    New 2.5D+ tree set is now available...
    31 Posts 16 Posters 10.2k Views 16 Watching
    • EdsonE Offline
      Edson
      thanks, tom. i really appreciate it! i am sure other people will find these tall, skinny trees very helpful.
      http://www.mahfuz.arq.br
        marne
        Thank you Tom again!
          matteo
          Tom,
          they are superb! I do love your work.
          hire me: http://www.nonsolo3d.it/ !
            theark
            It's a great tree.That's right for render.Nice.Thank you. 😮
            • bazB Offline
              baz
              thanks tom, how about a eucalypt some time for us aussies, (although I understand they are fairly common in california.)
              baz
                red_shift
                Trying to figure out how to make these trees render properly in Maxwell or the new Thea Render. They render perfectly in Twilight, but not in MR or Thea. Anyone else tried?
                • N Offline
                  notareal
                  Have you reported this yet on SU2TH bugs?
                    tomsdesk
                    Oli, I've just heard Thea is having troubles with png's in general and a fix is in the works...also there is a separate issue with SU's material editor changes in transparency and color, which my trees rely on heavily to work as well as they do. Sure hope this gets resolved!
                    2.5D Trees & Shrubs!
                    • N Offline
                      notareal
                      There is no "troubles with png's in general" that I know. As a format png do work just fine. But there is a workflow issue with alpha stored to png - that should be fixed soon. Actually a automatic filling of the clip channel from png alpha did work in some point, but was turned off because of a bug. It's quite critical feature to get back due popularity of 2D entourage. There is a manual workaround to use alpha from png, but it cannot be a permanent solution to this issue. Also there is a separate issue with alpha map and halos - it's been worked on. There is a manual fix for that too, just let me know if you need a help with it.
                        red_shift
                        I did find a workaround. I first turn off the shadow layer of Tom's trees in SU. Then, in Thea studio I set the clipping texture to the alpha image (enabling clipping and setting channel to Alpha rather than RGB). I also find that in scattering that I need to set the Index of Refraction to 1 rather to 1.5.
                          tomsdesk
                          Oli...I am sooooo happy to hear this! Have fun!
                          • soloS Offline
                            Tom, they work in Thea, just had to adjust the transparency in SU before export.
                            Straight Thea output with Bloom and vignetting, no post processing.
                            http://img705.imageshack.us/img705/5797/tomnprthea.jpg
                              tomsdesk
                              Well, I'm happy...thanks a bunch, Pete!
                              • broomstickB Offline
                                broomstick
                                Thank you very muche, great models 😄
                                  red_shift
                                  Pete: you didn't have to do anything additional in Thea? What kind of transparency adjustment in SU?
                                  • soloS Offline
                                    I eliminated all transparency values in SU, in Thea I clicked to enable the clip, and used the texture as a clipmap making sure it was alpha and not RGB.
                                      red_shift
                                      Similar to my approach mentioned above. I'm glad these work in Thea.
                                        buk2noy
                                        sir, thank you! 🎉
                                        seeking for peace of mind
                                          tallbridgeguy
                                          TBG
                                          Nielsen
                                          http://www.tallbridgeguy.com/
                                            stevebo
                                            Oldish topic but just want to say thank you Tom 😄. I promised I would buy it, bit late but I did 😄. They look great!
                                            Edit: Some quick tests on Vray
                                            http://img.photobucket.com/albums/v644/stevebo37/1-8.jpg
                                            http://img.photobucket.com/albums/v644/stevebo37/2-6.jpg
                                            • 2 / 2
