    Faces PushPulled to 0 in SU7 are deleted !!
    21 Posts 9 Posters 1.2k Views 9 Watching
    • simon le bonS Offline
      simon le bon
      Hi dear SCF users
      Is anybody is constrained as I am with PUSHPULL TOOL in SU7 ?
      When I push a face to zero, this face is always deleted. I feel very uneasy with this!
      [flash=493,352:2n5ya77w]http://www.youtube.com/v/rY4oi4dJjDY[/flash:2n5ya77w]
      (for exemple,I was used in SU6 to draw my vertical sheets as shown in the video: starting from a pushpulled rectangle. Can't do the same anymore.)
      May be I miss the good keys combination?
      😒 simon
      • jim smithJ Offline
        jim smith
        I have noticed that feature - or bug in V.7, as well. 😞
        So far, I have just worked around it but I agree there should be a way to keep that face. I hope someone knows of a key to hold down or something like that, to keep the face as an option. ❓
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
          that happen also with the SU 6 ! 😮
          Not at any time but after 2 or 5 pusphull on the same cube, you can make this one disapaer just with the Pushpull tool ! 😉
            Well, so to say this is the "natural" behaviour of su.
            When you make an opening in a wall (with parallel faces) and you PP the window through, it also deletes the opposite side by default. The program (probably) cannot make a difference when it is favourable to delete something that becomes 0 thick and when it is not.
              It is a pain... BUT it you select the face and then Move it instead, it will work as required and not delete the face in the new position [as PushPull now unfortunately does]... 😕
              • jeff hammondJ Offline
                That sounds better than the workaround I've been using which is select the face I want to keep, copy it, pushpull the volume to 0, then paste in place. I have a full day of designing ahead so I'm sure I'll have a chance to test the method today.
                  That's a brilliant tip, and deserves a mention in 'Beginners Tips' topic 👍
                  • daleD Offline
                    dale
                    Yes, Great tip. Thanks.
                      simon le bon
                      So I'm not alone to be annoyed..
                      Yes I think also TIG's solution is the best and simplest alternative to a wrong (IMO) PushPullTool upgrade
                      [flash=640,367:37qwzp78]http://www.youtube.com/v/edJd6Wrczfg[/flash:37qwzp78]
                      thanks TIG
                      *s
                      • daleD Offline
                        dale
                        I certainly wouldn't want the ability to push/delete a window in a double faced wall if this were addressed.
                          simon le bon
                          Hi Dale, ? I don't understand what you mean ❓ 💭
                          http://i274.photobucket.com/albums/jj245/Spendauballet/videos/PushPullSU6.gif
                          *sim
                          • daleD Offline
                            dale
                            Sorry Simon, I meant I wouldn't want to "lose" the ability to ....... Mr peck and poke typist strikes again...
                              simon le bon
                              This remind me a tip from Boofredlay I guess to PushPull a number of faces at the same time and the same length.
                              We can't use it anytime, specially on a complex model whit multilevel volumes. But in case, and to bring some fresh, here it is. (Thanks Boo! if it is from you: I don't recover it)
                              [flash=640,367:2a9fxvxe]http://www.youtube.com/v/Lw8Azee2jso[/flash:2a9fxvxe]
                              *s
                              • halroachH Offline
                                halroach
                                1. If face orientation isn't an issue (or is easy to adjust later), you could always pull the problematic face twice. First push holding down ctrl (causing some faces to reverse), and the second push brings the face to where you want it. Later it's just a matter of orienting faces.
                                double push pull:
                                [flash=640,367:37aarrx9]http://www.youtube.com/v/afE2l9_59zs&hl=en_US&fs=1&rel=0&hd=1[/flash:37aarrx9]
                                1. Another way is to draw a line across the surface you wish to keep. push the face and erase the remnants of the line.
                                Push Pull with a line:
                                [flash=640,367:37aarrx9]http://www.youtube.com/v/SLoExGhkwpg&hl=en_US&fs=1&rel=0&hd=1[/flash:37aarrx9]
                                Sometimes TIG's way is faster, other times these two ways are faster.
                                It always boils down to the amount of clicks 🎉 it takes in any one scenario.
                                FlexTools - Super Quick Windows, Doors, Slats...
                                  simon le bon
                                  Thank you so much Halroach to bring these two new scenarios ( and for the way simple they are explained).
                                  They are going to help a lot 👍 👍 👍
                                  😄 simon
                                  PS: any chance to obtain from Google SktechUp team to bring the old PushPull tool back ? 😕
                                  • daleD Offline
                                    dale
                                    Zippy avatar simon. Almost looks vaguely familiar ❓
                                      simon le bon
                                      Dear Dale,
                                      Thank you to take care, (may be I am needing it 😕 )
                                      I don't know what you mean by "Zippy" but coming from you, nothing unfair I'm sure. Something "creepy" I suppose.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/zScan_008_500jpg.jpg
                                      it looks vaguely familiar because it is Me! If you look it carefully, you will find it is my true self portrait 😆 !!
                                      I feel my freaky side very powerful by these days. Nothing very new at least.
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/zScan_010_500p.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/zScan_011_500p.jpg
                                      http://i274.photobucket.com/albums/jj245/Spendauballet/generalPicts/zScan_009_500p.jpg
                                      *s
                                      • daleD Offline
                                        dale
                                        Well it's great. Zippy in this case means "dynamically fresh"
                                        Dynamically I'll define as "a stimulating development or progress"
                                        While I'll define fresh as "something new and different"
                                        Maybe its the color, but it really caught my attention.
                                        Ride that freaky wave if this is it's outcome!
                                          simon le bon
                                          Thanks man!
                                            i forgot to post back my findings on this earlier..
                                            using works great as long as nothing else is attached to the face. if there is connecting geometry then you'll have to resort to another method.
