    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • TIGT Online
      Sorry Simon 😳 , but I've been a bit preoccupied lately... it is quite easy to do this and I am thinking of including an option with EEbyRails to allow you to keep only the Rail-paths, Profile-paths or Rail+Profile-paths... OR I might just make the 'pipe-dream' ExtrudeEdgesToLattice tool... That would do what you want... but also perhaps let you apply a lattice to the untriangulated mesh's faces - using an desired offset from each face's edges and also PushPulled up/down by desired amount[s] too...
      I am very 'bogged down' at the moment but I AM thinking about it...
      • simon le bonS Offline
        simon le bon
        Thank you TIG for your word, I feel better now.
        What you are planning is very exciting .
        πŸ‘
        πŸ‘ πŸ‘
        It is now going to be hard to wait for.
        you are the
        http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/gnie.gif
        of this place.
        πŸ˜‰ simon
          Landie
          Thankyou for sharing. 😍
          http://www.smithdimes.co.uk
          • TIGT Online
            New updated set available here... http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
            Brand new tool ExtrudeEdgesByRailsToLattice added.
            [It has basic EN-US/FR/ES lingvo files...] http://forums.sketchucation.com/viewtopic.php?p=242239#p242239
            Replacement ES lingvo files for all tools included [from Defisto]; and some new FA lingvo files for some tools added [through Majid] - Thanks to them! πŸ˜„
            Minor adjustments:
            EEbyEdges tool now exits gracefully.
            A few scripts have had the missing "require 'deBableizer.rb'" added.
            RickW's ' offset.rb' method-only script is now included in the set - because it's needed by EEbyRailsToLattice...
            πŸ€“
            • mitcorbM Offline
              mitcorb
              Again, TIG:
              Thank you for your talents and contributions.
              • W Offline
                watkins
                Dear TIG,
                You appear to be using version 1.0 of offset.rb. There is a later version, V2.1 (see the attached). Is it okay to use the later version with your scripts?
                Regards,
                Bob
                offset.rb
                • TIGT Online
                  @watkins said:
                  Dear TIG,
                  Regards,
                  Bob
                  Don't know how I'm still using that old one !
                  Finger on the pulse, and all that.... πŸ˜’
                  Anyway... it doesn't matter, v1 or v2.1 both work fine when I've tested...
                  I'll package the new version with any future updates...
                  Meanwhile, if users already have the newer version then I recommend that they don't overwrite it with the older zipped one until the zipped update catches up...
                  Sorry for any confusion...
                  • TIGT Online
                    Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                    EEbyRailsToLattice has been updated with the latest version of 'offset.rb' and trapped to rescue its 'fails', also some glitches with display of selected curves etc is fixed...
                    πŸ€“
                    • TIGT Online
                      I have reissued a new version again today http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      The single change is a temporarily fixed offset.rb [awaiting its author's input, RickW ]...
                      After I updated from offset.rb v1 to v2.1 in my zipped set earlier today, I discovered that it had then broken RickW's own Windowizer4.rb πŸ˜’ .
                      None of this affects my tools - they only need the Face::offset() method !
                      In this tweaked version I have included the older Array::offset() AND the newer Array::offsetPoints() methods found in offset.rb v1 AND v2.1 respectively; and so it should now work with Windowizer4.rb and also any tools that might rely on the newer version...
                      πŸ˜•
                      • TIGT Online
                        Here's another version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        An updated FR lingvo for EEbyRailsToLattice - a compilation of Pilou and Didier's suggestions/corrections
                        [note that "accents" are not used in text within the inputbox dialogs to avoid problems...]
                        Thanks...
                          doy
                          thumbs up....this is hot...thanks a lot for sharing
                          • TIGT Online
                            Here is today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            EEbyRailsToLattice has some new /updated lingvo files, minor text corrections and flat faces at z=0 are now auto-reversed. See it's thread for more info...
                            πŸ€“
                            • TIGT Online
                              Here is an updated zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              EEbyRailsToLattice is updated to give back faces of panes the color too and the panes' 'face.offset' method no longer relies on 3rd party offset.rb - it has been incorporated into the class-methods and made more robust.
                                Works fine now πŸ‘
                                  gavvy
                                  😲 TO Tig ,I can't say anymore πŸ‘
                                  • TIGT Online
                                    Here is an updated set.
                                    EEbyRailsToLattice now also has a 'Diagonals' option for the Lines...
                                    Reverse the order of picking the rails to swap the diagonals' direction.
                                    Make two diagonal groups overlaid to get a 'diamond mesh' etc...
                                    The lingvo files have be updated to match.
                                    • TIGT Online
                                      Here's a new zipped set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      EEbyRailsToLattice has been updated to fix glitches with the Line work lattices' grouping - which affected all types, but was only noticed when the 'diagonal' option was added...
                                      • W Offline
                                        watkins
                                        Dear TIG,
                                        Does one still need offset.rb? I notice that it is missing from the zipped folder.
                                        Regards,
                                        Bob
                                        • TIGT Online
                                          Bob
                                          No, as was explained in earlier release notes, to avoid the problems with newer versions of offset's incompatibility with Windowizer etc I changed the way EEbyRailsToLattice makes its lattice offsets by building the method into the code in a slightly different way...
                                          You can use any version of offset.rb you want - it is no longer needed by my tools... πŸ˜„
                                            leixing
                                            Thanks TIG.
                                            great work
                                            • 31
                                            • 32
                                            • 7 / 32
