    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
      red_shift
      Can someone please assist me with installing this plugin on Mac OS 10.6.2 (SU 7.1) I have unzipped the folder into SU plugin folder and moved Toolsonsurface.plugin to the Sketchup application package. I see no new menus in Sketchup.
      • majidM
        majid
        I started to draw an arc on a curved face, and here is the result,....what is wrong with it? I was expecting that result , be somthimg like the black line , but finally I had the red line ,as result.
          red_shift
          I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
          • fredo6F
            On Mac, the plugin files should be copied to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
            Please make sure that your unzipping operation leads to the same footprint as indicated in page 2 of the PDF documentation, that is:
            The 2 folders, LIBFREDO6_Dir_34 and TOS_Dir_15 must contains several files (.rb, .lang, ...) and a subfolder IMAGES_STANDARD (make sure that you do not have another LIBFREDO6_Dir_34 or TOS_Dir_15 embedded).
            If needed, unzip in a separate place, check the files and directories and then copy them in the Sketchup Plugin folder:
            Fred
            PS: if it still does not work, then I must call the Mac user community to help.
            • T
              tlerak
              where can i find tools on surface 1.5? thanks
                First post on the first page of this thread.
                • H
                  haynesc
                  how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
                  http://f.imagehost.org/t/0905/Untitled-1_3.jpg
                    Daniel S
                    Alternative solution:
                    I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
                    Daniel S
                    • T
                      Toucan
                      Where do I find this script?
                      • Chris FullmerC
                        Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
                          I occasionally get this happening while using TOS. What's causing it?
                          I wanted to draw an arc between the two points - going across the two faces.
                          • fredo6F
                            @thomthom said:
                            [attachment=0:h62psy7e]<!-- ia0 -->TOS_oddness.png<!-- ia0 -->[/attachment:h62psy7e]
                            The algorithm has many flaws, espcially on shape volumes that are closed.
                            I am thinking of a serious refresh to resolve these problems (and some others).
                            • W
                              whippie
                              What a brilliant tool thanks thanks thanks 😄
                              • B
                                balloon
                                ☀ Thanks Fredo6 😍
                                • K
                                  Khai
                                  may I request an additional feature?
                                  adding rounded corners to a shape?
                                    So it some times picks the wrong distance/direction between the two points? A workaround would be to break the volume somehow?
                                    • fredo6F
                                      Somehow, it works much better when the surface is open.
                                      But I know how to fix the problem. No easy, but I need some time, as I have to revisit the whole algorithm.
                                      • N
                                        nilblo
                                        Rightclick menues issue..
                                        After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
                                        Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
                                        I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
                                        I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
                                        Vista 64- Sketchup Pro 7.1.6860
                                        Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
                                        Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
                                        SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
                                          sus4
                                          too Dont Work Ver7.1.6087
                                          error massage ZLoader__OnSurface.rb File loading error
                                          No such file to load -- LibFredo6.rb
                                          • fredo6F
                                            I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
                                            I got it occasionally, even not using any plugins.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
