    1.5k Posts 471 Posters 3.4m Views 470 Watching
      krash88
      Thanks for taking a look at this for me. While I may not be able to use your script on this particular model, I can see many uses elsewhere. I appreciate the hard work that you and others have put into these scripts and for your time in answering questions. Guys like you have really turned SketchUp into something great. Thanks again!
        magpie
        Fredo, I echo the sentiment of all the grateful users who benefit from your talent and selfless dedication. Many thanks for this!
          mgfranz
          Excellent plugin! My router is going to be jealous... 😍
          "If you like what you do, it will never be work..."
          In memory of Sam Maloof, 1916-2009
            AR-51
            Hi, I install RoundCorner, but I'm unable to access it in SketchUp. When I click on Tools>FredoScale noting happens.
            I also get no response when I click on Set Preference Languages.
            I'm using Vista
            Thanks for the help.
            http://i601.photobucket.com/albums/tt93/Bestworldphoto/Sketch.jpg
            Plug in foulder
            http://i601.photobucket.com/albums/tt93/Bestworldphoto/Plugin.jpg
            • F Offline
              fine2444
              http://cfile234.uf.daum.net/original/155C3D1D4B6EA9867F0B3A
              I made two round corner model Yesterday, today.
              I want two same shape of rondcorner model but It is not working out.
              Working conditions were the same as the shape ..
              What's wrong?
              I dont want small triangle particles at all in very right model.
              You mean It happens becasue the edge is not aligned, I think I aligned it
              would like to tell me why and how?
                Hi Fine,
                Can you delete those edges without losing the faces?
                It's not necessarily there because you did not align your model but maybe because the newly created facets would not be co-planar otherwise.
                In any case, after smoothing those surfaces, it won't be seen (but I understand that you wish to have the least geometry and cleanest possible model)
                • fredo6F Offline
                  What's wrong?
                  Can you check if you use the same setting for the option "Strict Offset" (this is the button with the vertical green and red bars).
                    archi-sketch
                    i don't know what to say..or should i just say~THANK YOU VERY MUCH!!! ..you make my day!
                      rd84
                      Many thanks for this utility - my life using Sketchup is suddenly much easier !
                      Cheers
                      Paul
                        aea
                        2D round corner is ? plugin , something ?
                        • mitcorbM Offline
                          mitcorb
                          See TIG's 2D Tools.
                          Or fillet one corner with arc, mirror copy the others.
                            aea
                            my instal TIG 2D TOOLS bad no i managed ...?
                            • massimoM Offline
                              massimo Moderator
                              Try this Adrian, it's called "2D fillet".
                                Jim
                                A Fillet Tool should be a first-class plugin for Sketchup. What I mean is it should have a spot in the Tools menu, have a clear purpose, meet user's expectations for a native Tool, and be a stand-alone plug-in separate from dependencies.
                                I know several plug-in suites have a fillet feature, but I think would be better to borrow the best functionality from them all and create a dedicated feature out of them.
                                Sorry to go off-topic.
                                • fredo6F Offline
                                  You can also try BezierSpline 1.3and convert your rectangle and other polylines to have round corners.
                                  See post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                                  1. select the rectangle (contour with surface is fine)
                                  2. call the contextual menu Convert to... > Polyline Arc Corner
                                  3. You are prompted for the Radius of the corners
                                  4. Your contour will be rounded at the corners and become a curve
                                  5. you can change the number of segments of the corner by typing a Precision number followed by 's' (this is the number of segment for a full circle, by default 24)
                                  6. You can later chang'Ee the Radius and Precision with the BezierSpline Edit tool (also in contextual menu when selecting the contour 'Edit Polyline Arc Corners')
                                    aea
                                    THANKS from answer , 2d tool , fillettool , fillet.rb no works , bezier spline is ok ...
                                    • ely862meE Offline
                                      ely862me
                                      Hi Adrian! I see u have some problems with the plugins!
                                      Send me a private message so we can discuss better.
                                      Till soon!
                                      Salut Adrian! Vad ca ai ceva probleme cu plugin urile!
                                      Trimite mi un mesaj privat sa putem discuta mai bine.
                                      Pe curand!
                                      Elisei (sketchupper)
                                      Come and See EliseiDesign
                                      • romboutR Offline
                                        rombout
                                        why is there a PS plugin in the folder??????
                                        • HieruH Offline
                                          Hieru
                                          I'm having a little difficulty with the plugin.
                                          The plugin works initially, but when I save my file I lose a small section from each corner.
                                          Any idea what might be causing this?
                                          http://artsablaze.com/Images/missingCorner.jpg
                                          www.davidhier.co.uk
                                            Sketchup can't create faces that are too small. Scale up the geometry first, then scale down.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 73
                                            • 74
                                            • 29 / 74
