    [Plugin] Eclate_Deplace (fragmentation-exploded view)
    161 Posts 51 Posters 234.4k Views 51 Watching
      Thank you for this plugin.
        dedmin
        @thomthom said:
        @dedmin said:
        Please, leave me some time for eating and sleeping!!
        We can make a plugin for that... ๐Ÿ˜„
        ๐Ÿคฃ ๐Ÿคฃ ๐Ÿ˜„
          0.3.1 Decimal point fixed ๐Ÿ˜’
            Congratulation - welcome to the Ruby Brotherhood ๐Ÿ˜‰
            In the English version dialog popout substitute "Group|Component|Both" for the untransalted French version to get it to work...
              Ah Damned! ๐Ÿ˜ณ Thx ๐Ÿ‘ (fixed) โ˜€
              With esperanto that will be more easy just one language ๐Ÿ˜’
                There is already one World language - unfortunately it's English [and it's American too!] ๐Ÿ˜‰
                Il y a dรฉjร  une langue du monde - c'est malheureusement anglais [et aussi c'est Amรฉricain!]
                Estas jam unu Monda lingvo - bedaลญrinde ฤi estas Angla [kaj tio estas Amerika ankaลญ!]
                ๐Ÿคฃ
                  c.plassais
                  ๐Ÿ‘ฟ ๐Ÿ‘ฟ ๐Ÿ‘ฟ ๐Ÿ‘ฟ ๐Ÿ‘ฟ ๐Ÿ‘ฟ ๐Ÿ‘ฟ
                  Good Works Pilou...............for the translation OF COURSE!!!
                               :facepunch:  :facepunch:  :facepunch:  :facepunch: :facepunch: :facepunch: :facepunch:
                  c.plassais
                    @C.plassais: sorry a very hard hyperactive end of year ๐Ÿ’š
                    See you soon next year! ๐Ÿ˜‰
                    [flash=500,405:1je4n8r4]http://www.youtube.com/v/o9698TqtY4A[/flash:1je4n8r4]
                    • MALAISEM Offline
                      MALAISE
                      Oh Guys, I miss a lot beeing on travel for the last 15 days.
                      Excellent work, I 'll use it very fast for technical explanations ๐Ÿ˜„
                      MALAISE
                      La Connaissance n'a de valeur que partagรฉe
                      • X Offline
                        xrok1
                        great plugin, thanks. if you could rename this "Exploded View" or "Exploded Model Viewer" or similiar, it would be much more precise and easier to find. ๐Ÿ˜‰
                        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                          Edit the script with a plain text editor - like Notepad.exe [osa] - and replace any 'French' text inside "" with your 'English' translation[s]. Keep a copy in case you screw up...
                          You can adjust a script to say whatever you want.... ๐Ÿค“
                            you speak about the title of the tread?
                            • X Offline
                              xrok1
                              yes, i was refering to the thread title. i don't think anyone searching for an "exploded view" would ever find it currently.
                                He got a point..
                                • X Offline
                                  xrok1
                                  it would make it a little more clear what the plugin is for as well. ๐Ÿ˜‰
                                    Done and tested with the search Engine โ˜€
                                    No someone can find it by the title and by your post ๐Ÿ˜‰
                                    • Rich O BrienR Online
                                      Anyone experiencing Bugsplats with SU7.1 and this plugin?
                                      Haven't used since last SU update now it Bugsplat everytime. I've attached the model if anyone want to see if it's just me?
                                      I know i have the components nested in a component but use this plugin when not nested
                                      CherryMax Rivet.skp
                                        Stephan
                                        Hello,
                                        Same problem for me with SU7.16860, I get a Bugsplat each time I try to use it. ๐Ÿ˜•
                                        Any idea?
                                        Rgds,
                                        Stephan
                                          kostas_designer
                                          No bugsplat to me, although i do not understand why some groups stay glued together..
                                          In this example there are only first-class groups:
                                            Is this plugin not compatible with the latest SU? Pilou if you've time can you look?
                                            It is behaving strangely with mixed results.
                                            • 2 / 9
