    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.8m Views 202 Watching
    • W
      watkins
      Dear Fredo6,
      I note that when using your Tools on Surface plugin one has a toolbar which is permanently displayed and then an 'on screen' toolbar that appears when one selects a tool from the permanently displayed toolbar. Is this how it is supposed to work? If so, would it not be better to have a single permanently visible icon, perhaps labelled TOS, which when clicked brought up the 'on screen' toolbar?
      Kind regards,
      Bob
      • fredo6F
        @watkins said:
        Dear Fredo6,
        Bob,
        In TOS 1.5, I introduced a Generic Icon (the first one in the toolbar) that keep memory of last TOS tool launched.
        If you go to the Default Setting dialog box of ToolsOnSurface, you can hide all other icons and keep this one.
        PS: you may want to keep one or two other icons for the functions you need frequently.
        • W
          watkins
          Dear Fredo6,
          Many thanks for the explanation, and a most excellent plugin.
          Thank you again for your generosity.
          Kind regards,
          Bob
          • fredo6F
            Documentation in Frenchnow available, thanks to Jean-Francoand Christophe Plassais.
            See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
            • plot-parisP
              plot-paris
              hi Fredo,
              in the last couple of releases Daniel S' fancy icons are not implemented anymore. but only the old ones... do you know why that is?
              [Edit] ops.. never mind, just found them in the installation folder 😳
              thanks again for the great plugin []
              • K
                kilgo
                Is it possible to use this tool to put text on a surface. Flat text that follows the curvature of a sphere or rolling hills in all directions?
                  I think not BUT my 2D Tools - 2D Text will place 2D Text onto any face with the appropriate snapping option - it's not limited to '2D'... You could always place the text on to a high spot on the terrain and use the Sandbox Drape Tool to make the outline of it onto the terrain's surface ? Color it to suit...
                  • K
                    kilgo
                    Thanks TIG,
                    The drape tool only drapes in a vertical fashion (whats the coordinate? X,Y?) So if for example I wanted to drape a #2 on the side of a slope it becomes distorted, elongated. Love your work by the way.
                    • fredo6F
                      The script is now translated to Chinese, thanks to the effort of the CLT Team at SketchupBar.
                      see main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212&p=76625#p76625
                        Daniel S
                        Fredo...
                        Changing the axes has no effect in your inference system.. it still uses the standard axes.
                        Look that the standard SU tools are not using the original orientation of the axes.
                        Is there a way to choose that Tools on Surface can use the user defined axes instead the standard ones?
                        Daniel S
                          red_shift
                          Can someone please assist me with installing this plugin on Mac OS 10.6.2 (SU 7.1) I have unzipped the folder into SU plugin folder and moved Toolsonsurface.plugin to the Sketchup application package. I see no new menus in Sketchup.
                          • majidM
                            majid
                            I started to draw an arc on a curved face, and here is the result,....what is wrong with it? I was expecting that result , be somthimg like the black line , but finally I had the red line ,as result.
                              red_shift
                              I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
                              • fredo6F
                                On Mac, the plugin files should be copied to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
                                Please make sure that your unzipping operation leads to the same footprint as indicated in page 2 of the PDF documentation, that is:
                                The 2 folders, LIBFREDO6_Dir_34 and TOS_Dir_15 must contains several files (.rb, .lang, ...) and a subfolder IMAGES_STANDARD (make sure that you do not have another LIBFREDO6_Dir_34 or TOS_Dir_15 embedded).
                                If needed, unzip in a separate place, check the files and directories and then copy them in the Sketchup Plugin folder:
                                Fred
                                PS: if it still does not work, then I must call the Mac user community to help.
                                • T
                                  tlerak
                                  where can i find tools on surface 1.5? thanks
                                    First post on the first page of this thread.
                                    • H
                                      haynesc
                                      how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
                                      http://f.imagehost.org/t/0905/Untitled-1_3.jpg
                                        Daniel S
                                        Alternative solution:
                                        I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
                                        Daniel S
                                        • T
                                          Toucan
                                          Where do I find this script?
                                          • Chris FullmerC
                                            Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
