    New 2.5D+ tree set is now available...
    31 Posts 16 Posters 10.1k Views 16 Watching
    • N Offline
      notareal
      @red_shift said:
      Trying to figure out how to make these trees render properly in Maxwell or the new Thea Render. They render perfectly in Twilight, but not in MR or Thea. Anyone else tried?
      Have you reported this yet on SU2TH bugs?
        tomsdesk
        Oli, I've just heard Thea is having troubles with png's in general and a fix is in the works...also there is a separate issue with SU's material editor changes in transparency and color, which my trees rely on heavily to work as well as they do. Sure hope this gets resolved!
        2.5D Trees & Shrubs!
        • N Offline
          notareal
          There is no "troubles with png's in general" that I know. As a format png do work just fine. But there is a workflow issue with alpha stored to png - that should be fixed soon. Actually a automatic filling of the clip channel from png alpha did work in some point, but was turned off because of a bug. It's quite critical feature to get back due popularity of 2D entourage. There is a manual workaround to use alpha from png, but it cannot be a permanent solution to this issue. Also there is a separate issue with alpha map and halos - it's been worked on. There is a manual fix for that too, just let me know if you need a help with it.
            red_shift
            I did find a workaround. I first turn off the shadow layer of Tom's trees in SU. Then, in Thea studio I set the clipping texture to the alpha image (enabling clipping and setting channel to Alpha rather than RGB). I also find that in scattering that I need to set the Index of Refraction to 1 rather to 1.5.
              tomsdesk
              Oli...I am sooooo happy to hear this! Have fun!
              • soloS Offline
                Tom, they work in Thea, just had to adjust the transparency in SU before export.
                Straight Thea output with Bloom and vignetting, no post processing.
                http://img705.imageshack.us/img705/5797/tomnprthea.jpg
                  tomsdesk
                  Well, I'm happy...thanks a bunch, Pete!
                  • broomstickB Offline
                    broomstick
                    Thank you very muche, great models πŸ˜„
                      red_shift
                      Pete: you didn't have to do anything additional in Thea? What kind of transparency adjustment in SU?
                      • soloS Offline
                        I eliminated all transparency values in SU, in Thea I clicked to enable the clip, and used the texture as a clipmap making sure it was alpha and not RGB.
                          red_shift
                          Similar to my approach mentioned above. I'm glad these work in Thea.
                            buk2noy
                            sir, thank you! πŸŽ‰
                            seeking for peace of mind
                              tallbridgeguy
                              TBG
                              Nielsen
                              http://www.tallbridgeguy.com/
                                stevebo
                                Oldish topic but just want to say thank you Tom πŸ˜„. I promised I would buy it, bit late but I did πŸ˜„. They look great!
                                Edit: Some quick tests on Vray
                                http://img.photobucket.com/albums/v644/stevebo37/1-8.jpg
                                http://img.photobucket.com/albums/v644/stevebo37/2-6.jpg
                                • 2 / 2
