    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
      @tlerak said:
      where can i find tools on surface 1.5? thanks
      First post on the first page of this thread.
      • H
        haynesc
        how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
        http://f.imagehost.org/t/0905/Untitled-1_3.jpg
          Daniel S
          Alternative solution:
          I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
          Daniel S
          • T
            Toucan
            Where do I find this script?
            • Chris FullmerC
              Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
                I occasionally get this happening while using TOS. What's causing it?
                I wanted to draw an arc between the two points - going across the two faces.
                • fredo6F
                  @thomthom said:
                  [attachment=0:h62psy7e]<!-- ia0 -->TOS_oddness.png<!-- ia0 -->[/attachment:h62psy7e]
                  The algorithm has many flaws, espcially on shape volumes that are closed.
                  I am thinking of a serious refresh to resolve these problems (and some others).
                  • W
                    whippie
                    What a brilliant tool thanks thanks thanks 😄
                    • B
                      balloon
                      ☀ Thanks Fredo6 😍
                      • K
                        Khai
                        may I request an additional feature?
                        adding rounded corners to a shape?
                          So it some times picks the wrong distance/direction between the two points? A workaround would be to break the volume somehow?
                          • fredo6F
                            Somehow, it works much better when the surface is open.
                            But I know how to fix the problem. No easy, but I need some time, as I have to revisit the whole algorithm.
                            • N
                              nilblo
                              Rightclick menues issue..
                              After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
                              Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
                              I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
                              I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
                              Vista 64- Sketchup Pro 7.1.6860
                              Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
                              Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
                              SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
                                sus4
                                too Dont Work Ver7.1.6087
                                error massage ZLoader__OnSurface.rb File loading error
                                No such file to load -- LibFredo6.rb
                                • fredo6F
                                  I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
                                  I got it occasionally, even not using any plugins.
                                    sketchyup2010
                                    Great tool bro. Nice work!!!!
                                      dylan
                                      A minor issue and not sure if this is Mac related.
                                      I can only get the default icons to show.
                                      If I go into Default Parameters and choose IMAGES_DanielS then save changes, it does nothing. I can open the default parameters again and the box is un-ticked.
                                      I have the latest version installed.
                                      http://dmdarchitecture.co.uk/
                                      • T
                                        theark
                                        Thanks a lot.Good plug-in
                                        • COSEDIMARCOC
                                          COSEDIMARCO
                                          Thanks loads for this tool, your work is great!
                                          after I use this tool I sometimes loose right click options such as; smooth, make group/component, reverse faces, etc.
                                          [attachment=0:2zrlzv0n]<!-- ia0 -->Image.jpg<!-- ia0 -->[/attachment:2zrlzv0n]
                                          I have this issue too.
                                          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                          • Roguer1R
                                            Roguer1
                                            @ Dylan
                                            Just replace the default icons with the ones you wish (in the plugins directory). Thats actually the way I did it.
                                            I’m also having another issue. IDK if this has been discussed before or not, but after I use this tool I sometimes loose right click options such as; smooth, make group/component, reverse faces, etc.
                                            Find all my models on the 3D Warehouse
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
