    1.5k Posts 477 Posters 4.1m Views 477 Watching
      archi-sketch
      i don't know what to say..or should i just say~THANK YOU VERY MUCH!!! ..you make my day!
        rd84
        Many thanks for this utility - my life using Sketchup is suddenly much easier !
        Cheers
        Paul
          aea
          2D round corner is ? plugin , something ?
          • mitcorbM
            mitcorb
            See TIG's 2D Tools.
            Or fillet one corner with arc, mirror copy the others.
              aea
              my instal TIG 2D TOOLS bad no i managed ...?
              • massimoM
                massimo Moderator
                Try this Adrian, it's called "2D fillet".
                  Jim
                  A Fillet Tool should be a first-class plugin for Sketchup. What I mean is it should have a spot in the Tools menu, have a clear purpose, meet user's expectations for a native Tool, and be a stand-alone plug-in separate from dependencies.
                  I know several plug-in suites have a fillet feature, but I think would be better to borrow the best functionality from them all and create a dedicated feature out of them.
                  Sorry to go off-topic.
                  • fredo6F
                    You can also try BezierSpline 1.3and convert your rectangle and other polylines to have round corners.
                    See post at http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&hilit=plugin#p100509
                    1. select the rectangle (contour with surface is fine)
                    2. call the contextual menu Convert to... > Polyline Arc Corner
                    3. You are prompted for the Radius of the corners
                    4. Your contour will be rounded at the corners and become a curve
                    5. you can change the number of segments of the corner by typing a Precision number followed by 's' (this is the number of segment for a full circle, by default 24)
                    6. You can later chang'Ee the Radius and Precision with the BezierSpline Edit tool (also in contextual menu when selecting the contour 'Edit Polyline Arc Corners')
                      aea
                      THANKS from answer , 2d tool , fillettool , fillet.rb no works , bezier spline is ok ...
                      • ely862meE
                        ely862me
                        Hi Adrian! I see u have some problems with the plugins!
                        Send me a private message so we can discuss better.
                        Till soon!
                        Salut Adrian! Vad ca ai ceva probleme cu plugin urile!
                        Trimite mi un mesaj privat sa putem discuta mai bine.
                        Pe curand!
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • romboutR
                          rombout
                          why is there a PS plugin in the folder??????
                          • HieruH
                            Hieru
                            I'm having a little difficulty with the plugin.
                            The plugin works initially, but when I save my file I lose a small section from each corner.
                            Any idea what might be causing this?
                            http://artsablaze.com/Images/missingCorner.jpg
                            www.davidhier.co.uk
                              Sketchup can't create faces that are too small. Scale up the geometry first, then scale down.
                              • X
                                xrok1
                                that sentence should be added to the end of every forum topic title, specially the newbie one. 😆
                                it should actually be a SU popup to warn the user when this happens.
                                • HieruH
                                  Hieru
                                  Thanks for the response.
                                  Unfortunately I already tried that and the same thing happens.
                                  The plugin creates the rounded corners (20mm radius in this case), but as soon as I save the file a section from each corner literally vanishes. If I 'undo', the missing section reappears - disappearing again if I try and save the file.
                                  What is odd, is that it only appears to happen with certain files and certain objects within a model (just basic shapes - nothing complex).
                                  www.davidhier.co.uk
                                  • X
                                    xrok1
                                    did you try scaling it up before saving it?
                                    • HieruH
                                      Hieru
                                      Yes I did.
                                      I've just tried remodelling certain elements of the model I'm working on and I'm finding that all sorts of odd geometry is appearing on its own and random bits of geometry keep disappearing in areas where I haven't applied the plugin.
                                      I'll have to try reinstalling SU.
                                      www.davidhier.co.uk
                                      • fredo6F
                                        @hieru said:
                                        Yes I did.
                                        Before reinstalling SU, could you post your model, so that I have a look and try to find out where the issue comes from.
                                        • HieruH
                                          Hieru
                                          I'd really appreciate that. Thanks.
                                          Problem File
                                          The model has only been scaled up so that it is 10 times the size that it needs to be. I've been trying to use a 2mm bevel on various edges, but if I scale up the model and use a 20mm bevel, I still get the same problem.
                                          www.davidhier.co.uk
                                          • X
                                            xrok1
                                            nice model but which corners are giving you problems?
                                            • 11
                                            • 12
                                            • 74
                                            • 75
                                            • 10 / 75
