    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 253.1k Views 51 Watching
      [url]some groups stay glued[/url]
      The explosion is made by level by level of grouped elements
      not compatible with the latest SU?
      Normally no reason for that 😄
      Have you a file for test it?
      • C
        c.plassais
        Hi all,
        just a little precision
        plugin Pilou ➡
        model = Sketchup.active_model
        entities = model.entities
        selection = model.selection
        xp=100  # Pivot Point (as you want)
        yp=100
        zp=100
        q=50 # Measure of translation (as you want)
        selection.each do |e| # update!
          # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
          next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
        center = e.bounds.center #Center Point of the grouped object
           xc= center.x
           yc= center.y
           zc= center.z
        xe=xc #End Point of the grouped object
        ye=yc
        ze=zc
        if xc<xp
        xe =xc - q
        if xc>xp
        xe =xc + q
        if yc<yp
        ye =yc - q
        if yc>yp
        ye =yc + q
        if zc<zp
        ze =zc - q
        if zc>zp
        ze =zc + q
          point = Geom;;Point3d.new xe,ye,ze
          t = Geom;;Transformation.new point
          # Apply the transformation
          e.transform!(t)
        plugin modified by me ➡
        # Designed December 2009 by C.plassais + Pilou
        # Permission to use this software for any purpose and without fee is hereby granted
        # Distribution of this software for commercial purpose is forbidden;
        # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
        # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
        # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
        # Name			;   Eclate_Deplace
        # Original Date	;  03 Juil 2009 version 0.0 (thx to TIG, Thomthom)
        # Type			;   Plugin
        # Description	;   Exploding movements of groups or/and components
        # Usage			;   Right Click - Context Menu
        # Version 0.3.2
        # petit plug d'explosion deplacement" de groupes ou de composants
        	require 'sketchup.rb'
        	def pilou_explose
        		myModel = Sketchup.active_model
        		myEntities = myModel.entities
        		selection = myModel.selection
        		if selection.empty?
        		    UI.messagebox "Veuillez Selectionner des\nComposants ou des Groupes"
        		myModel.start_operation "Deplacement Eclate",true
                group = myModel.active_entities.add_group(selection)
        		centre_selec = group.bounds.center
        		point_ligne = UI.messagebox "Voulez-matérialiser les déplacement \npar des points et des lignes de construction", MB_YESNO
                (point_ligne == 6) ? (myEntities.add_cpoint (centre_selec)) ;()
                resultat1 = UI.messagebox "Voulez vous faire une copie de l'original", MB_YESNO
        		if resultat1 == 6
        		    group2 = group.copy
        		    group2.explode
                selection = group.explode
                cent_selec_x = centre_selec[0].to_i   # determination
        		cent_selec_y = centre_selec[1].to_i   # du centre de
        		cent_selec_z = centre_selec[2].to_i   # la selection
               		prompts = ["Ecarter ou centrer/par rapport au pivot", "Deplacement pivot x", "Deplacement pivot y", "Deplacement pivot z", "Coef translation x de 0 a...", "Coef translation y de 0 a...", "Coef translation z de 0 a...", "Groupe Composant les 2"]
        		val_defaut = ["Centrer", cent_selec_x, cent_selec_y, cent_selec_z, 1.00, 1.00, 1.00, "Les 2"]
        		liste_val = ["Centrer|Ecarter", "", "", "", "", "", "" , "Groupe|Composant|Les 2"]
        		results = UI.inputbox prompts, val_defaut, liste_val, "Parametres"
        		return if not results
        		decent_pivot, deplac_pivot_x, deplac_pivot_y, deplac_pivot_z, coef_trans_x, coef_trans_y, coef_trans_z, group_ou_comp = results
                # Translation des axes suivant unites
                convertit = []
                convertit[0]= 1.inch
