    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 248.9k Views 51 Watching
      if you could rename this "Exploded View"
      you speak about the title of the tread?
      • X Offline
        xrok1
        yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
          He got a point..
          • X Offline
            xrok1
            it would make it a little more clear what the plugin is for as well. 😉
              Done and tested with the search Engine ☀
              No someone can find it by the title and by your post 😉
                Anyone experiencing Bugsplats with SU7.1 and this plugin?
                Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                I know i have the components nested in a component but use this plugin when not nested
                CherryMax Rivet.skp
                  Stephan
                  Hello,
                  Same problem for me with SU7.16860, I get a Bugsplat each time I try to use it. 😕
                  Any idea?
                  Rgds,
                  Stephan
                    kostas_designer
                    No bugsplat to me, although i do not understand why some groups stay glued together..
                    In this example there are only first-class groups:
                      Is this plugin not compatible with the latest SU? Pilou if you've time can you look?
                      It is behaving strangely with mixed results.
                        dtrarch
                        Also see Smustard for Todd Burch's ExplodeImplode script.
                        Works OK with SU 7.1 and older.
                        dtr
                          [url]some groups stay glued[/url]
                          The explosion is made by level by level of grouped elements
                          Normally no reason for that 😄
                          Have you a file for test it?
                            c.plassais
                            Hi all,
                            just a little precision
                            plugin Pilou ➡
                            model = Sketchup.active_model
                            entities = model.entities
                            selection = model.selection
                            xp=100  # Pivot Point (as you want)
                            yp=100
                            zp=100
                            q=50 # Measure of translation (as you want)
                            selection.each do |e| # update!
                              # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                              next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                            center = e.bounds.center #Center Point of the grouped object
                               xc= center.x
                               yc= center.y
                               zc= center.z
                            xe=xc #End Point of the grouped object
                            ye=yc
                            ze=zc
                            if xc<xp
                            xe =xc - q
                            if xc>xp
                            xe =xc + q
                            if yc<yp
                            ye =yc - q
                            if yc>yp
                            ye =yc + q
                            if zc<zp
                            ze =zc - q
                            if zc>zp
                            ze =zc + q
                              point = Geom;;Point3d.new xe,ye,ze
                              t = Geom;;Transformation.new point
                              # Apply the transformation
                              e.transform!(t)
                            plugin modified by me ➡
                            # Designed December 2009 by C.plassais + Pilou
                            # Permission to use this software for any purpose and without fee is hereby granted
                            # Distribution of this software for commercial purpose is forbidden;
                            # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                            # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                            # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                            # Name			;   Eclate_Deplace
                            # Original Date	;  03 Juil 2009 version 0.0 (thx to TIG, Thomthom)
                            # Type			;   Plugin
                            # Description	;   Exploding movements of groups or/and components
                            # Usage			;   Right Click - Context Menu
                            # Version 0.3.2
                            # petit plug d'explosion deplacement" de groupes ou de composants
                            	require 'sketchup.rb'
                            	def pilou_explose
                            		myModel = Sketchup.active_model
                            		myEntities = myModel.entities
                            		selection = myModel.selection
                            		if selection.empty?
                            		    UI.messagebox "Veuillez Selectionner des\nComposants ou des Groupes"
                            		myModel.start_operation "Deplacement Eclate",true
                                    group = myModel.active_entities.add_group(selection)
                            		centre_selec = group.bounds.center
                            		point_ligne = UI.messagebox "Voulez-matérialiser les déplacement \npar des points et des lignes de construction", MB_YESNO
                                    (point_ligne == 6) ? (myEntities.add_cpoint (centre_selec)) ;()
                                    resultat1 = UI.messagebox "Voulez vous faire une copie de l'original", MB_YESNO
                            		if resultat1 == 6
                            		    group2 = group.copy
                            		    group2.explode
                                    selection = group.explode
                                    cent_selec_x = centre_selec[0].to_i   # determination
                            		cent_selec_y = centre_selec[1].to_i   # du centre de
                            		cent_selec_z = centre_selec[2].to_i   # la selection
                                   		prompts = ["Ecarter ou centrer/par rapport au pivot", "Deplacement pivot x", "Deplacement pivot y", "Deplacement pivot z", "Coef translation x de 0 a...", "Coef translation y de 0 a...", "Coef translation z de 0 a...", "Groupe Composant les 2"]
                            		val_defaut = ["Centrer", cent_selec_x, cent_selec_y, cent_selec_z, 1.00, 1.00, 1.00, "Les 2"]
                            		liste_val = ["Centrer|Ecarter", "", "", "", "", "", "" , "Groupe|Composant|Les 2"]
                            		results = UI.inputbox prompts, val_defaut, liste_val, "Parametres"
                            		return if not results
                            		decent_pivot, deplac_pivot_x, deplac_pivot_y, deplac_pivot_z, coef_trans_x, coef_trans_y, coef_trans_z, group_ou_comp = results
                                    # Translation des axes suivant unites
                                    convertit = []
                                    convertit[0]= 1.inch
                                    convertit[1]= 1.feet
                                    convertit[2]= 1.mm
                                    convertit[3]= 1.cm
                                    convertit[4]= 1.m/100
                                    uniteCourante = myModel.options["UnitsOptions"]["LengthUnit"]
