    [Plugin] Selection Toys
    594 Posts 121 Posters 381.3k Views 121 Watching
      @pghstone83 said:
      I sent the file to the plugins folder on my C drive and extracted it there.I also took in the TTLib folder that I thought I needed for the plugin to work. But when I open the TTLib file up there's another selection toys folder in there.
      There should be no selection toys folder in the TT_Lib folder. Something has gone wrong there.
      @pghstone83 said:
      Isn't the process to send these plugins to the plugins folder in C drive and simply hit extract and enable them in sketchup?
      @pghstone83 said:
      Do I have to manually remove every file in the folder or can I just hit "extract"? Some other plugins had to be opened this way for me to get them to work. Also can I just import the "Selection Toys" download or do I also need to bring that TTLib file also?
      There things is; "just hit extract" depends on the extraction program you use. Some apps makes an extra unwanted folder - often happens on OSX it appears.
      For Selection Toys, the files and folders you want to move to your plugins folder is:
      A file named "tt_selection_toys.rb"
      A folder named "TT_Select_Toys" and it's containing sub-folders.
      For TT_Lib:
      A folder containing "TT_Lib" - this folder should contain other *.rb files and a webdialogs folder. If it doesn't contain that, but instead just got another folder named "TT_Lib" - then check out that next "TT_Lib" folder.
        Panga
        Thanks for this update, and this great plugin !!
          Maybe an image of the arborescence folder/files needing result will be an help for new plugin users? 😉
            Yea - I've been thinking I should include that for plugins that consists of multiple files packaged in .zip.
              Outer Edges added to selection filters and Quad-Face Loop now accepts multiple start-edges in my internal build. Got a couple of other things to finish before I release it though.
              • bagateloB Offline
                bagatelo
                MODO from Luxology have good tools that make interesting selections. I remenber one very good. Is something like select polygon by yes/no/yes/no/yes/no, or by samples. Think about this, please.
                  yes/no/yes/no/yes?
                  • bagateloB Offline
                    bagatelo
                    @thomthom said:
                    yes/no/yes/no/yes?
                    Please see the imagem called "selection"...
                    This is plugins tools to make selections in 3dsMax, and more...:
                    http://www.polyboost.com/features_selection.htm
                    http://www.orionflame.com/
                    • JClementsJ Offline
                      JClements
                      Hi Thom:
                      Selection Tools must be a labor of love! 😄
                      Selecting Instances on same layer (both all and active) not working? See attached.
                      Select Instance of Same Layer Not Working.skp
                        I will look into that.
                        (you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
                          @jclements said:
                          Another Bug; Select Edge Loops?
                          If after an edge loop is selected, then using the Layers Toolbar dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                          hm.. will have to look at that. I never use that toolbar. PC or OSX?
                          @jclements said:
                          Select Default Front and Default Back not working?
                          Might be a bug there. Thought I'd fixed it earlier, but maybe it slipped through... 😕
                            JClements
                            Yeh, I edited my post because part of it didn't make sense. 😲
                            If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
                            [Edit]
                              @jclements said:
                              Hi Thom:
                              Confirmed and fixed internally.
                              Thanks for reporting.
                                Can't reproduce.
                                  @thomthom said:
                                  Can't reproduce.
                                  Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
                                    [attachment=0:137w7llf]<!-- ia0 -->Layers Toolbar, PC.png<!-- ia0 -->[/attachment:137w7llf]
                                    This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
                                      rv1974
                                      Hi!
                                      What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
                                        Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
                                        This would be something that filters an existing selection? Or make a new selection in the active space?
                                          rv1974
                                          ...being able to select edges where the angle between connected faces are larger than a given angle?..
                                          -yes
                                          ...filters an existing selection?
                                          -yes
                                          • juan974J Offline
                                            juan974
                                            good idea rv1974, kind of : "select string edges", useful for complicated shape
                                            juan974 (Réunion island)
                                            website : http://sketchucation.com/click.php?url=http://www.tarn.us
                                            • 29
                                            • 30
                                            • 5 / 30
