    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 790.8k Views 175 Watching
      dedmin
        driven
        Hi Tig, more toys,,, excellent
        EEbyRailsbyFace isn't working on my Mac, and when I looked at the code, line 632 comments out all lines through to 693 which look important to me.
        might this be my issue?
        cheers
        • TIGT Online
          driven
          That code is legacy stiff from EEbyRails that I found I didn't ever need [yet] but I left it in but 'commented' out just in case - so that's not the problem...
          When you try it on your Mac what errors do you get in the in the Ruby Console ? πŸ˜•
            driven
            Error: #<NoMethodError: undefined method db' for #<Object:0x3f319f4>> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:359:in extrudeEdgesByFace'
            /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:463
            • TIGT Online
              Here's an updated zip file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
              It's issued because the EEbyFace tool had a simple typo in it that meant that whilst it didn't affect my testing of it, it did mess up some of you - it's been fixed in the latest zip file... Sorry for any inconvenience 😳
                driven
                no problem,
                I EExRxF is working although it does crash out if you do it wrong, and it is that one that wasn't even starting.
                I was looking at the code for both (to see what I was doing wrong) when I saw the comment-out bit, then I got mixed up which was in error...
                  driven
                  Working a treat..... cheers again
                  • TIGT Online
                    Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
                    I'll fix it and reissue a new zip... πŸ˜’
                    • TIGT Online
                      Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
                      Also minor speed improvements and the lingvo files updates.
                      Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
                      Feedback please πŸ€“
                        jessemorton24
                        Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
                        Cheers!
                        Parkways, Driveways, Gateways, Pathways...
                        • H Offline
                          haynesc
                          http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
                          Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
                          ... would help keep our plugins list smaller ...
                          • TIGT Online
                            Good idea - watch for next update....
                            • TIGT Online
                              Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                              It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                              πŸ€“
                                Ruturaj
                                Thank you TIG
                                GooD πŸ˜‰
                                Thanks,
                                RuturaJ
                                • TIGT Online
                                  EEbyRails and EEbyRailsByFace have been updated to avoid a rare glitch in the mesh/ribs caused by some helical rails turning so exactly at 180 degrees in some parts...
                                  • TIGT Online
                                    Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                    It has some minor tweaks to FR lingvo files [thanks Pilou] etc and a brand new Tool ExtrudeEdgesByFaces.
                                    You pick a face as a profile and then one rail [curve] - then a melding-profile-face [this could also be first face picked]. The location of the face(s) relative to the rail ends affects the final extruded form.
                                    It then forms a triangulated mesh based on these faces, melding from one face shape to the other, completing it with capped ends - there are then options to reverse/smooth etc - [its functionality is very similar to EEbyRails with a pinch of EEbyFace]...
                                    πŸ€“
                                    • H Offline
                                      Howard leslie
                                      TIG,
                                      Thank you so much for producing this FANTASTIC set of tools.
                                      Quite stunning.
                                      I do, however, have something for you to ponder....
                                      Will it be possible in the future to utilise Intermediate Profiles ???
                                      (See attached *.skp file)
                                      This would be EXTREMELY useful for producing models with a constantly changing cross section
                                      eg boat hulls, aircraft fuselages, certain storage tanks and vessels etc.
                                      This can be done at present with your "extrude edges by rails" (performed several times) - but the ability to utilise intermediate profiles would be brilliant.
                                      Thanks once again for all your hard work in producing this set of tools - and for combining them together in one toolbar.
                                      Regards
                                      Howard Leslie
                                      IntermediateProfiles.skp
                                      • TIGT Online
                                        The 'lofting by multiple profile selections' is on the list but I know Fredo also has lots up his sleeve too... πŸ€“
                                        • Y Offline
                                          yuelai
                                          hey,why cann't i download the attachment?
                                          • Y Offline
                                            yuelai
                                            somebody can help me please?
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 31
                                            • 32
                                            • 16 / 32
