    Profile Builder released!
    125 Posts 41 Posters 65.8k Views 41 Watching
      DIEGO-RODRIGUEZ
      ok. thanks.
      correction
      I bought version 1, and look forward to version 2
        mikeewilly
        Profile Libraries
        I know this may be a touchy subject and I'm not asking for a Library Viewer, but is there a recommended way of documenting what each profile looks like in a library to make it easy for me to find one pseudo-quickly. This is most important when I sitting with a customer trying to quickly sketch out their vision.
        Thanks for the help,
        Mike
        • W Offline
          Whaat
          @mikeewilly said:
          Profile Libraries
          Mike
          Hi Mike,
          All i can really suggest is to use a long descriptive name for the profile name and make use of the 'favourites' library. Obviously, this will make it much easier to find the profile you are looking for. (Sorry if this isn't the kind of answer you were hoping for...) ๐Ÿ˜„
            mikeewilly
            @whaat said:
            Hi Mike,
            Well thanks for the suggestion, I'll do that. What about any tips for libraries I've downloaded? (Specifically the "Mouldings" library)
            Thanks again for a nice tool.
            Mike
              @whaat said:
              @mikeewilly said:
              Profile Libraries
              Mike
              Hi Mike,
              What's the format the profiles are saved in?
              I was thinking, is it isn't scrambled, then it wouldn't be too hard to write a little snippet that recreates the profiles as faces in SU which then can be printed....
                Cheers TIG! ๐Ÿ‘
                  @thomthom said:
                  @whaat said:
                  @mikeewilly said:
                  Profile Libraries
                  Mike
                  Hi Mike,
                  The data is stored in .plb files in C:\Program Files\Google\Google SketchUp 7\Plugins\ProfileBuilder\Libraries\, and it is in the format
                  SQ0.25x0.25 0.0 0.0 0.25 0.0 0.25 0.25 0.0 0.25 SQ0.5x0.5 0.0 0.0 0.5 0.0 0.5 0.5 0.0 0.5
                  ...this above is from the 'built-in' Squares Imperial.plb and is for a 1/4" square, 1/2" square, etc
                  It is a line-by-line space separated data set, the first part is the profile's name [for the first one here it's SQ0.25x0.25] and the remainder are paired values that make 2D points, and are used to make the shape, always set off from the first one that's 0,0...
                  When you make a custom profile it lists the vertices as 2D points starting at [0,0]...
                  Any new profile you make can be saved into any current profile .plb library or Favorites.plb [you can make as many .plb files as you like with ...Create New option] - a new profile's name always has spaces stripped out [so 'My Profile 1' becomes 'MyProfile1'] to avoid confusion in the data structure...
                  So it would be relatively easy to read the .plb files, a line at a time and get the profile's name and its points, [converted to 3d by adding a third item to the array as 0], then use those to make a face inside a group and move that group about on the screen to miss any others by their b'boxes and place a text-tag in the center of it giving the .plb_name+profile+name, repeat for all profiles in the .plb - finally take a .png of the screen, named after the .plb etc and repeat for other plb's...
                  Over to you thomthom... ๐Ÿ˜‰
                  • bagateloB Offline
                    bagatelo
                    If can be possible to scaleup or scaledown the profiles stored on the library....
                    And to create and set layer by profile name...
                    And... if the plugin can set material for profile, maybe this data can be stored on profiles.
                    this maybe make me smile.
                    • bagateloB Offline
                      bagatelo
                      Is it possible to access and to use the tools of great Dale Martens for other scripts, enlarging Google Sketchup's API or something like this?
                        slugore
                        I love this plug-in! As soon as I saw the video I had to buy it.
                        One question that I think hasn't been answered (and forgive me if it has been) has to do with adding textures to a profile.
                        I created a wall profile that was then used to create several walls(Placement Point: Bottom Left). When I try to add a texture that has a definite vertical orientation, it seems to rotate the texture to the horizontal(in direction of extrusion). Exploding the group and then adding the texture seems to work but adds a few extra steps that I would rather not take. Is there something that I am missing? Or is this a Sketchup thing? (Follow me appears to keep the orientation right BTW.)
                        Thanks in advance.
                        http://slugisdoug.files.wordpress.com/2010/03/pbwallssmall.jpg
                        • boofredlayB Offline
                          boofredlay
                          Thanks again for this one Dale, it saved my butt tonight.
                          • gtalaricoG Offline
                            gtalarico
                            Crashed SU 8...
                            Has anyone been able to "edit path" on SU 8?
                            Cheers
                            -Gui
                            http://www.gtalarico.com
                              @gtalarico said:
                              Crashed SU 8...
                              Cheers
                              hm... I've used PB in SU8 - but I just realised I haven't edited a path yet - as it just crashed on me when I tried it.
                                gtalarico
                                I guess whaat is aware of it:
                                File Not Found
                                (www.smustard.com)
                                -Gui
                                • W Offline
                                  Whaat
                                  @thomthom said:
                                  @gtalarico said:
                                  Crashed SU 8...
                                  Cheers
                                  Yes, this bug has been reported awhile ago to the SketchUp team. I need to check with them to see if it will be fixed in the next update.
                                    You know what caused it?
                                      Dsmelcer1234
                                      Any update on the su8 edit path bug?
                                        gtalarico
                                        According to someone on Smustard, SU maintenance patch 8.0.4811 for sketchup fixes the bug:
                                        http://www.smustard.com/forum/viewtopic.php?f=3&t=70
                                        -Gui
                                          Yup! ๐Ÿ˜„
                                          • MarianM Offline
                                            Marian
                                            I'm having a problem with Profile builder. I can't access any of the profile libraries even though they're correctly located.
                                            • 6 / 7
