    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
      d12dozr
      Thanks TIG, Just dl'd and played a bit. I like the zipped set...makes it so much easier. Cheers!
      http://goo.gl/f7ooYh
      • H Offline
        haynesc
        will the zipped set be updated along with each update of each individual plugin ?
        • TIGT Online
          The individual EEby.. tools will no longer be updated.
          Any new or updated EEby tool[s] will be issued in this zipped set...
          However, the 'notes' will remain in each individual tool's thread, and I shall also remove the downloads from each at the next update... [which might be next week].
          • H Offline
            haynesc
            cool ... much easier
            • majidM Offline
              majid
              Thnak you again dear Tig πŸ˜„
                remus
                I downloaded this a while ago and forgot to say thanks, so thanks! These are those most sacred of tools that bring entirely new functionality to SU.
                • TIGT Online
                  Here's today's update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  Contains two new tools:
                  EEbyFace (followme-like tool using a preselected 'flat' face with multiple paths if desired)
                  EEbyRailsByFace (uses EEbyFace across a mesh picked by Profile/Rail1/Rail2/Melding-Profile just like EEbyRails to form a 'rib-cage')
                  Links to their threads are in the main page... πŸ€“
                    dedmin
                      driven
                      Hi Tig, more toys,,, excellent
                      EEbyRailsbyFace isn't working on my Mac, and when I looked at the code, line 632 comments out all lines through to 693 which look important to me.
                      might this be my issue?
                      cheers
                      • TIGT Online
                        driven
                        That code is legacy stiff from EEbyRails that I found I didn't ever need [yet] but I left it in but 'commented' out just in case - so that's not the problem...
                        When you try it on your Mac what errors do you get in the in the Ruby Console ? πŸ˜•
                          driven
                          Error: #<NoMethodError: undefined method db' for #<Object:0x3f319f4>> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:359:in extrudeEdgesByFace'
                          /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/extrudeEdgesByFace.rb:463
                          • TIGT Online
                            Here's an updated zip file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                            It's issued because the EEbyFace tool had a simple typo in it that meant that whilst it didn't affect my testing of it, it did mess up some of you - it's been fixed in the latest zip file... Sorry for any inconvenience 😳
                              driven
                              no problem,
                              I EExRxF is working although it does crash out if you do it wrong, and it is that one that wasn't even starting.
                              I was looking at the code for both (to see what I was doing wrong) when I saw the comment-out bit, then I got mixed up which was in error...
                                driven
                                Working a treat..... cheers again
                                • TIGT Online
                                  Thanks - that points to a typo in the file that doesn't cause me a problem while checking it... but does you !
                                  I'll fix it and reissue a new zip... πŸ˜’
                                  • TIGT Online
                                    Here's an updated version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                    Main changes are in EEbyFace and the related EEbyFaceByRails - their extruded form is now consistently oriented.
                                    Also minor speed improvements and the lingvo files updates.
                                    Minor tweaks to some other tools db setups etc - these will probably go unnoticed by most of you...
                                    Feedback please πŸ€“
                                      jessemorton24
                                      Feedback....I noticed the uniform spline of Fredo's makes the sexest railed surfaces. I do think the bezier command shrinks these curves..But Thank you!! I will be donating on your behalf soon. Like the day I can actually put money in my pocket, sweariingly.. I use your tools the most!! lately. Much THANKS and donation soon!!!!
                                      Cheers!
                                      Parkways, Driveways, Gateways, Pathways...
                                      • H Offline
                                        haynesc
                                        http://i.imagehost.org/t/0301/extrude_tools_menu.jpg
                                        Hi TIG would you be able to place your tools in a sub-menu like iv shown above ?
                                        ... would help keep our plugins list smaller ...
                                        • TIGT Online
                                          Good idea - watch for next update....
                                          • TIGT Online
                                            Here's the latest version http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                            It now loads all of the available Extrusion Tools into one 'Extrusion Tools...' sub-menu in the Plugins menu...
                                            πŸ€“
                                            • 31
                                            • 32
                                            • 3 / 32
