    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      @gaieus said:
      There is an "unwanted" feature in this plugin (I do not necessarily want to call it a "bug"); it erases coplanar edges also when that edge divides faces where the same material applied but positioned differently. See screenshots attached.
      hmm... Yes - I see how this can be an issue. Will need to ponder on how to avoid this though.
      @gaieus said:
      Thanks for looking into this issue - this is the best ever cleanup script I have ever encountered. aybe abother wish - could there be a feature/setting to clean up only whatever is in context (like inside a goup) and/or in a certain selection?
      Or maybe I missed something?
      Yea - the UI is horrible.
      • GaieusG
        Hm. Can I have another (older?) version?
          No - I seem to have extra menu items from working on v1.2.0 oopsie
          • GaieusG
            ๐Ÿ˜†
            I tried to lock such faces with positioned materials but the script erases lines in locked groups, too! ๐Ÿ˜ฎ
              That's interesting. Another thing to note down.
                Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances.
                Highly recommended update!
                  ๐Ÿ˜ž Turns out it's not 100%. In one of my test model it still left some edges that could be erased.
                  Updated with some minor UI fixes.
                  • EscapeArtistE
                    EscapeArtist
                    "The selected attachment does not exist anymore"
                    Error when clicking for download.
                      You probably tried to download just as I uploaded a quick patch. ๐Ÿ˜ณ
                      • CadFatherC
                        CadFather
                        Thanks Thom, this is good.
                        • EscapeArtistE
                          EscapeArtist
                          Ah, timing is everything. Works just fine. Thanks!
                            MtnTrails
                            ๐Ÿ‘ Thank you, Thom! Works just like I'd hoped. What a great time saver!
                            -Brian
                            Keep doing what you're doing and you'll keep getting what you're getting.
                            • GaieusG
                              Hi Thom,
                              Thanks for the update. I'll definitely try it out (I managed to forget about two coplanar faces with differently positioned but the same texture again and screwed up my model - no big hassle though just a "doh" moment again...)
                              ๐Ÿ˜„
                                @gaieus said:
                                Hi Thom,
                                ๐Ÿ˜„
                                Ah yes - I'm still not sure how to account for that. But it is possible ... somehow...
                                  Hi Thom,
                                  Thanks for the update, one of my favourite plugins.
                                  Doesnt say much about my modelling ability!
                                    Important update in 1.2.2
                                    Sorry for all these updates recently.
                                    I think I found the root of why the last update wasn't 100%.
                                    It now erases edges as they are processes, instead of in bulk later. This is because each face's plane equations must be re-evaluated after it's been merged. This might lead to slightly longer processing time - but I now hope that it truly is 100% watertight.
                                    • EarthMoverE
                                      EarthMover
                                      Thanks for the update. I use this puppy all the time! ๐Ÿ‘
                                      Content Creator at Skapeup
                                        Jim
                                        Thanks - it is doing better job of removing edges. I am willing to trade a little extra time for a cleaner model.
                                        I did get a reference to a deleted Edge error on this model (.stl import.) I haven't investigated the cause, but I've attached it in case you're curious.
                                        Error: #<TypeError: reference to deleted Edge> C:\Program Files\Google\Google SketchUp 7\Plugins\tt_cleanup.rb:283:infaces'`
                                        My fix:
                                        283: next unless e.valid? and e.is_a?(Sketchup::Edge)
                                        But is doesn't explain the cause.
                                        moai.skp
                                          hm.. that is odd. I wonder why that happens. thanks for posting the model.
                                            Updated to account for the issue reported by Jim.
                                            Though I still don't understand why I ever get a reference to a deleted edge...
                                            • 48
                                            • 49
                                            • 6 / 49
