    New 2.5D+ tree set is now available...
    31 Posts 16 Posters 10.8k Views 16 Watching
    • T
      theark
      It's a great tree.That's right for render.Nice.Thank you. ๐Ÿ˜ฎ
      • bazB
        baz
        thanks tom, how about a eucalypt some time for us aussies, (although I understand they are fairly common in california.)
        baz
          red_shift
          Trying to figure out how to make these trees render properly in Maxwell or the new Thea Render. They render perfectly in Twilight, but not in MR or Thea. Anyone else tried?
          • N
            notareal
            Have you reported this yet on SU2TH bugs?
            • T
              tomsdesk
              Oli, I've just heard Thea is having troubles with png's in general and a fix is in the works...also there is a separate issue with SU's material editor changes in transparency and color, which my trees rely on heavily to work as well as they do. Sure hope this gets resolved!
              2.5D Trees & Shrubs!
              • N
                notareal
                There is no "troubles with png's in general" that I know. As a format png do work just fine. But there is a workflow issue with alpha stored to png - that should be fixed soon. Actually a automatic filling of the clip channel from png alpha did work in some point, but was turned off because of a bug. It's quite critical feature to get back due popularity of 2D entourage. There is a manual workaround to use alpha from png, but it cannot be a permanent solution to this issue. Also there is a separate issue with alpha map and halos - it's been worked on. There is a manual fix for that too, just let me know if you need a help with it.
                  red_shift
                  I did find a workaround. I first turn off the shadow layer of Tom's trees in SU. Then, in Thea studio I set the clipping texture to the alpha image (enabling clipping and setting channel to Alpha rather than RGB). I also find that in scattering that I need to set the Index of Refraction to 1 rather to 1.5.
                  • T
                    tomsdesk
                    Oli...I am sooooo happy to hear this! Have fun!
                    • soloS
                      Tom, they work in Thea, just had to adjust the transparency in SU before export.
                      Straight Thea output with Bloom and vignetting, no post processing.
                      http://img705.imageshack.us/img705/5797/tomnprthea.jpg
                      • T
                        tomsdesk
                        Well, I'm happy...thanks a bunch, Pete!
                        • broomstickB
                          broomstick
                          Thank you very muche, great models ๐Ÿ˜„
                            red_shift
                            Pete: you didn't have to do anything additional in Thea? What kind of transparency adjustment in SU?
                            • soloS
                              I eliminated all transparency values in SU, in Thea I clicked to enable the clip, and used the texture as a clipmap making sure it was alpha and not RGB.
                                red_shift
                                Similar to my approach mentioned above. I'm glad these work in Thea.
                                • B
                                  buk2noy
                                  sir, thank you! ๐ŸŽ‰
                                  seeking for peace of mind
                                  • T
                                    tallbridgeguy
                                    TBG
                                    Nielsen
                                    http://www.tallbridgeguy.com/
                                      stevebo
                                      Oldish topic but just want to say thank you Tom ๐Ÿ˜„. I promised I would buy it, bit late but I did ๐Ÿ˜„. They look great!
                                      Edit: Some quick tests on Vray
                                      http://img.photobucket.com/albums/v644/stevebo37/1-8.jpg
                                      http://img.photobucket.com/albums/v644/stevebo37/2-6.jpg
                                      • 2 / 2
