    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      driven
      Working a treat..... cheers again
        Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
        I'll fix it and reissue a new zip... πŸ˜’
          Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
          Also minor speed improvements and the lingvo files updates.
          Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
          Feedback please πŸ€“
            jessemorton24
            Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
            Cheers!
            Parkways, Driveways, Gateways, Pathways...
            • H
              haynesc
              http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
              Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
              ... would help keep our plugins list smaller ...
                Good idea - watch for next update....
                  Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                  πŸ€“
                    Ruturaj
                    Thank you TIG
                    GooD πŸ˜‰
                    Thanks,
                    RuturaJ
                      EEbyRails and EEbyRailsByFace have been updated to avoid a rare glitch in the mesh/ribs caused by some helical rails turning so exactly at 180 degrees in some parts...
                        Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                        It has some minor tweaks to FR lingvo files [thanks Pilou] etc and a brand new Tool ExtrudeEdgesByFaces.
                        You pick a face as a profile and then one rail [curve] - then a melding-profile-face [this could also be first face picked]. The location of the face(s) relative to the rail ends affects the final extruded form.
                        It then forms a triangulated mesh based on these faces, melding from one face shape to the other, completing it with capped ends - there are then options to reverse/smooth etc - [its functionality is very similar to EEbyRails with a pinch of EEbyFace]...
                        πŸ€“
                        • H
                          Howard leslie
                          TIG,
                          Thank you so much for producing this FANTASTIC set of tools.
                          Quite stunning.
                          I do, however, have something for you to ponder....
                          Will it be possible in the future to utilise Intermediate Profiles ???
                          (See attached *.skp file)
                          This would be EXTREMELY useful for producing models with a constantly changing cross section
                          eg boat hulls, aircraft fuselages, certain storage tanks and vessels etc.
                          This can be done at present with your "extrude edges by rails" (performed several times) - but the ability to utilise intermediate profiles would be brilliant.
                          Thanks once again for all your hard work in producing this set of tools - and for combining them together in one toolbar.
                          Regards
                          Howard Leslie
                          IntermediateProfiles.skp
                            The 'lofting by multiple profile selections' is on the list but I know Fredo also has lots up his sleeve too... πŸ€“
                            • Y
                              yuelai
                              hey,why cann't i download the attachment?
                              • Y
                                yuelai
                                somebody can help me please?
                                • Y
                                  yuelai
                                  is this plugin for Skechtup6 or 7 vision?
                                    What are you trying to do exactly ?
                                    Simply click on the zip file link [ extrudeTools_yyyymmdd.zip- the file's suffix varies with the date of the last upload currently 20100219 ?], you can find it at the end of the first post in this thread, and then your browser should ask you what to do [varies with browser make]... download the zip file to your desktop, then follow the 'extraction' instructions etc...
                                    You MUST extract the files as directed - that is in their sub-folders as supplied in the zip - DON'T try to drag/drop them out of the zip's window it'll go wrong. Use 'extract[_all]' option in you zip application and they should keep their folders intact. The .rb files go directly into the Plugins folder BUT the rest of them go into a TIGtools folder inside Plugins and even sub-folders within that...
                                    πŸ€“
                                    PS: These plugins works with SUp v6 and v7.
                                      dylan
                                      Just to let you know TIG and I'm not sure if anyone else has had this problem on a Mac, but I have an icon image missing.
                                      I installed the ruby and opened SU. The toolbar shows ok, but after closing down then re-opening, the first icon is blank.
                                      I can live with it, just thought I would report it.
                                      http://dmdarchitecture.co.uk/
                                        This was reported once before [that was on a Mac too when there were fewer tools http://forums.sketchucation.com/viewtopic.php?p=218480#p218480 think it was resolved by removing everything and reinstalling the whole set from scratch...].
                                        Are you sure you have all of the rb's and png's in the right folders ?
                                        There are currently only 7 tools - you show 8 - the extra [first] button is a 'false' one...
                                        What EEby.. tool does it open?
                                        It suggests to me that you have a duplicate rb loading from perhaps one of those Mac's dreaded extra 'personal' Plugins folders [scripts should all be in 'root' level Plugins folder ?].
                                        Use the Finder and search for any .rb files starting with ExtrudeEdgesBy... there should only be the 7 in the proper Plugins folder.
                                        There's also a toolbar loader called #extrusionToolbar.rb - that should also only be found in Plugins folder - that file just makes the toolbar for the other tools to add on too as they each load in turn...
                                          Here's an update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                          There are a few minor tweaks to some db text and newly rephrased FR lingvo files by Didier Bur [sorry Pilou - he is a 'Professor' πŸ˜‰ ]
                                          πŸ€“
                                            driven
                                            Hi TIG, just for info, I still have the extra button, unless I close the toolbar and reopen after a SU restart, each time.
                                            it's there even when TIGTools folder + rubies are the only items added to fresh instal of SU
                                            doesn't hurt anything..
                                            • 31
                                            • 32
                                            • 4 / 32
