    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      @diego-rodriguez said:
      hi fredo.
      a query.
      in this plugin, the inferences do not work correctly.
      in the first segment, generally work well (inferences, color axis)
      the second segment, with some work tools and other tools do not work.
      in the third segment, inferences generally do not work or the color of the axes.
      and does not block the inference to press the shift key
      that's normal? or is an error in my computer?
      if not normal, it might solve?
      Thank you very much
      This plugin needs a serious refresh (this was my first one), in particular for the inference management, tangent positioining and some other additional features.
      So your computer is innocent!
      Fred
      • T
        tulacong
        thank you 😍
          mm5949
          hi fredo.
          a query.
          Thank you very much
          Fred
          So, should I download v1.3b, or should I wait for v.1.3c?
          If so, where can I find the download? I would like to try it.
          Thanks for your good work, 😄
          Mel
            jcoulter1890
            This tool looks amazing bit how do i actualy download it. Is there a link any1 can give me?
            • mitcorbM
              mitcorb
              @jcoulter:
              "Go to the first page of this post. Mouse over the target file. Right click. Select Save Link As.. Make sure that the window that pops up shows the file name and be sure that file type is Zip file. Save to destination, say desktop, or Google Sketchup Plugin subfolder. I prefer desktop so that it gets me out of suspense. Then I cut or copy to the plugin folder. Then it is a matter of unzipping the folder in place in the plugins.
              Also, be aware that you need the latest version of LibFredo, a helper file for the plugin. Do the same thing to download this one.
              Hope this helps.
              mitcorb
                agrazdi
                Whenever i try to use the Courbette comand the program always closes.
                Is it a Bug ?
                agrazdi
                • V
                  vrrroom
                  I (also) have the problem that only half the toolbar is displayed. The same within the top menu.
                  http://dl.dropbox.com/u/2399172/bezier1.png
                  http://dl.dropbox.com/u/2399172/bezier2.png
                  It was working fine the first few days after adding the plugin bundle. But today it was like this. I tried disable/enable, uninstall/install (with starting SketchUp in between), updated to the lastest version 3b. Same problem in SketchUp 6 and 7.
                  I really need the Cubic Curve tool for tracing a complicated bent line for work with a tight deadline. Anybody knows what to do?
                    rizal21
                    Great update, thanks FREDO6
                    • F
                      Ferroman
                      Hi folks, I'm new here and am getting boggled by the depth of the software and the community. I have been familiarizing myself with the BezierSpline plug in. I was very happy to find it as I've used Illustrator for years in my design work. What I need help with is that I am unable to put a face on the bezier forms I am drawing. I can select the line but there is no face. Can someone tell me how to do it? I have been trying for a few hours and I am flummoxed. Thanks, Ray
                        A curve will 'face' if all of its vertices are coplanar and it is looped [or at least connected to other edges so there are on open ends].
                        Draw over one of its edges and it should face.
                        If not try drawing a diagonal line across where the face should be - this can force a face - you should be able to erase the temporary line afterwards and the face should stay behind.
                        If not there are 'face-making' scripts - search for 'makefaces'....
                          DIEGO-RODRIGUEZ
                          hi fredo.
                          could you fix this little mistake?
                          thank you very much
                          Error: #<NameError: undefined local variable or method preserve' for BZ__Segmentor:Module> D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/BZ__Segmentor.rb:128:in calculate'
                          D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/BZ__Segmentor.rb:57:in bz_compute_curve' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:1995:in call'
                          D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:1995:in call_compute_curve' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2063:in conversion_curve'
                          D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2323:in compute_contextual_menu' D:/Archivos de programa/Google/Google SketchUp 7/Plugins/BZ_Dir_13/bezierspline_main.rb:2323:in call'
                            Diego
                            In the latest version of the file - that's download-able from the first post in this topic - the 'preserve' variable is 'commented out' with # ...
                            C:\Program Files\Google\Google SketchUp 7\Plugins\BZ_Dir_13\BZ__Segmentor.rb should have the word 'preserve' in it only twice [lines 86 and 128] - both times the line starts with a # to stop it loading...
                            Do you have the right version ?
                            If not, get it or add the two # yourself ?
                              DIEGO-RODRIGUEZ
                              TIG thanks.
                              now it works perfect.
                              • fredo6F
                                Thanks TIG for your help.
                                For info, the preserve variable is to have an option to keep the original control points, but for whatever reason I forgot to finish the code.
                                • H
                                  hsjzyangbin
                                  Hope to improve the function :control point along z axis
                                  maybe add "ctrl" key to control XY plan or z plan
                                  • fredo6F
                                    Do you mean you can do it or you wish to do it.
                                    Planar lock is supported in creation mode.
                                    Axis lock is also supported in Edition mode for th moving the control points.
                                    This is explained in the doc, using Ctrl and Arrows
                                    In a next version, I'll try to make something more explicit and straightforward however.
                                    • H
                                      hsjzyangbin
                                      I used Bonzai3d to do it .
                                      thanks a lot
                                      hsjzyangbin
                                      • H
                                        hsjzyangbin
                                        wish to have a visual interface control nodes of the function like YAD
                                        here is an example:
                                        best regards
                                          Daniel S
                                          here is an example:
                                          About visual interface control nodes... Something like this is possible? (Like most 2d Vector software)
                                          "A quadratic Bézier curve has a start and an end point (blue dots) and just one control point (red dot) while a cubic Bézier curve uses two control points."
                                          404 Not Found
                                          (www.caffeineowl.com)
                                          Daniel S
                                          • H
                                            hsjzyangbin
                                            @daniel s said:
                                            here is an example:
                                            [attachment=1:21zf7cs5]<!-- ia1 -->simulation.gif<!-- ia1 -->[/attachment:21zf7cs5]
                                            [attachment=2:21zf7cs5]<!-- ia2 -->bezier.png<!-- ia2 -->[/attachment:21zf7cs5]
                                            404 Not Found
                                            Daniel S
                                            maybe some difference:
                                            visual interface control number of nodes
                                            [flash=][attachment=0:21zf7cs5]<!-- ia0 -->2010-03-18_0456.swf<!-- ia0 -->[/attachment:21zf7cs5][/flash]
                                            thank you
                                            2010-03-18_0456.swf
                                            • 22
                                            • 23
                                            • 4 / 23
