    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.9m Views 202 Watching
    • majidM
      majid
      I started to draw an arc on a curved face, and here is the result,....what is wrong with it? I was expecting that result , be somthimg like the black line , but finally I had the red line ,as result.
        red_shift
        I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
        • fredo6F
          On Mac, the plugin files should be copied to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
          Please make sure that your unzipping operation leads to the same footprint as indicated in page 2 of the PDF documentation, that is:
          The 2 folders, LIBFREDO6_Dir_34 and TOS_Dir_15 must contains several files (.rb, .lang, ...) and a subfolder IMAGES_STANDARD (make sure that you do not have another LIBFREDO6_Dir_34 or TOS_Dir_15 embedded).
          If needed, unzip in a separate place, check the files and directories and then copy them in the Sketchup Plugin folder:
          Fred
          PS: if it still does not work, then I must call the Mac user community to help.
          • T
            tlerak
            where can i find tools on surface 1.5? thanks
              First post on the first page of this thread.
              • H
                haynesc
                how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
                http://f.imagehost.org/t/0905/Untitled-1_3.jpg
                  Daniel S
                  Alternative solution:
                  I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
                  Daniel S
                  • T
                    Toucan
                    Where do I find this script?
                    • Chris FullmerC
                      Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
                        I occasionally get this happening while using TOS. What's causing it?
                        I wanted to draw an arc between the two points - going across the two faces.
                        • fredo6F
                          @thomthom said:
                          [attachment=0:h62psy7e]<!-- ia0 -->TOS_oddness.png<!-- ia0 -->[/attachment:h62psy7e]
                          The algorithm has many flaws, espcially on shape volumes that are closed.
                          I am thinking of a serious refresh to resolve these problems (and some others).
                          • W
                            whippie
                            What a brilliant tool thanks thanks thanks 😄
                            • B
                              balloon
                              ☀ Thanks Fredo6 😍
                              • K
                                Khai
                                may I request an additional feature?
                                adding rounded corners to a shape?
                                  So it some times picks the wrong distance/direction between the two points? A workaround would be to break the volume somehow?
                                  • fredo6F
                                    Somehow, it works much better when the surface is open.
                                    But I know how to fix the problem. No easy, but I need some time, as I have to revisit the whole algorithm.
                                    • N
                                      nilblo
                                      Rightclick menues issue..
                                      After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
                                      Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
                                      I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
                                      I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
                                      Vista 64- Sketchup Pro 7.1.6860
                                      Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
                                      Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
                                      SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
                                        sus4
                                        too Dont Work Ver7.1.6087
                                        error massage ZLoader__OnSurface.rb File loading error
                                        No such file to load -- LibFredo6.rb
                                        • fredo6F
                                          I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
                                          I got it occasionally, even not using any plugins.
                                            sketchyup2010
                                            Great tool bro. Nice work!!!!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 31
                                            • 32
                                            • 13 / 32
