    Bonzai 2.0 released
    extensions
    215 Posts 28 Posters 60.7k Views 28 Watching
      @chris fullmer said:
      PS: is there an API for bonzai 3d?
      http://www.formz.com/forum/discus41/messages/35952/41004.html?1266516023#POST83468
      Thom,
      The formZ SDK lets you create both. The bonzai SDK is still being finalized but it should be very similar to the current formz SDK.
      Thom,
      Let us clarify the original post:
      Bonzai3d can run plug-ins written in formZ's sdk and calling functions that are available in b3d. In practical terms this means that if you want to create a plugin for b3d you have to write it in formZ. Our initial intention was (and still is) to not include an API (SDK) in bonzai, as it is intended to be a simpler application than formZ. However, we may reconsider this.
      For your information, formZ has both an API and a script language. They are both C-like.
      I see. Is it just compiled plugins that run on B3D, or also scripts?
      Thomas,
      Sorry for the delay in responding. We now have your answer:
      Bonzai3d currently supports Plugins (and many of its components -- such as the file translators, RenderZone, etc) are currently running as plugins. Adding the ability to run scripts as well is high on our priority list, and this will be added in the future.
      πŸ˜„ New toy!
        tomasz
        Now they are talking! πŸ˜„
          tfdesign
          You B3D/ formZ folk, don't overlook Russian based Ledas' Parametric plugin and engine either! Parametric ability would be something really great, you would have beaten SpaceClaim (although I highly suspect that SC is a bit of a formZ clone), to a Mac version of the software.
            bonzai3d support
            Andrew,
            Yes, we are "pushing hard" to make bonzai3d the best that it can be!
            Rich,
            Thanks for sharing your experiences so far. Bonzai3d should be quite easy to use, but does offer a lot more than SU does, and the interface is a little different, but as you have noted, if you give it a bit of a chance, you should be able to pick up on it fairly quickly.
            Thanks also for your congratulations! f you find that the 30 day trial is not enough for you to fully evaluate all the capabilities of boznai3d, please send us an email (support@bonzai3d.com) and we will see what we can do to get you an extension to your trial.
            Thom,
            Thanks for answering the API questions for us. We hope to have the full details for this available soon.
            Tom,
            Thanks for the suggestion regarding "Ledas." (Yes, we are aware of them...) πŸ˜„
            Please keep all your comments and feedback coming. We are always interested in your opinions, and we are working hard to add as many new capabilities and features as we can!
            Explore * Design * Deliver
            http://www.bonzai3d.com
            Version 2.5 Now Available!
              tfdesign
              @bonzai3d support said:
              Tom,
              Yes, Dimitry seems like a very pleasant and approachable chap. It's really nice to know that there is finally another 3D parametric kernel out there, ready to take on the likes of Spatial and Parasolid. πŸ˜„
              • soloS Offline
                Hey guys, anyone done any UV mapping with Bonsai yet?
                I need to map a chair cover for an SU model, I have seen the video tutorial but I'm still lost, seems that he has edit windows that I cannot find, the tutorial jumps to an edit applet without showing where in the world one finds it.
                So, my question is... anyone got a tutorial or explanation on how to import an SU model and map UV's correctly then back into SU?
                  Hi Pete,
                  I've been trying the same but seems that it's not a feature. 'Texture Mapping' seems what is associated with Bonzai3d. Here's what CG Forum members say...
                  no UV editor. but if you are working in nurbs it does map correctly to curved surfaces. you can see a video about it here:
                  (www.bonzai3d.com)
                  look for "texture mapping"
                  if you figure it out or any member does, please post there solution.
                  What's your opinion so far Pete?
                  • soloS Offline
                    I guess you are right, parametric mapping (which I need) only works with Nurbs, the problem is the cushion is modeled with SU and once imported you are limited to what UV mapping you can do.
                    I will need to use Vue as it can kinda achieve a result that is okay (not great).
                    So far I like Bonsai, I have not had enough practice to give a detailed review, but I think that once I get familiar with where everything is and what does what then I should start loving it as it's got all the bells and whistles.
                      dedmin
                      The default GUI font doesn't support Cyrillic names. I had to choose a Cyrillic font so see it properly.
