    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Well, the office is making more and more Revit models. And importing them into SU is a workflow nightmare. So I'm very tempted to get Max into my office toolkit. ...so who knows... ๐Ÿ˜‰
      Btw, got any new renders to show off?
      • free agentF
        free agent
        please contact me when u take the plunge into maxscript, im sure its easier, definitly a bigger user base, do it do it do it!!!
        i got a couple, should i email? ๐Ÿ˜›
        http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
          email or make a post in the gallery. I'm always curious to see what you produce.
          • GaieusG
            Hi Thom,
            There is an "unwanted" feature in this plugin (I do not necessarily want to call it a "bug"); it erases coplanar edges also when that edge divides faces where the same material applied but positioned differently. See screenshots attached.
            Highlighted dividing, coplanar edge
            After running the plugin
            Could there be at least a settingthat prevents this? I was making an arched surface for this vault when I first discovered this - it simply erased all the dividing edges and of course screwed up the arch big time.
            Thanks for looking into this issue - this is the best ever cleanup script I have ever encountered. aybe abother wish - could there be a feature/setting to clean up only whatever is in context (like inside a goup) and/or in a certain selection?
            Or maybe I missed something?
              hmm... Yes - I see how this can be an issue. Will need to ponder on how to avoid this though.
              Yea - the UI is horrible.
              • GaieusG
                Hm. Can I have another (older?) version?
                  No - I seem to have extra menu items from working on v1.2.0 oopsie
                  • GaieusG
                    ๐Ÿ˜†
                    I tried to lock such faces with positioned materials but the script erases lines in locked groups, too! ๐Ÿ˜ฎ
                      That's interesting. Another thing to note down.
                        Armed with more info from Simone Nicolo I now have a better method for detecting coplanar faces - the same method Sketchup use. I think it's 100% reliable. No more messing about with tolerances.
                        Highly recommended update!
                          ๐Ÿ˜ž Turns out it's not 100%. In one of my test model it still left some edges that could be erased.
                          Updated with some minor UI fixes.
                          • EscapeArtistE
                            EscapeArtist
                            "The selected attachment does not exist anymore"
                            Error when clicking for download.
                              You probably tried to download just as I uploaded a quick patch. ๐Ÿ˜ณ
                              • CadFatherC
                                CadFather
                                Thanks Thom, this is good.
                                • EscapeArtistE
                                  EscapeArtist
                                  Ah, timing is everything. Works just fine. Thanks!
                                    MtnTrails
                                    ๐Ÿ‘ Thank you, Thom! Works just like I'd hoped. What a great time saver!
                                    -Brian
                                    Keep doing what you're doing and you'll keep getting what you're getting.
                                    • GaieusG
                                      Hi Thom,
                                      Thanks for the update. I'll definitely try it out (I managed to forget about two coplanar faces with differently positioned but the same texture again and screwed up my model - no big hassle though just a "doh" moment again...)
                                      ๐Ÿ˜„
                                        @gaieus said:
                                        Hi Thom,
                                        ๐Ÿ˜„
                                        Ah yes - I'm still not sure how to account for that. But it is possible ... somehow...
                                          Hi Thom,
                                          Thanks for the update, one of my favourite plugins.
                                          Doesnt say much about my modelling ability!
                                            Important update in 1.2.2
                                            Sorry for all these updates recently.
                                            I think I found the root of why the last update wasn't 100%.
                                            It now erases edges as they are processes, instead of in bulk later. This is because each face's plane equations must be re-evaluated after it's been merged. This might lead to slightly longer processing time - but I now hope that it truly is 100% watertight.
                                            • 48
                                            • 49
                                            • 6 / 49
