    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      email or make a post in the gallery. I'm always curious to see what you produce.
      • GaieusG
        Hi Thom,
        There is an "unwanted" feature in this plugin (I do not necessarily want to call it a "bug"); it erases coplanar edges also when that edge divides faces where the same material applied but positioned differently. See screenshots attached.
        Highlighted dividing, coplanar edge
        After running the plugin
        Could there be at least a settingthat prevents this? I was making an arched surface for this vault when I first discovered this - it simply erased all the dividing edges and of course screwed up the arch big time.
        Thanks for looking into this issue - this is the best ever cleanup script I have ever encountered. aybe abother wish - could there be a feature/setting to clean up only whatever is in context (like inside a goup) and/or in a certain selection?
        Or maybe I missed something?
          hmm... Yes - I see how this can be an issue. Will need to ponder on how to avoid this though.
          Yea - the UI is horrible.
          • GaieusG
            Hm. Can I have another (older?) version?
              No - I seem to have extra menu items from working on v1.2.0 oopsie
              • GaieusG
                ๐Ÿ˜†
                I tried to lock such faces with positioned materials but the script erases lines in locked groups, too! ๐Ÿ˜ฎ
                  That's interesting. Another thing to note down.
                    Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances.
                    Highly recommended update!
                      ๐Ÿ˜ž Turns out it's not 100%. In one of my test model it still left some edges that could be erased.
                      Updated with some minor UI fixes.
                      • EscapeArtistE
                        EscapeArtist
                        "The selected attachment does not exist anymore"
                        Error when clicking for download.
                          You probably tried to download just as I uploaded a quick patch. ๐Ÿ˜ณ
                          • CadFatherC
                            CadFather
                            Thanks Thom, this is good.
                            • EscapeArtistE
                              EscapeArtist
                              Ah, timing is everything. Works just fine. Thanks!
                                MtnTrails
                                ๐Ÿ‘ Thank you, Thom! Works just like I'd hoped. What a great time saver!
                                -Brian
                                Keep doing what you're doing and you'll keep getting what you're getting.
                                • GaieusG
                                  Hi Thom,
                                  Thanks for the update. I'll definitely try it out (I managed to forget about two coplanar faces with differently positioned but the same texture again and screwed up my model - no big hassle though just a "doh" moment again...)
                                  ๐Ÿ˜„
                                    @gaieus said:
                                    Hi Thom,
                                    ๐Ÿ˜„
                                    Ah yes - I'm still not sure how to account for that. But it is possible ... somehow...
                                      Hi Thom,
                                      Thanks for the update, one of my favourite plugins.
                                      Doesnt say much about my modelling ability!
                                        Important update in 1.2.2
                                        Sorry for all these updates recently.
                                        I think I found the root of why the last update wasn't 100%.
                                        It now erases edges as they are processes, instead of in bulk later. This is because each face's plane equations must be re-evaluated after it's been merged. This might lead to slightly longer processing time - but I now hope that it truly is 100% watertight.
                                        • EarthMoverE
                                          EarthMover
                                          Thanks for the update. I use this puppy all the time! ๐Ÿ‘
                                          Content Creator at Skapeup
                                            Jim
                                            Thanks - it is doing better job of removing edges. I am willing to trade a little extra time for a cleaner model.
                                            I did get a reference to a deleted Edge error on this model (.stl import.) I haven't investigated the cause, but I've attached it in case you're curious.
                                            Error: #<TypeError: reference to deleted Edge> C:\Program Files\Google\Google SketchUp 7\Plugins\tt_cleanup.rb:283:infaces'`
                                            My fix:
                                            283: next unless e.valid? and e.is_a?(Sketchup::Edge)
                                            But is doesn't explain the cause.
                                            moai.skp
                                            • 48
                                            • 49
                                            • 6 / 49
