    New 2.5D+ tree set is now available...
    31 Posts 16 Posters 9.8k Views 16 Watching
      tomsdesk
      Oli, I've just heard Thea is having troubles with png's in general and a fix is in the works...also there is a separate issue with SU's material editor changes in transparency and color, which my trees rely on heavily to work as well as they do. Sure hope this gets resolved!
      2.5D Trees & Shrubs!
      • N Offline
        notareal
        There is no "troubles with png's in general" that I know. As a format png do work just fine. But there is a workflow issue with alpha stored to png - that should be fixed soon. Actually a automatic filling of the clip channel from png alpha did work in some point, but was turned off because of a bug. It's quite critical feature to get back due popularity of 2D entourage. There is a manual workaround to use alpha from png, but it cannot be a permanent solution to this issue. Also there is a separate issue with alpha map and halos - it's been worked on. There is a manual fix for that too, just let me know if you need a help with it.
        Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
          red_shift
          I did find a workaround. I first turn off the shadow layer of Tom's trees in SU. Then, in Thea studio I set the clipping texture to the alpha image (enabling clipping and setting channel to Alpha rather than RGB). I also find that in scattering that I need to set the Index of Refraction to 1 rather to 1.5.
            tomsdesk
            Oli...I am sooooo happy to hear this! Have fun!
            • soloS Offline
              Tom, they work in Thea, just had to adjust the transparency in SU before export.
              Straight Thea output with Bloom and vignetting, no post processing.
              http://img705.imageshack.us/img705/5797/tomnprthea.jpg
                tomsdesk
                Well, I'm happy...thanks a bunch, Pete!
                • broomstickB Offline
                  broomstick
                  Thank you very muche, great models πŸ˜„
                    red_shift
                    Pete: you didn't have to do anything additional in Thea? What kind of transparency adjustment in SU?
                    • soloS Offline
                      I eliminated all transparency values in SU, in Thea I clicked to enable the clip, and used the texture as a clipmap making sure it was alpha and not RGB.
                        red_shift
                        Similar to my approach mentioned above. I'm glad these work in Thea.
                          buk2noy
                          sir, thank you! πŸŽ‰
                          seeking for peace of mind
                            tallbridgeguy
                            TBG
                            Nielsen
                            http://www.tallbridgeguy.com/
                              stevebo
                              Oldish topic but just want to say thank you Tom πŸ˜„. I promised I would buy it, bit late but I did πŸ˜„. They look great!
                              Edit: Some quick tests on Vray
                              http://img.photobucket.com/albums/v644/stevebo37/1-8.jpg
                              http://img.photobucket.com/albums/v644/stevebo37/2-6.jpg
                              • 2 / 2