                                    coef_trans_x = coef_trans_x.to_f * convertit[uniteCourante]
                                    coef_trans_y = coef_trans_y.to_f * convertit[uniteCourante]
                                    coef_trans_z = coef_trans_z.to_f * convertit[uniteCourante]
                                    # Calcul de la distance entre le centre d'origine de la selection et le nouveau
                                    nouv_pivot_x =  cent_selec_x-deplac_pivot_x
                                    nouv_pivot_y =  cent_selec_y-deplac_pivot_y
                                    nouv_pivot_z =  cent_selec_z-deplac_pivot_z
                                    case decent_pivot
                                         when "Ecarter"
                                              myEntities.add_cpoint [(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]
                                              myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]) ; ()
                                         when "Centrer"
                                             nouv_pivot_x =  - nouv_pivot_x
                                		     nouv_pivot_y =  - nouv_pivot_y
                                		     nouv_pivot_z =  - nouv_pivot_z
                                		     myEntities.add_cpoint [deplac_pivot_x,deplac_pivot_y,deplac_pivot_z]
                                		     myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[deplac_pivot_x, deplac_pivot_y, deplac_pivot_z]) ; ()
                                    case group_ou_comp
                                        when "Groupe"
                                            group_ou_comp = comp_ou_group = Sketchup;;Group
                                        when "Composant"
                                            group_ou_comp = comp_ou_group = Sketchup;;ComponentInstance
                                        else
                            	           group_ou_comp = Sketchup;;Group
                            		selection.each do |e| # debut de la transformation
                            			next unless (e.is_a? group_ou_comp) or next unless(e.is_a? comp_ou_group)
                            			centre_objet = e.bounds.center
                            			centre_objet_x = centre_objet[0].to_i  # Determination
                            			centre_objet_y = centre_objet[1].to_i  # du centre
                            			centre_objet_z = centre_objet[2].to_i  # de l'objet
                                       (centre_objet_x == cent_selec_x) ? (nouv_centobj_x = nouv_pivot_x) ; (nouv_centobj_x = ((centre_objet_x-cent_selec_x) * coef_trans_x) + nouv_pivot_x)
                                       (centre_objet_y == cent_selec_y) ? (nouv_centobj_y = nouv_pivot_y) ; (nouv_centobj_y = ((centre_objet_y-cent_selec_y) * coef_trans_y) + nouv_pivot_y)
                                       (centre_objet_z == cent_selec_z) ? (nouv_centobj_z = nouv_pivot_z) ; (nouv_centobj_z = ((centre_objet_z-cent_selec_z) * coef_trans_z) + nouv_pivot_z)
                                        point_trans = Geom;;Point3d.new nouv_centobj_x,nouv_centobj_y,nouv_centobj_z
                                        t = Geom;;Transformation.new point_trans
                                        e.transform!(t)
                                        nouv_centobj = e.bounds.center
                            			myEntities.add_cpoint (nouv_centobj)
                            			myEntities.add_cpoint (centre_objet)
                            			constline = myEntities.add_cline [centre_objet_x, centre_objet_y, centre_objet_z],nouv_centobj
                            			constline.stipple = ".") ; ()
                            			myModel.selection.add e
                            		myModel.commit_operation
                            	end # pilou_explose
                            	if( not file_loaded?("Eclate_Deplace.rb") )
                                    UI.add_context_menu_handler do |context_menu|
                            	       context_menu.add_separator
                            	       context_menu.add_item("Eclate_Deplace") { pilou_explose }
                                    file_loaded("Eclate_Deplace.rb")
                            Christophe
                              No problem 😄
                              Idea 💭 Pilou for training Ruby 5%
                              Realisation Ruby C.Plassais 95%
                              • BoxB Offline
                                I'm using the latest version of sketchup and I get a bug splat every time I try to use Eclate.
                                Even with a simple cube. As soon as you click yes or no on the copy dialog it shuts down and goes to bug splat.
                                  c.plassais
                                  you should only use Eclate_Deplace with components or groups
                                    kyyu
                                    It doesn't bug splat for me, but I am still using SU v7.0.10247. It doesn't do much with that file either, except add one guide point?
                                    I tried it on an ungrouped 3D pushpulled rectangle and also not bug splat. So could be something not compatable with the latest version of sketchup.
                                      @kyyu said:
                                      ... It doesn't do much with that file either, except add one guide point?
                                      Why would you use it on an "ungrouped 3D push/pulled rectangle"? The plugin is intended to move components away from each other to create an exploded view of this sort.
                                      http://farm5.static.flickr.com/4023/4628792635_15716dcc29.jpg
                                        kyyu
                                        Because a few post up, Box said he was getting bug splats on everything; even with a simple cube. So I tested it, but maybe he meant a cube made of grouped sides? Anyways, I was checking for bug splats and didn't find any. But, like I noted, I'm using v7.0 of sketchup.
                                        • BoxB Offline
                                          Yes I was using a cube of grouped faces, and at first I was getting a bug spat every time, now it is random.
                                          I have rebooted and added updates and a few other bits and pieces since then, sorry that's not a very useful bit of diagnostic information but I've been doing too many things at once.
                                          So to put it simply, It does work for me but it is unstable and I have yet to work out what, if any, conditions cause the bug splat.
                                            c.plassais
                                            Two versions of the plugin that can be corrected bug
                                            I've written a 3.0.2 version and also a rewritten version by the genius Fredo. Thanks Fredo 👍
                                            Sorry I can not insert in the original post ...
                                            The limitation of this plugin is that it does not take into account the size of groups or components.
                                            It moves only the elements from their center. Perhaps a future version
                                            Christophe
                                            Eclate_Deplace english version 3.0.2
                                            version 3.0.2 rewritten by fredo ChrisP_RadialMove
                                            • 2 / 9
