    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 968.2k Views 175 Watching
      TIG,
      This tool set has been a blessing. Have followed it closely since you first posted them as individual plugins. Must say it's a tremendous example scripting prowess that have moved the goal posts in terms of SU capabilities. Congrats!
      Do you think it us possible to implement a coloured highlight feature which indicates rail selection from profile selection? Along the lines of Whaats SDS Crease tool. It would mimic what's seen in each icon. It's not really an issue more a graphical aid.
        chrisjk
        TIG, in addition to your toolbar showing a blank button, I also get a blank button on my Mac with Jim Folz's MakeOrthoViews.rb I have no idea what causes it though. Maybe if you look at Jim's script it will give you a clue?
        Edit - just realised Jim's script is encrypted!
          TIG,
          Thanks for the praise 😳
          It would be possible to color profiles and rails differently rather than select them with the normal highlighting - but what colors would you like ? I could get it to trace over them with the 'draw' command while the tool is active with any standard colors you like ? I tend to avoid RGB as they are axial how about profile=cyan, rail1=magenta, rail2=dark_cyan and profile2=dark_magenta - it'll vary across tools as some have different selection needs etc - also the last item picked doesn't always highlight well - but that's the challenge ! 🤓
            Thanks for the reply. I think your suggestion of colours is the way to go. And will compliment the tool quite well. I see how it can't be applied to certain tools but still think it'll be well received
              Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              The picked curves/faces etc are now highlighted and 'color-coded' [this depends on the tool***]
              Typically they are:
              Profile[Face] =Cyan
              Rail/Rail1 = Magenta
              Rail2 = DarkVioletRed
              MeldingProfile[Face] = DarkCyan
              OtherFace = Orange
              ***See each Tools notes...
                Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                EEbyRailsByFace has been fixed - glitches with curve selection and color-coding locations.
                  Here's the latest update - http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  The Tooltips etc are now properly deBabelized into other languages...
                  • U Offline
                    unclex
                    Update Again……
                    Wonderful things
                    • H Offline
                      hsjzyangbin
                      Thank you
                        dedmin
                        Is there a way to organize plugins into sub-menus?
                          A bit off topic, but yes.
                          See 'organizer' available on Smustard and also my earlier ideas drifting around where you could create your sub-menus in an early loading ruby [#.rb] and add your scripts to any one by giving them one of its global variables e.g. $submenu1 for the menu rather than "Plugins"...
                          I use it to group my plugins as
                          Construction[Guide] Tools
                          2D Tools
                          3D Shape Tools - Simple
                          3D Shape Tools - Complex
                          2D Manipulation Tools
                          3D Manipulation Tools
                          Camera/Image Tools
                          Text/Dims Tools
                          Terrain Tools
                          Other Tools
                          $submenu0 to $submenu9...
                            dedmin
                              charrr
                              cool tool 👍
                                Here's the latest version
                                404 Not Found
                                (forums.sketchucation.com)
                                It has a new tool added 'ExtrudeEdgesByLoft'...
                                [instructions here http://forums.sketchucation.com/viewtopic.php?p=231016#p231016]
                                • ken28875K Offline
                                  ken28875
                                  @tig said:
                                  Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                  Awesome, TIG! Your plugins are so useful to me that I use them at work everyday!
                                  Thank you, Sir. 👍 👍
                                  Follow Your Dreams.
                                    Ben Ritter
                                    TIG, Thank you so much for all your newest releases. I appreciate your generosity in sharing.
                                      Here's ANOTHER update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      Fixes a reported glitch on the EEbyLathe tool that messed it up completing - orient etc...
                                        chloesdad
                                        TIG, Thank you very, very much for your toolset. I just updated with the loft tool. All work flawlessly on my Mac. I really appreciate your skills, and efforts.
                                          Here's another update [3rd of the day!]
                                          In this one the FR lingvo file has been updated by Didier Bur...
                                          I knew that Extrude Edges by Loft == Extruder des arêtes par 'Loft' could have been put much better [my franglais ain't so good... !]...
                                          But Extruder des arêtes par profilage entre courbes is not half as snappy ??? 😉
                                          The Spanish disponiendo is quite near 'to loft' - when taken in the 'naval architecture' sense of 'to lay-out a hull of a ship' - which is where I believe 'loft' comes from ?
                                          Anyway whatever fits is best...
                                          Enjoy...
                                            Better is "Tendre une surface entre 2 courbes" and more poetic 😉
                                            (tensile structure) a loft between 2 curves
                                            • 31
                                            • 32
                                            • 5 / 32