                      • X Offline
                        xrok1
                        Pete, Rich... check pages 176 through 18? in the manual to see if this helps you.
                        from page 176:
                        The default texture mapping assignments can be changed and edited with two tools. The Map Texture tool allows you to assign a different mapping type to an object or its face. The Edit Texture tool is used to interactively adjust the orientation and size of the texture.
                        • soloS Offline
                          Rocky, Ive seen that and used both those options, they let you orientate, scale and even change the mapping from planar to cylindrical and spherical, what I really need is Parametric which is only an available option for a Bonsai created nurb shape.
                          • X Offline
                            xrok1
                            did you try changing the mapping type to UV coordinates from the edit tool?
                            not sure what you mean by parametric? you want all faces joined when you edit? the method in this .jpg seems to work for that.
                            • X Offline
                              xrok1
                              Solo, can you explain the attraction to parametric texture mapping? as you can see i mapped this cylinder parametrically and its fubar so i can't seem to see any advantages.
                              • soloS Offline
                                Rocky, Parametric mapping is for organic shapes, for tube shapes use the cylindrical mapping.
                                • X Offline
                                  xrok1
                                  ah... the UV coordinate mapping seems to be about the closest. have you tried that?
                                    toxicvoxel
                                    Unless the blokes over at SU HQ wake up and smell the coffee they will lose their professional design user core.
                                    (But then do they even care? With the new Bing Augmented Reality looming even more focus may be concentrated on GE support rather than design functionality in Sketchup.)
                                      bonzai3d support
                                      Gentlemen,
                                      Sorry for the delay in replying back to your questions and comments. Due to popular demand, we have been extremely busy answering all the emails and phone calls that we are receiving directly (at support@bonzai3d.com, or 614 488-8838). We shall try to keep a closer eye on your discussions so we can help or respond a little more quickly in the future!
                                      (Feel free to contact us directly if you have any urgent needs...)
                                      Solo,
                                      Yes, Parametric mapping is for Nurbs objects in bonzai3d -- so if you created this in bonzai3d, mapping it would be pretty straightforward, but if you create the geometry with SketchUp, then you are pretty limited with what you can do with it.
                                      Also, with UV mapping, you typically assign the desired mapping type first (ie, Flat, Cubic, Spherical...) and then set it to UV. Then when you adjust the geometry, the mapping is locked to the surfaces and will "stretch" accordingly if the shape is adjusted non-uniformly.
                                      Dedmin,
                                      We do not understand exactly what you are saying regarding Cyrillic names. Can you please clarify?
                                      ToxicVoxel,
                                      I am having my coffee right now and it smells pretty good. πŸ˜„
                                      We plan to continue aggressive development to give designers the best possible 3d tools to realize their projects. Please check out our tutorial videos, give out Trial version a chance, and let us know what you think!
                                      Tutorial videos: http://www.formz.com/products/bonzai3d/bonzai3dVideo_320.php?startMovie=Interface_320.flv
                                      Feature videos: http://www.formz.com/products/bonzai3d/bonzai3dFeatures.html
                                      Free Trial: http://www.formz.com/products/bonzai3d/bonzai3dTrial.html
                                      All our best!
                                        dedmin
                                        Copy and paste this into Bonzai3D as a name of object, layer or scene:
                                        страница
                                          bonzai3d support
                                          Dedmin,
                                          Yes, thanks for clarifying. We have now reproduced this and we will get it corrected. As you note, selecting a Cyrillic font is a way to work around this.
                                          Please let us know if there is anything further. πŸ˜„
                                            dedmin
                                            It depends at what You are doing. For me the community is very important. For instance, I needed a way to incremental rename a lot of components and asked for a script and I had it in an hour thanks to TIG! For small woodworking, melamine and MDF furniture SketchUp is perfect - there are FredoScale,CutList,Dovetails and bunch of other plugins to do the job!
                                            • 11
                                            • 9 / 11
