so everyone has given good pointers.
                              Have a good one 👍
                              Rich
                                Slimdog
                                Rich wrote:
                                "If you wan to know why i 'Divided' the line before welding read this"
                                I would like to know why you divided the line before welding. The link you give is to the smustard site and I see no answer for the question there.
                                Cheers
                                S
                                  404 Not Found
                                    TIG's example are exactly what you need and unfortunately he beat me to the punch but here's a little info anyway....
                                    The faces we need to join....
                                    Adding extra geometry to help create shape....
                                    Delete unwanted faces....
                                    Delete unwanted geometry....
                                    Using 'Weld' plugin to create polylines....
                                    You'll find the 'Weld' plugin here
                                    Using EEbyR to create Mesh....
                                    Final shape
                                    This shape could have easily been created using EEbyFaces with a lot less click but this might help you understand how the Extrude Toolset works.
                                    Post your models if you can or if your stuck!
                                      I think he meant "how" [to get 'weld.rb'], not "why" [he divided the edge before welding its parts]...
                                      To use the EEby... tools [and others] any profiles/rails/etc need to be 'curves' - that is any collection of edges that have been made into a 'polyline' [in CAD-terms] - or a 'curve' in SUp-speak - SUp's arcs etc are naturally 'curves' - Bezier curves etc made with Fredo's tools are also this type of 'curve' - BUT any edges joined end-to-end [with no branching] can be made into such a 'curve' - even if there is no apparent 'curviness' in it at all 😕
                                      The tool to make these edges into a 'curve' is weld.rb. However, you can only 'weld' two or more edges into a curve, if you have just the one edge then it can't become a curve that way - therefore select the lone edge, right-click context-menu > divide it [i.e. 2 or more - if it's to match a 'paired' curve as a profile/rail/etc then it's recommended that you divide it to have a matching number of segments], it will remains highlighted [but it's now in bits], immediately weld those selected bits into a curve...
                                      You are now ready for he next step...
