    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 253.1k Views 51 Watching
      Is this plugin not compatible with the latest SU? Pilou if you've time can you look?
      It is behaving strangely with mixed results.
        dtrarch
        Also see Smustard for Todd Burch's ExplodeImplode script.
        Works OK with SU 7.1 and older.
        dtr
          [url]some groups stay glued[/url]
          The explosion is made by level by level of grouped elements
          Normally no reason for that 😄
          Have you a file for test it?
          • C
            c.plassais
            Hi all,
            just a little precision
            plugin Pilou ➡
            model = Sketchup.active_model
            entities = model.entities
            selection = model.selection
            xp=100  # Pivot Point (as you want)
            yp=100
            zp=100
            q=50 # Measure of translation (as you want)
            selection.each do |e| # update!
              # Skip all entities that aren't groups or components (replace follow "ComponentInstance" by "Group" if you have groups
              next unless e.is_a? Sketchup;;ComponentInstance  # Now we process the component or group
            center = e.bounds.center #Center Point of the grouped object
               xc= center.x
               yc= center.y
               zc= center.z
            xe=xc #End Point of the grouped object
            ye=yc
            ze=zc
            if xc<xp
            xe =xc - q
            if xc>xp
            xe =xc + q
            if yc<yp
            ye =yc - q
            if yc>yp
            ye =yc + q
            if zc<zp
            ze =zc - q
            if zc>zp
            ze =zc + q
              point = Geom;;Point3d.new xe,ye,ze
              t = Geom;;Transformation.new point
              # Apply the transformation
              e.transform!(t)
            plugin modified by me ➡
            # Designed December 2009 by C.plassais + Pilou
            # Permission to use this software for any purpose and without fee is hereby granted
            # Distribution of this software for commercial purpose is forbidden;
            # THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
            # IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
            # WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
            # Name			;   Eclate_Deplace
            # Original Date	;  03 Juil 2009 version 0.0 (thx to TIG, Thomthom)
            # Type			;   Plugin
            # Description	;   Exploding movements of groups or/and components
            # Usage			;   Right Click - Context Menu
            # Version 0.3.2
            # petit plug d'explosion deplacement" de groupes ou de composants
            	require 'sketchup.rb'
            	def pilou_explose
            		myModel = Sketchup.active_model
            		myEntities = myModel.entities
            		selection = myModel.selection
            		if selection.empty?
            		    UI.messagebox "Veuillez Selectionner des\nComposants ou des Groupes"
            		myModel.start_operation "Deplacement Eclate",true
                    group = myModel.active_entities.add_group(selection)
            		centre_selec = group.bounds.center
            		point_ligne = UI.messagebox "Voulez-matérialiser les déplacement \npar des points et des lignes de construction", MB_YESNO
                    (point_ligne == 6) ? (myEntities.add_cpoint (centre_selec)) ;()
                    resultat1 = UI.messagebox "Voulez vous faire une copie de l'original", MB_YESNO
            		if resultat1 == 6
            		    group2 = group.copy
            		    group2.explode
                    selection = group.explode
                    cent_selec_x = centre_selec[0].to_i   # determination
            		cent_selec_y = centre_selec[1].to_i   # du centre de
            		cent_selec_z = centre_selec[2].to_i   # la selection
                   		prompts = ["Ecarter ou centrer/par rapport au pivot", "Deplacement pivot x", "Deplacement pivot y", "Deplacement pivot z", "Coef translation x de 0 a...", "Coef translation y de 0 a...", "Coef translation z de 0 a...", "Groupe Composant les 2"]
            		val_defaut = ["Centrer", cent_selec_x, cent_selec_y, cent_selec_z, 1.00, 1.00, 1.00, "Les 2"]
            		liste_val = ["Centrer|Ecarter", "", "", "", "", "", "" , "Groupe|Composant|Les 2"]
