    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 923.8k Views 175 Watching
      Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
      I'll fix it and reissue a new zip... πŸ˜’
        Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
        Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
        Also minor speed improvements and the lingvo files updates.
        Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
        Feedback please πŸ€“
          jessemorton24
          Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
          Cheers!
          Parkways, Driveways, Gateways, Pathways...
          • H Offline
            haynesc
            http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
            Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
            ... would help keep our plugins list smaller ...
              Good idea - watch for next update....
                Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                πŸ€“
                  Ruturaj
                  Thank you TIG
                  GooD πŸ˜‰
                  Thanks,
                  RuturaJ
                    EEbyRails and EEbyRailsByFace have been updated to avoid a rare glitch in the mesh/ribs caused by some helical rails turning so exactly at 180 degrees in some parts...
                      Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                      It has some minor tweaks to FR lingvo files [thanks Pilou] etc and a brand new Tool ExtrudeEdgesByFaces.
                      You pick a face as a profile and then one rail [curve] - then a melding-profile-face [this could also be first face picked]. The location of the face(s) relative to the rail ends affects the final extruded form.
                      It then forms a triangulated mesh based on these faces, melding from one face shape to the other, completing it with capped ends - there are then options to reverse/smooth etc - [its functionality is very similar to EEbyRails with a pinch of EEbyFace]...
                      πŸ€“
                      • H Offline
                        Howard leslie
                        TIG,
                        Thank you so much for producing this FANTASTIC set of tools.
                        Quite stunning.
                        I do, however, have something for you to ponder....
                        Will it be possible in the future to utilise Intermediate Profiles ???
                        (See attached *.skp file)
                        This would be EXTREMELY useful for producing models with a constantly changing cross section
                        eg boat hulls, aircraft fuselages, certain storage tanks and vessels etc.
                        This can be done at present with your "extrude edges by rails" (performed several times) - but the ability to utilise intermediate profiles would be brilliant.
                        Thanks once again for all your hard work in producing this set of tools - and for combining them together in one toolbar.
                        Regards
                        Howard Leslie
                        IntermediateProfiles.skp
                          The 'lofting by multiple profile selections' is on the list but I know Fredo also has lots up his sleeve too... πŸ€“
                          • Y Offline
                            yuelai
                            hey,why cann't i download the attachment?
                            • Y Offline
                              yuelai
                              somebody can help me please?
                              • Y Offline
                                yuelai
                                is this plugin for Skechtup6 or 7 vision?
                                  What are you trying to do exactly ?
                                  Simply click on the zip file link [ extrudeTools_yyyymmdd.zip- the file's suffix varies with the date of the last upload currently 20100219 ?], you can find it at the end of the first post in this thread, and then your browser should ask you what to do [varies with browser make]... download the zip file to your desktop, then follow the 'extraction' instructions etc...
                                  You MUST extract the files as directed - that is in their sub-folders as supplied in the zip - DON'T try to drag/drop them out of the zip's window it'll go wrong. Use 'extract[_all]' option in you zip application and they should keep their folders intact. The .rb files go directly into the Plugins folder BUT the rest of them go into a TIGtools folder inside Plugins and even sub-folders within that...
                                  πŸ€“
                                  PS: These plugins works with SUp v6 and v7.
                                    dylan
                                    Just to let you know TIG and I'm not sure if anyone else has had this problem on a Mac, but I have an icon image missing.
                                    I installed the ruby and opened SU. The toolbar shows ok, but after closing down then re-opening, the first icon is blank.
                                    I can live with it, just thought I would report it.
                                    http://dmdarchitecture.co.uk/
                                      This was reported once before [that was on a Mac too when there were fewer tools http://forums.sketchucation.com/viewtopic.php?p=218480#p218480 think it was resolved by removing everything and reinstalling the whole set from scratch...].
                                      Are you sure you have all of the rb's and png's in the right folders ?
                                      There are currently only 7 tools - you show 8 - the extra [first] button is a 'false' one...
                                      What EEby.. tool does it open?
                                      It suggests to me that you have a duplicate rb loading from perhaps one of those Mac's dreaded extra 'personal' Plugins folders [scripts should all be in 'root' level Plugins folder ?].
                                      Use the Finder and search for any .rb files starting with ExtrudeEdgesBy... there should only be the 7 in the proper Plugins folder.
                                      There's also a toolbar loader called #extrusionToolbar.rb - that should also only be found in Plugins folder - that file just makes the toolbar for the other tools to add on too as they each load in turn...
                                        Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                        There are a few minor tweaks to some db text and newly rephrased FR lingvo files by Didier Bur [sorry Pilou - he is a 'Professor' πŸ˜‰ ]
                                        πŸ€“
                                          driven
                                          Hi TIG, just for info, I still have the extra button, unless I close the toolbar and reopen after a SU restart, each time.
                                          it's there even when TIGTools folder + rubies are the only items added to fresh instal of SU
                                          doesn't hurt anything..
                                            This extra button is a mystery as it only affects a few Mac users ???
                                            Any Mac-users got any ideas ???
                                            πŸ˜•
                                            • 31
                                            • 32
                                            • 4 / 32
