    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.6m Views 202 Watching
      red_shift
      I have still not been able to get the plugin to work on my Mac...can someone please give me some help?
      • fredo6F Offline
        On Mac, the plugin files should be copied to Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins
        Please make sure that your unzipping operation leads to the same footprint as indicated in page 2 of the PDF documentation, that is:
        The 2 folders, LIBFREDO6_Dir_34 and TOS_Dir_15 must contains several files (.rb, .lang, ...) and a subfolder IMAGES_STANDARD (make sure that you do not have another LIBFREDO6_Dir_34 or TOS_Dir_15 embedded).
        If needed, unzip in a separate place, check the files and directories and then copy them in the Sketchup Plugin folder:
        Fred
        PS: if it still does not work, then I must call the Mac user community to help.
          tlerak
          where can i find tools on surface 1.5? thanks
            First post on the first page of this thread.
            • H Offline
              haynesc
              how would i draw a diagonal curved line from plain to plain ... ? top right corner to bottom left corner ?
              http://f.imagehost.org/t/0905/Untitled-1_3.jpg
                Daniel S
                Alternative solution:
                I see that you have Whaat´s "subdivide and smooth". Use the knife tool (a.k.a. zorro) in parallel projection. Also you can group the faces you don´t want to divide:
                Daniel S
                  Toucan
                  Where do I find this script?
                  • Chris FullmerC Offline
                    Hi Toucan, the script is located in the first post of this thread. Go back to page one and look for a download link there. Have fun!
                      I occasionally get this happening while using TOS. What's causing it?
                      I wanted to draw an arc between the two points - going across the two faces.
                      • fredo6F Offline
                        @thomthom said:
                        [attachment=0:h62psy7e]<!-- ia0 -->TOS_oddness.png<!-- ia0 -->[/attachment:h62psy7e]
                        The algorithm has many flaws, espcially on shape volumes that are closed.
                        I am thinking of a serious refresh to resolve these problems (and some others).
                        • W Offline
                          whippie
                          What a brilliant tool thanks thanks thanks 😄
                            balloon
                            ☀ Thanks Fredo6 😍
                              Khai
                              may I request an additional feature?
                              adding rounded corners to a shape?
                                So it some times picks the wrong distance/direction between the two points? A workaround would be to break the volume somehow?
                                • fredo6F Offline
                                  Somehow, it works much better when the surface is open.
                                  But I know how to fix the problem. No easy, but I need some time, as I have to revisit the whole algorithm.
                                  • N Offline
                                    nilblo
                                    Rightclick menues issue..
                                    After having installed Fredo6 Tools on surface + FredoScale I´m having the darnest stupid problem:
                                    Most contextual menues are greyed out, like Intersect with model, Flip along Groups Red, and so on..
                                    I can create shortcuts to these commands and they work as expected, but I rely heavily on shortcuts in my work and list of shortcuts is getting more and more crowded. Have I done something wrong here and this is normal behavior? I have been searching the forum but so far havent found a description af this "problem".
                                    I have most definetely missed out on something here and the fault is obviously mine (as it usually is) but I really would appreciate an input to help me solve this matter.
                                    Vista 64- Sketchup Pro 7.1.6860
                                    Plugins: Fredo6 ToolsOnSurface v1.5f LIBFREDO6_Dir_34 (109 mS seems OK?
                                    Total time to load plugin = 187 mS) FredoScale v2.0g (Total time to load plugin =124 mS)
                                    SketchyPhysics verson3 Kerkythea SU2KT version 3.0 model exporter
                                      sus4
                                      too Dont Work Ver7.1.6087
                                      error massage ZLoader__OnSurface.rb File loading error
                                      No such file to load -- LibFredo6.rb
                                      • fredo6F Offline
                                        I have heard that this problem is related to SU itself, though it may be 'helped' by some plugins.
                                        I got it occasionally, even not using any plugins.
                                          sketchyup2010
                                          Great tool bro. Nice work!!!!
                                            dylan
                                            A minor issue and not sure if this is Mac related.
                                            I can only get the default icons to show.
                                            If I go into Default Parameters and choose IMAGES_DanielS then save changes, it does nothing. I can open the default parameters again and the box is un-ticked.
                                            I have the latest version installed.
                                            http://dmdarchitecture.co.uk/
                                            • 31
                                            • 32
                                            • 7 / 32