            		results = UI.inputbox prompts, val_defaut, liste_val, "Parametres"
            		return if not results
            		decent_pivot, deplac_pivot_x, deplac_pivot_y, deplac_pivot_z, coef_trans_x, coef_trans_y, coef_trans_z, group_ou_comp = results
                    # Translation des axes suivant unites
                    convertit = []
                    convertit[0]= 1.inch
                    convertit[1]= 1.feet
                    convertit[2]= 1.mm
                    convertit[3]= 1.cm
                    convertit[4]= 1.m/100
                    uniteCourante = myModel.options["UnitsOptions"]["LengthUnit"]
                    coef_trans_x = coef_trans_x.to_f * convertit[uniteCourante]
                    coef_trans_y = coef_trans_y.to_f * convertit[uniteCourante]
                    coef_trans_z = coef_trans_z.to_f * convertit[uniteCourante]
                    # Calcul de la distance entre le centre d'origine de la selection et le nouveau
                    nouv_pivot_x =  cent_selec_x-deplac_pivot_x
                    nouv_pivot_y =  cent_selec_y-deplac_pivot_y
                    nouv_pivot_z =  cent_selec_z-deplac_pivot_z
                    case decent_pivot
                         when "Ecarter"
                              myEntities.add_cpoint [(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]
                              myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[(cent_selec_x + nouv_pivot_x), (cent_selec_y + nouv_pivot_y), (cent_selec_z + nouv_pivot_z)]) ; ()
                         when "Centrer"
                             nouv_pivot_x =  - nouv_pivot_x
                		     nouv_pivot_y =  - nouv_pivot_y
                		     nouv_pivot_z =  - nouv_pivot_z
                		     myEntities.add_cpoint [deplac_pivot_x,deplac_pivot_y,deplac_pivot_z]
                		     myEntities.add_cline [cent_selec_x, cent_selec_y, cent_selec_z],[deplac_pivot_x, deplac_pivot_y, deplac_pivot_z]) ; ()
                    case group_ou_comp
                        when "Groupe"
                            group_ou_comp = comp_ou_group = Sketchup;;Group
                        when "Composant"
                            group_ou_comp = comp_ou_group = Sketchup;;ComponentInstance
                        else
            	           group_ou_comp = Sketchup;;Group
            		selection.each do |e| # debut de la transformation
            			next unless (e.is_a? group_ou_comp) or next unless(e.is_a? comp_ou_group)
            			centre_objet = e.bounds.center
            			centre_objet_x = centre_objet[0].to_i  # Determination
            			centre_objet_y = centre_objet[1].to_i  # du centre
            			centre_objet_z = centre_objet[2].to_i  # de l'objet
                       (centre_objet_x == cent_selec_x) ? (nouv_centobj_x = nouv_pivot_x) ; (nouv_centobj_x = ((centre_objet_x-cent_selec_x) * coef_trans_x) + nouv_pivot_x)
                       (centre_objet_y == cent_selec_y) ? (nouv_centobj_y = nouv_pivot_y) ; (nouv_centobj_y = ((centre_objet_y-cent_selec_y) * coef_trans_y) + nouv_pivot_y)
                       (centre_objet_z == cent_selec_z) ? (nouv_centobj_z = nouv_pivot_z) ; (nouv_centobj_z = ((centre_objet_z-cent_selec_z) * coef_trans_z) + nouv_pivot_z)
                        point_trans = Geom;;Point3d.new nouv_centobj_x,nouv_centobj_y,nouv_centobj_z
                        t = Geom;;Transformation.new point_trans
                        e.transform!(t)
                        nouv_centobj = e.bounds.center
            			myEntities.add_cpoint (nouv_centobj)
            			myEntities.add_cpoint (centre_objet)
            			constline = myEntities.add_cline [centre_objet_x, centre_objet_y, centre_objet_z],nouv_centobj
            			constline.stipple = ".") ; ()
            			myModel.selection.add e
            		myModel.commit_operation
            	end # pilou_explose
            	if( not file_loaded?("Eclate_Deplace.rb") )
                    UI.add_context_menu_handler do |context_menu|
            	       context_menu.add_separator
            	       context_menu.add_item("Eclate_Deplace") { pilou_explose }
                    file_loaded("Eclate_Deplace.rb")
            Christophe
              No problem 😄
              Idea 💭 Pilou for training Ruby 5%
              Realisation Ruby C.Plassais 95%
              • BoxB
                I'm using the latest version of sketchup and I get a bug splat every time I try to use Eclate.
