    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 237.5k Views 51 Watching
      @C.plassais: sorry a very hard hyperactive end of year 💚
      See you soon next year! 😉
      [flash=500,405:1je4n8r4]http://www.youtube.com/v/o9698TqtY4A[/flash:1je4n8r4]
      • MALAISEM Offline
        MALAISE
        Oh Guys, I miss a lot beeing on travel for the last 15 days.
        Excellent work, I 'll use it very fast for technical explanations 😄
        MALAISE
        • X Offline
          xrok1
          great plugin, thanks. if you could rename this "Exploded View" or "Exploded Model Viewer" or similiar, it would be much more precise and easier to find. 😉
            Edit the script with a plain text editor - like Notepad.exe [osa] - and replace any 'French' text inside "" with your 'English' translation[s]. Keep a copy in case you screw up...
            You can adjust a script to say whatever you want.... 🤓
              you speak about the title of the tread?
              • X Offline
                xrok1
                yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
                  He got a point..
                  • X Offline
                    xrok1
                    it would make it a little more clear what the plugin is for as well. 😉
                      Done and tested with the search Engine ☀
                      No someone can find it by the title and by your post 😉
                        Anyone experiencing Bugsplats with SU7.1 and this plugin?
                        Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                        I know i have the components nested in a component but use this plugin when not nested
                        CherryMax Rivet.skp
                          Stephan
                          Hello,
                          Same problem for me with SU7.16860, I get a Bugsplat each time I try to use it. 😕
                          Any idea?
                          Rgds,
                          Stephan
                            kostas_designer
                            No bugsplat to me, although i do not understand why some groups stay glued together..
                            In this example there are only first-class groups:
                              Is this plugin not compatible with the latest SU? Pilou if you've time can you look?
                              It is behaving strangely with mixed results.
                                dtrarch
                                Also see Smustard for Todd Burch's ExplodeImplode script.
                                Works OK with SU 7.1 and older.
                                dtr
                                  [url]some groups stay glued[/url]
                                  The explosion is made by level by level of grouped elements
                                  Normally no reason for that 😄
                                  Have you a file for test it?
                                    c.plassais
                                    Hi all,
                                    just a little precision
                                    plugin Pilou ➡
                                    model = Sketchup.active_model
                                    entities = model.entities
                                    selection = model.selection
                                    xp=100  # Pivot Point (as you want)
                                    yp=100
                                    zp=100
                                    q=50 # Measure of translation (as you want)
                                    selection.each do |e| # update!
                                      # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
                                      next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
                                    center = e.bounds.center #Center Point of the grouped object
                                       xc= center.x
                                       yc= center.y
                                       zc= center.z
                                    xe=xc #End Point of the grouped object
                                    ye=yc
                                    ze=zc
                                    if xc<xp
                                    xe =xc - q
                                    if xc>xp
                                    xe =xc + q
                                    if yc<yp
                                    ye =yc - q
                                    if yc>yp
                                    ye =yc + q
                                    if zc<zp
                                    ze =zc - q
                                    if zc>zp
                                    ze =zc + q
                                      point = Geom;;Point3d.new xe,ye,ze
                                      t = Geom;;Transformation.new point
                                      # Apply the transformation
                                      e.transform!(t)
                                    plugin modified by me ➡
                                    # Designed December 2009 by C.plassais + Pilou
                                    # Permission to use this software for any purpose and without fee is hereby granted
                                    # Distribution of this software for commercial purpose is forbidden;
                                    # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                                    # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                                    # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                    # Name			;   Eclate_Deplace
                                    # Original Date	;  03 Juil 2009 version 0.0 (thx to TIG, Thomthom)
                                    # Type			;   Plugin
                                    # Description	;   Exploding movements of groups or/and components
                                    # Usage			;   Right Click - Context Menu
                                    # Version 0.3.2
                                    # petit plug d'explosion deplacement" de groupes ou de composants
                                    	require 'sketchup.rb'
                                    	def pilou_explose
                                    		myModel = Sketchup.active_model
                                    		myEntities = myModel.entities
                                    		selection = myModel.selection
                                    		if selection.empty?
