    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • TIGT Online
      driven
      That code is legacy stiff from EEbyRails that I found I didn't ever need [yet] but I left it in but 'commented' out just in case - so that's not the problem...
      When you try it on your Mac what errors do you get in the in the Ruby Console ? πŸ˜•
        driven
        Error: #<NoMethodError: undefined method db' for #<Object:0x3f319f4>> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:359:in extrudeEdgesByFace'
        /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:463
        • TIGT Online
          Here's an updated zip file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          It's issued because the EEbyFace tool had a simple typo in it that meant that whilst it didn't affect my testing of it, it did mess up some of you - it's been fixed in the latest zip file... Sorry for any inconvenience 😳
            driven
            no problem,
            I EExRxF is working although it does crash out if you do it wrong, and it is that one that wasn't even starting.
            I was looking at the code for both (to see what I was doing wrong) when I saw the comment-out bit, then I got mixed up which was in error...
              driven
              Working a treat..... cheers again
              • TIGT Online
                Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
                I'll fix it and reissue a new zip... πŸ˜’
                • TIGT Online
                  Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
                  Also minor speed improvements and the lingvo files updates.
                  Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
                  Feedback please πŸ€“
                    jessemorton24
                    Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
                    Cheers!
                    Parkways, Driveways, Gateways, Pathways...
                    • H Offline
                      haynesc
                      http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
                      Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
                      ... would help keep our plugins list smaller ...
                      • TIGT Online
                        Good idea - watch for next update....
                        • TIGT Online
                          Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                          πŸ€“
                            Ruturaj
                            Thank you TIG
                            GooD πŸ˜‰
                            Thanks,
                            RuturaJ
                            • TIGT Online
                              EEbyRails and EEbyRailsByFace have been updated to avoid a rare glitch in the mesh/ribs caused by some helical rails turning so exactly at 180 degrees in some parts...
                              • TIGT Online
                                Here's a new version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                It has some minor tweaks to FR lingvo files [thanks Pilou] etc and a brand new Tool ExtrudeEdgesByFaces.
                                You pick a face as a profile and then one rail [curve] - then a melding-profile-face [this could also be first face picked]. The location of the face(s) relative to the rail ends affects the final extruded form.
                                It then forms a triangulated mesh based on these faces, melding from one face shape to the other, completing it with capped ends - there are then options to reverse/smooth etc - [its functionality is very similar to EEbyRails with a pinch of EEbyFace]...
                                πŸ€“
                                • H Offline
                                  Howard leslie
                                  TIG,
                                  Thank you so much for producing this FANTASTIC set of tools.
                                  Quite stunning.
                                  I do, however, have something for you to ponder....
                                  Will it be possible in the future to utilise Intermediate Profiles ???
                                  (See attached *.skp file)
                                  This would be EXTREMELY useful for producing models with a constantly changing cross section
                                  eg boat hulls, aircraft fuselages, certain storage tanks and vessels etc.
                                  This can be done at present with your "extrude edges by rails" (performed several times) - but the ability to utilise intermediate profiles would be brilliant.
                                  Thanks once again for all your hard work in producing this set of tools - and for combining them together in one toolbar.
                                  Regards
                                  Howard Leslie
                                  IntermediateProfiles.skp
                                  • TIGT Online
                                    The 'lofting by multiple profile selections' is on the list but I know Fredo also has lots up his sleeve too... πŸ€“
                                    • Y Offline
                                      yuelai
                                      hey,why cann't i download the attachment?
                                      • Y Offline
                                        yuelai
                                        somebody can help me please?
                                        • Y Offline
                                          yuelai
                                          is this plugin for Skechtup6 or 7 vision?
                                          • TIGT Online
                                            What are you trying to do exactly ?
                                            Simply click on the zip file link [ extrudeTools_yyyymmdd.zip- the file's suffix varies with the date of the last upload currently 20100219 ?], you can find it at the end of the first post in this thread, and then your browser should ask you what to do [varies with browser make]... download the zip file to your desktop, then follow the 'extraction' instructions etc...
                                            You MUST extract the files as directed - that is in their sub-folders as supplied in the zip - DON'T try to drag/drop them out of the zip's window it'll go wrong. Use 'extract[_all]' option in you zip application and they should keep their folders intact. The .rb files go directly into the Plugins folder BUT the rest of them go into a TIGtools folder inside Plugins and even sub-folders within that...
                                            πŸ€“
                                            PS: These plugins works with SUp v6 and v7.
                                            • 31
                                            • 32
                                            • 3 / 32