                convertit[1]= 1.feet
                convertit[2]= 1.mm
                convertit[3]= 1.cm
                convertit[4]= 1.m/100
                uniteCourante = myModel.options["UnitsOptions"]["LengthUnit"]
                coef_trans_x = coef_trans_x.to_f * convertit[uniteCourante]
                coef_trans_y = coef_trans_y.to_f * convertit[uniteCourante]
                coef_trans_z = coef_trans_z.to_f * convertit[uniteCourante]
                # Calcul de la distance entre le centre d'origine de la selection et le nouveau
                nouv_pivot_x =  cent_selec_x-deplac_pivot_x
                nouv_pivot_y =  cent_selec_y-deplac_pivot_y
                nouv_pivot_z =  cent_selec_z-deplac_pivot_z
                case decent_pivot
                     when "Ecarter"
                          myEntities.add_cpoint [(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]
                          myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]) ; ()
                     when "Centrer"
                         nouv_pivot_x =  - nouv_pivot_x
            		     nouv_pivot_y =  - nouv_pivot_y
            		     nouv_pivot_z =  - nouv_pivot_z
            		     myEntities.add_cpoint [deplac_pivot_x,deplac_pivot_y,deplac_pivot_z]
            		     myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[deplac_pivot_x, deplac_pivot_y, deplac_pivot_z]) ; ()
                case group_ou_comp
                    when "Groupe"
                        group_ou_comp = comp_ou_group = Sketchup;;Group
                    when "Composant"
                        group_ou_comp = comp_ou_group = Sketchup;;ComponentInstance
                    else
        	           group_ou_comp = Sketchup;;Group
        		selection.each do |e| # debut de la transformation
        			next unless (e.is_a? group_ou_comp) or next unless(e.is_a? comp_ou_group)
        			centre_objet = e.bounds.center
        			centre_objet_x = centre_objet[0].to_i  # Determination
        			centre_objet_y = centre_objet[1].to_i  # du centre
        			centre_objet_z = centre_objet[2].to_i  # de l'objet
                   (centre_objet_x == cent_selec_x) ? (nouv_centobj_x = nouv_pivot_x) ; (nouv_centobj_x = ((centre_objet_x-cent_selec_x) * coef_trans_x) + nouv_pivot_x)
                   (centre_objet_y == cent_selec_y) ? (nouv_centobj_y = nouv_pivot_y) ; (nouv_centobj_y = ((centre_objet_y-cent_selec_y) * coef_trans_y) + nouv_pivot_y)
                   (centre_objet_z == cent_selec_z) ? (nouv_centobj_z = nouv_pivot_z) ; (nouv_centobj_z = ((centre_objet_z-cent_selec_z) * coef_trans_z) + nouv_pivot_z)
                    point_trans = Geom;;Point3d.new nouv_centobj_x,nouv_centobj_y,nouv_centobj_z
                    t = Geom;;Transformation.new point_trans
                    e.transform!(t)
                    nouv_centobj = e.bounds.center
        			myEntities.add_cpoint (nouv_centobj)
        			myEntities.add_cpoint (centre_objet)
        			constline = myEntities.add_cline [centre_objet_x, centre_objet_y, centre_objet_z],nouv_centobj
        			constline.stipple = ".") ; ()
        			myModel.selection.add e
        		myModel.commit_operation
        	end # pilou_explose
        	if( not file_loaded?("Eclate_Deplace.rb") )
                UI.add_context_menu_handler do |context_menu|
        	       context_menu.add_separator
        	       context_menu.add_item("Eclate_Deplace") { pilou_explose }
                file_loaded("Eclate_Deplace.rb")
        Christophe
          No problem 😄
          Idea 💭 Pilou for training Ruby 5%
          Realisation Ruby C.Plassais 95%
          • BoxB
            I'm using the latest version of sketchup and I get a bug splat every time I try to use Eclate.
            Even with a simple cube. As soon as you click yes or no on the copy dialog it shuts down and goes to bug splat.
            • C
              c.plassais
              you should only use Eclate_Deplace with components or groups
              • K
                kyyu
                Anyone experiencing Bugsplats with SU7.1 and this plugin?
                Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                I know i have the components nested in a component but use this plugin when not nested
                It doesn't bug splat for me, but I am still using SU v7.0.10247. It doesn't do much with that file either, except add one guide point?
                I tried it on an ungrouped 3D pushpulled rectangle and also not bug splat. So could be something not compatable with the latest version of sketchup.
                  @kyyu said:
                  ... It doesn't do much with that file either, except add one guide point?
                  Why would you use it on an "ungrouped 3D push/pulled rectangle"? The plugin is intended to move components away from each other to create an exploded view of this sort.
                  http://farm5.static.flickr.com/4023/4628792635_15716dcc29.jpg
                  • K
                    kyyu
                    Because a few post up, Box said he was getting bug splats on everything; even with a simple cube. So I tested it, but maybe he meant a cube made of grouped sides? Anyways, I was checking for bug splats and didn't find any. But, like I noted, I'm using v7.0 of sketchup.
                    • BoxB
                      Yes I was using a cube of grouped faces, and at first I was getting a bug spat every time, now it is random.
                      I have rebooted and added updates and a few other bits and pieces since then, sorry that's not a very useful bit of diagnostic information but I've been doing too many things at once.
                      So to put it simply, It does work for me but it is unstable and I have yet to work out what, if any, conditions cause the bug splat.
                      • C
                        c.plassais
                        Two versions of the plugin that can be corrected bug
                        I've written a 3.0.2 version and also a rewritten version by the genius Fredo. Thanks Fredo 👍
                        Sorry I can not insert in the original post ...
                        The limitation of this plugin is that it does not take into account the size of groups or components.
                        It moves only the elements from their center. Perhaps a future version
                        Christophe
                        Eclate_Deplace english version 3.0.2
                        version 3.0.2 rewritten by fredo ChrisP_RadialMove
                          Added to the first post 😉
                          • C
                            c.plassais
                            Thank Pilou 👍
                              dedmin
                              • V
                                vidy
                                dear guys,
                                is there any possibility of this plugin have crashed with other plugin?
                                ok, here is what i did:
                                1. i copy the newest version 3.0.2
                                2. then rename it so its just Eclate_Deplace.rb
                                3. i create simple cube, and then group it
                                4. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                                http://a.imageshack.us/img829/1341/eclatedeplaceprob01.jpg
                                please,somebody help me to solved this issue, thank you.. ❓
                                regards,
                                still so much to learn..
                                  Finally it's back working 👍
                                  Thanks Pilou....C.Plassais....TIG....Thomthom....Chris Fullmer....Fredo!
                                  Hope i left no one out?
                                    Maybe cats and dogs and birds...
                                    It's a big familly 😆
                                      About
                                      Facegroup by Gavvy (seems there a is little problem with this facegroup plugin) Thomthom is look it! and seems found the error ☀
                                      And I have found another one who works 😉
                                      Make_components by Matt666 at Crai Ruby depot!
                                      And a third solution by Tig! (face selected ---> groups)
                                      Put this in the Ruby console! ☀
                                      m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                                      • V
                                        vidy
                                        thanks pilou for the fast reply, i will try it and report it soon..
                                        regards,
                                          With newest version 3.0.2
                                          I don't believe that
                                          1. i create simple cube, and then group it
                                          2. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                                          Normal : a simple cube must be composed of a 6 faces themself a group!!!
                                          (so for a cube: 6 faces who are each a group) !
                                          in this image i have selected one face for you show that is a group
                                          (each face is a group)
                                          Select them then call the plug!
                                          If you want transform automatically each 6 faces of a simple cube on 6 groups maybe exist a plug 😉
                                          (or any faces selected)
                                          Facegroup by Gavvy (seems there a little problem with this facegroup plugin) Thomthom is look it!
                                          Make_components by Matt666 at Crai Ruby depot! ☀
                                          Ps Menu of "Radial Move" or "Eclate_displace" Appear by Right Click on the selection of the groups or components!
                                          • Y
                                            yvan79
                                            How do you use the ChrisP_RadialMove_EN.rb plugin? can anyone show an example?
                                            • 3 / 9