                                    		    UI.messagebox "Veuillez Selectionner des\nComposants ou des Groupes"
                                    		myModel.start_operation "Deplacement Eclate",true
                                            group = myModel.active_entities.add_group(selection)
                                    		centre_selec = group.bounds.center
                                    		point_ligne = UI.messagebox "Voulez-matérialiser les déplacement \npar des points et des lignes de construction", MB_YESNO
                                            (point_ligne == 6) ? (myEntities.add_cpoint (centre_selec)) ;()
                                            resultat1 = UI.messagebox "Voulez vous faire une copie de l'original", MB_YESNO
                                    		if resultat1 == 6
                                    		    group2 = group.copy
                                    		    group2.explode
                                            selection = group.explode
                                            cent_selec_x = centre_selec[0].to_i   # determination
                                    		cent_selec_y = centre_selec[1].to_i   # du centre de
                                    		cent_selec_z = centre_selec[2].to_i   # la selection
                                           		prompts = ["Ecarter ou centrer/par rapport au pivot", "Deplacement pivot x", "Deplacement pivot y", "Deplacement pivot z", "Coef translation x de 0 a...", "Coef translation y de 0 a...", "Coef translation z de 0 a...", "Groupe Composant les 2"]
                                    		val_defaut = ["Centrer", cent_selec_x, cent_selec_y, cent_selec_z, 1.00, 1.00, 1.00, "Les 2"]
                                    		liste_val = ["Centrer|Ecarter", "", "", "", "", "", "" , "Groupe|Composant|Les 2"]
                                    		results = UI.inputbox prompts, val_defaut, liste_val, "Parametres"
                                    		return if not results
                                    		decent_pivot, deplac_pivot_x, deplac_pivot_y, deplac_pivot_z, coef_trans_x, coef_trans_y, coef_trans_z, group_ou_comp = results
                                            # Translation des axes suivant unites
                                            convertit = []
                                            convertit[0]= 1.inch
                                            convertit[1]= 1.feet
                                            convertit[2]= 1.mm
                                            convertit[3]= 1.cm
                                            convertit[4]= 1.m/100
                                            uniteCourante = myModel.options["UnitsOptions"]["LengthUnit"]
                                            coef_trans_x = coef_trans_x.to_f * convertit[uniteCourante]
                                            coef_trans_y = coef_trans_y.to_f * convertit[uniteCourante]
                                            coef_trans_z = coef_trans_z.to_f * convertit[uniteCourante]
                                            # Calcul de la distance entre le centre d'origine de la selection et le nouveau
                                            nouv_pivot_x =  cent_selec_x-deplac_pivot_x
                                            nouv_pivot_y =  cent_selec_y-deplac_pivot_y
                                            nouv_pivot_z =  cent_selec_z-deplac_pivot_z
                                            case decent_pivot
                                                 when "Ecarter"
                                                      myEntities.add_cpoint [(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]
                                                      myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]) ; ()
                                                 when "Centrer"
                                                     nouv_pivot_x =  - nouv_pivot_x
                                        		     nouv_pivot_y =  - nouv_pivot_y
                                        		     nouv_pivot_z =  - nouv_pivot_z
                                        		     myEntities.add_cpoint [deplac_pivot_x,deplac_pivot_y,deplac_pivot_z]
                                        		     myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[deplac_pivot_x, deplac_pivot_y, deplac_pivot_z]) ; ()
                                            case group_ou_comp
                                                when "Groupe"
                                                    group_ou_comp = comp_ou_group = Sketchup;;Group
                                                when "Composant"
                                                    group_ou_comp = comp_ou_group = Sketchup;;ComponentInstance
                                                else
                                    	           group_ou_comp = Sketchup;;Group
                                    		selection.each do |e| # debut de la transformation
                                    			next unless (e.is_a? group_ou_comp) or next unless(e.is_a? comp_ou_group)
                                    			centre_objet = e.bounds.center
                                    			centre_objet_x = centre_objet[0].to_i  # Determination
                                    			centre_objet_y = centre_objet[1].to_i  # du centre
                                    			centre_objet_z = centre_objet[2].to_i  # de l'objet
                                               (centre_objet_x == cent_selec_x) ? (nouv_centobj_x = nouv_pivot_x) ; (nouv_centobj_x = ((centre_objet_x-cent_selec_x) * coef_trans_x) + nouv_pivot_x)
                                               (centre_objet_y == cent_selec_y) ? (nouv_centobj_y = nouv_pivot_y) ; (nouv_centobj_y = ((centre_objet_y-cent_selec_y) * coef_trans_y) + nouv_pivot_y)
                                               (centre_objet_z == cent_selec_z) ? (nouv_centobj_z = nouv_pivot_z) ; (nouv_centobj_z = ((centre_objet_z-cent_selec_z) * coef_trans_z) + nouv_pivot_z)
                                                point_trans = Geom;;Point3d.new nouv_centobj_x,nouv_centobj_y,nouv_centobj_z
                                                t = Geom;;Transformation.new point_trans
                                                e.transform!(t)
                                                nouv_centobj = e.bounds.center
                                    			myEntities.add_cpoint (nouv_centobj)
                                    			myEntities.add_cpoint (centre_objet)
                                    			constline = myEntities.add_cline [centre_objet_x, centre_objet_y, centre_objet_z],nouv_centobj
                                    			constline.stipple = ".") ; ()
                                    			myModel.selection.add e
                                    		myModel.commit_operation
                                    	end # pilou_explose
                                    	if( not file_loaded?("Eclate_Deplace.rb") )
                                            UI.add_context_menu_handler do |context_menu|
                                    	       context_menu.add_separator
                                    	       context_menu.add_item("Eclate_Deplace") { pilou_explose }
                                            file_loaded("Eclate_Deplace.rb")
                                    Christophe
                                      No problem 😄
                                      Idea 💭 Pilou for training Ruby 5%
                                      Realisation Ruby C.Plassais 95%
                                      • BoxB Offline
                                        I'm using the latest version of sketchup and I get a bug splat every time I try to use Eclate.
                                        Even with a simple cube. As soon as you click yes or no on the copy dialog it shuts down and goes to bug splat.
                                          c.plassais
                                          you should only use Eclate_Deplace with components or groups
                                            kyyu
                                            It doesn't bug splat for me, but I am still using SU v7.0.10247. It doesn't do much with that file either, except add one guide point?
                                            I tried it on an ungrouped 3D pushpulled rectangle and also not bug splat. So could be something not compatable with the latest version of sketchup.
                                            • 2 / 9