                Even with a simple cube. As soon as you click yes or no on the copy dialog it shuts down and goes to bug splat.
                • C
                  c.plassais
                  you should only use Eclate_Deplace with components or groups
                  • K
                    kyyu
                    Anyone experiencing Bugsplats with SU7.1 and this plugin?
                    Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                    I know i have the components nested in a component but use this plugin when not nested
                    It doesn't bug splat for me, but I am still using SU v7.0.10247. It doesn't do much with that file either, except add one guide point?
                    I tried it on an ungrouped 3D pushpulled rectangle and also not bug splat. So could be something not compatable with the latest version of sketchup.
                      @kyyu said:
                      ... It doesn't do much with that file either, except add one guide point?
                      Why would you use it on an "ungrouped 3D push/pulled rectangle"? The plugin is intended to move components away from each other to create an exploded view of this sort.
                      http://farm5.static.flickr.com/4023/4628792635_15716dcc29.jpg
                      • K
                        kyyu
                        Because a few post up, Box said he was getting bug splats on everything; even with a simple cube. So I tested it, but maybe he meant a cube made of grouped sides? Anyways, I was checking for bug splats and didn't find any. But, like I noted, I'm using v7.0 of sketchup.
                        • BoxB
                          Yes I was using a cube of grouped faces, and at first I was getting a bug spat every time, now it is random.
                          I have rebooted and added updates and a few other bits and pieces since then, sorry that's not a very useful bit of diagnostic information but I've been doing too many things at once.
                          So to put it simply, It does work for me but it is unstable and I have yet to work out what, if any, conditions cause the bug splat.
                          • C
                            c.plassais
                            Two versions of the plugin that can be corrected bug
                            I've written a 3.0.2 version and also a rewritten version by the genius Fredo. Thanks Fredo 👍
                            Sorry I can not insert in the original post ...
                            The limitation of this plugin is that it does not take into account the size of groups or components.
                            It moves only the elements from their center. Perhaps a future version
                            Christophe
                            Eclate_Deplace english version 3.0.2
                            version 3.0.2 rewritten by fredo ChrisP_RadialMove
                              Added to the first post 😉
                              • C
                                c.plassais
                                Thank Pilou 👍
                                  dedmin
                                  • V
                                    vidy
                                    dear guys,
                                    is there any possibility of this plugin have crashed with other plugin?
                                    ok, here is what i did:
                                    1. i copy the newest version 3.0.2
                                    2. then rename it so its just Eclate_Deplace.rb
                                    3. i create simple cube, and then group it
                                    4. when i right click on the group and choose eclate_deplace, no dialog box showed up and i got this messages
                                    http://a.imageshack.us/img829/1341/eclatedeplaceprob01.jpg
                                    please,somebody help me to solved this issue, thank you.. ❓
                                    regards,
                                    still so much to learn..
                                      Finally it's back working 👍
                                      Thanks Pilou....C.Plassais....TIG....Thomthom....Chris Fullmer....Fredo!
                                      Hope i left no one out?
                                        Maybe cats and dogs and birds...
                                        It's a big familly 😆
                                          About
                                          Facegroup by Gavvy (seems there a is little problem with this facegroup plugin) Thomthom is look it! and seems found the error ☀
                                          And I have found another one who works 😉
                                          Make_components by Matt666 at Crai Ruby depot!
                                          And a third solution by Tig! (face selected ---> groups)
                                          Put this in the Ruby console! ☀
                                          m=Sketchup.active_model;n=m.active_entities;m.selection.to_a.each{|e|n.add_group(e)if e.class==Sketchup;;Face}
                                          • V
                                            vidy
                                            thanks pilou for the fast reply, i will try it and report it soon..
                                            regards,
                                            • 3 / 9
